Advise on these Pre-Amps?? - AVS Forum | Home Theater Discussions And Reviews
Old 10-02-2011, 05:14 PM - Thread Starter
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Hey guys I am currently debating on which pre-amp or intgrted amp I want to use and would like to hear some of your comments. I will be using a CD player for the majority of my music and will also be streaming music through my Airport Express. With that in mind, here are my options for pre-amps:
Nad- 1020 series 20
Nad- 1155
Adcom- GTP400
or
Nad- 7220PE receiver
Rotel- RX950AX receiver
or I guess I could go with the EMotiva ERC-1 or something from Onkyo or Yamaha. I was just thinking that not only would it be cheaper to go with the Nad/Adcom/Rotel but that it might yeild better SQ?
Martycool007 is offline
Old 10-03-2011, 04:33 AM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
i used to have the erc1, the build is good but sonicaly, i dont think is worth it. It just didnt best my 60 dollars sony dvd player and the remote is very insensity.
RicardoJoa is offline
Old 10-03-2011, 06:54 AM
whoaru99's Avatar
Liked: 69
Nad- 1020 series 20
Nad- 1155
Adcom- GTP400
or
Since you're looking at preamps and integrated amps, fairly different beasts, one having amplification built in and one not, is it safe to assume you have an amp to use with the preamp?
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 10-04-2011, 10:49 AM - Thread Starter
Quoted: 280 Post(s)
Liked: 176
Yes I know they are different. I will be using a good amp, probably an emo or rotel.
Old 10-08-2011, 03:40 PM
lastplace's Avatar
Quoted: 33 Post(s)
I used a NAD 1130 with a Hafler XL-280, very good preamp, excellent phono stage. Should have never sold it.
I love this HD stuff!
lastplace is offline
