Integrated Digital Amp with Wifi and USB? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-29-2011, 04:01 PM - Thread Starter
brian1212's Avatar
Looking for an integrated stereo amp with:
- Wifi/DLNA support
- USB input for connecting USB stick or harddrive
- must support 96/24 WAV/FLAC
Do not want an AVR.
What's out there that can do this, or do I need a 2 box soln?
brian1212 is offline
post #2 of 9 Old 11-04-2011, 02:37 PM
aquaphile's Avatar
I think the wifi might be the biggest roadblock in your list of demands
also, what's your rough budget? I cant imagine the ideal product being super affordable
2.0 > 7.1
aquaphile is offline
post #3 of 9 Old 11-04-2011, 09:50 PM
runner2k's Avatar
Hello Brian,
I'm looking for the same solution. I believe you/we will end up buying the Integrated Amplifier + Extra gear in order to have the USB input, Wireless/DLNA....
runner2k is offline
post #4 of 9 Old 11-06-2011, 11:08 PM
Clarion's Avatar
Clarion is offline
post #5 of 9 Old 11-07-2011, 06:41 AM
aquaphile's Avatar
Originally Posted by Clarion View Post
Naim UnitiQute
http://www.naimaudio.com/hifi-product-range/579
this device only has an analog USB connection, aka the signal isn't fed through the Naim's internal dac. the front input doubles as a 3.5 toslink, and there are coax and optical inputs in the back, but no digital USB. this may or may not suffice for the OP.
2.0 > 7.1
post #6 of 9 Old 11-07-2011, 09:03 AM
Knucklehead90's Avatar
Quoted: 498 Post(s)
Liked: 430
The Onkyo TX-8050 has WiFi & USB which plays from a thumb drive (mass storage) but only plays MP3 - no WAV or FLAC files. It's also a receiver.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #7 of 9 Old 11-08-2011, 06:28 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Get any simple stereo amp, and add Squeezebox touch (I can't call that tiny device a box). You even can use pure power amp, for that purpose, if media player is your only source.
ap1 is offline
post #8 of 9 Old 11-08-2011, 06:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
- Wifi/DLNA support
Do not want an AVR.
There should be no problem finding a Blu Ray player with these features, except for the 24/96 wav/flac weirdness. You are probably in your own world for that one - get a cheap laptop for that.
arnyk is offline
post #9 of 9 Old 11-09-2011, 06:21 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
With BD player you also need monitor to see menus. Device with touch screen is much better. Cheap laptop needs external DAC, and is likely more expensive then Logitech device.
ap1 is offline
Reply 2-Channel Audio
