Helping Setting up HK 3490 and LG 47LE5400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-05-2012, 02:04 PM - Thread Starter
Harlan Miles's Avatar
Everyone,
I tried a search, but I couldn't come up with anything. I have an HK 3490 receiver and an LG 47LE5400 television. I'm using an HD antenna to get my stations (so no cable box), and I'm trying to get audio (2.0) out of my HK 3490.
I've got the toslink cable going from the television to the receiver, but I can't get any sound. I've turned off the tv speakers, and I made sure to set the CD source to optical. I thought to use Video 1, but the receiver doesn't have any HDMI inputs.
Any suggestions?
H.M.
Harlan Miles is offline
post #2 of 13 Old 02-05-2012, 03:20 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
According to the manual (p.47), there could be ACP issues that you would have no control over. Also, check to see what kind of audio source the HK needs over optical. I'm betting it needs 2.0 PCM; not sure what the TV would be putting out.
It also seems like other than the headphone out jack, the optical out is your only option for audio out. All the other connectors appear to be inputs. If you continue not to have any luck and don't get an answer here, people in the video LCD Flat Panel Displays forum may be able to help more.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 13 Old 02-05-2012, 08:59 PM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 134
I'm guessing your LG television outputs Dolby Digital over the optical digital output. My LG plasma does. I had the same problem in a 2-channel, albeit analog, system. I tried sending the digital output of the LG from its internal TV tuner through an external, stand-alone DAC and then to an analog input on my 2-channel preamp. It didn't work because the DAC lacked a DD decoder. I think your HK 3490 also lacks a Dolby Digital decoder. That puts you in the same boat, because you'll get hiss instead of decoded sound from the TV's output.
Here's your solution: the GeffenTV Digital Audio Decoder (note, GeffenTV also sells a cheaper DAC which looks similar, but won't do what you need; you need the DD decoder in between your TV and your AVR).
http://www.amazon.com/gp/product/B00..._ya_os_product
Good luck.
Will2007 is offline
post #4 of 13 Old 02-05-2012, 09:30 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Mono-Price has HDMI to Stereo converters - one of them should do the job. You'll also need an HDMI splitter.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 13 Old 02-05-2012, 10:48 PM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 134
It sounds like it's more than an adapter issue. None of those will solve the problem of needing to decode the Dolby Digital signal his TV is outputting into a digital PCM signal to then be converted to analog. He needs a DD decoder in between his TV's optical output and his AVR's input because his AVR doesn't have a DD decoder.
Will2007 is offline
post #6 of 13 Old 02-06-2012, 10:02 AM
Quoted: 385 Post(s)
Liked: 332
Don't most TVs have an option to output 2 channel PCM? The TV manufacturers seem to have forgotten that there are many audio enthusiasts that have 2 channel setups. Very few add analog L/R output any longer. HK should have added a DAC that is capable of pulling out the stereo signal out of the 5 channel signal. Even their very expensive HK 990 integrated amp is not capable of dealing with a 5.1 DD signal. I know - I owned one for a while.
***GO SEAHAWKS ***
post #7 of 13 Old 02-06-2012, 12:06 PM
cel4145's Avatar
Liked: 2987
I looked briefly at the manual for the LG 47LE5400, and it doesn't say it can do 2 channel PCM but talks about 5.1 sound coming from that optical. This is the best bet as to the problem.
And you are right. Really too bad that there is no analog out on the back. Who wants to use the headphone jack for hooking up a 2 channel receiver, although that may be the best option here.
cel4145 is offline
post #8 of 13 Old 02-06-2012, 01:30 PM
glangford's Avatar
Quoted: 197 Post(s)
Liked: 170
Another option would be to use an AVR for its optical input and have the AVR downmix to 2 channel, then sell the HK 3490.
glangford is offline
post #9 of 13 Old 02-06-2012, 01:34 PM
Quoted: 385 Post(s)
Liked: 332
I looked at that manual too but I missed the headphone jack. That would work. I doubt there is much difference in sound quality between a 1/8" plug and standard L/R RCA jacks. One of these cables should work fine.
***GO SEAHAWKS ***
post #10 of 13 Old 02-06-2012, 03:31 PM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 134
I don't know about most, but LG apparently stopped offering that ability in recent models. I have 2 LG plasmas made in 2010, and they offer only 1 optical output, and they output only in encoded Dolby Digital. Sure, the TV has a DD decoder it uses when you use the TV's speakers, but there is no setting, no switch, nothing you can flip to use the decoder to send out PCM via the optical output. Believe me, I have tried and I have looked at every square millimeter of the thing and dug around in every user menu dozens of times, and you simply cannot output PCM via the digital optical output.
I'm with you, man. That's why I bought the GeffenTV DD decoder for $84. It solved my problem, but not before a lot of frustration on my part.
My TV does not have a headphone jack on the side or anywhere else like the OP's does, so that option was not available to me.
Will2007 is offline
post #11 of 13 Old 02-06-2012, 04:21 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
http://www.mycablemart.com/store/car..._detail&p=3146
I have no idea what the quality might be like. I assume it will downmix multichannel to 2-channel but that's not entirely clear.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #12 of 13 Old 02-06-2012, 05:43 PM
cel4145's Avatar
Liked: 2987
That seems the best option. It just sucks, though, having to have a connector visibly sticking out of the side of a TV, particularly now that people are also starting to use powered multimedia and subs with analog L/R output to enhance TV sound.
cel4145 is offline
post #13 of 13 Old 02-09-2012, 03:54 PM - Thread Starter
Thanks for all for all of the help everyone. I ended up going back and forth with both LG and HK (boy was THAT fun), and it turns out that the problem is as many of you expected - no PCM over the optical output.
To the person that suggested selling the HK - thanks, but I really love it, and I also use it for my turntables. I'm not yet in a position to have multiple audio setups, so I'm trying to figure out how to make the 3490 work for both. Looks as if I'll be going with the Digital Audio Decoder.
Reply 2-Channel Audio
