Enable USB audio on any Android 4.0 smartphone/tablet - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 151Likes
Old 04-20-2014, 01:04 PM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Originally Posted by Rodrigues_Brazil View Post
If so, is there a way to play files stored in another device, in case a NAS logged in a Windows lan?
Nope, for the time being.
Another app from the same developer, USB Audio Recorder PRO also including its own USB audio soft driver, can play music files stored on a 2TB external USB hard drive (USB hard drive and Android device connected to a powered USB hub).
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/4545#post_10473524
By the way, USB Audio Player PRO & USB Audio Recorder PRO can play and output 24-bit high resolution audio to a 24-bit capable USB DAC.
http://www.2l.no/hires/
Rodrigues_Brazil likes this.
Universal audio/video receiver (Dolby Atmos, DTS:X, etc.) is achieved.
Universal HDR TV (HDR10, Dolby Vision, HEVC HLG HDR, VP9-HLG / VP9-PQ YouTube HDR, Dynamic HDR) is required.
Push for universal HDR TV!
DanBa is online now
Old 04-20-2014, 01:22 PM
Rodrigues_Brazil's Avatar
Quoted: 269 Post(s)
Liked: 18057
That means the usb audio driver only works via those apps?
I think this is a limitation, considering that there is some apps which can access my files on the NAS normally.
Old 04-21-2014, 01:49 PM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Yes, the USB audio soft driver of USB Audio Player PRO (UAPP) / USB Audio Recorder PRO (UARP) can only work with UAPP/UARP for the time being.
The UAPP/UARP developer has unsuccessfully convinced other music player app developers to use his proprietary interface.
The UAPP app is relatively new. The UAPP/UARP developer is asking for a lot of requirements like folder playback.
Your requirement of DLNA/UPnP support should be posted on the thread "Android phones and USB DACs": the UAPP/UARP developer used to read it.
http://www.head-fi.org/forums/posts/by_user/id/351770
In the meantime, my workaround with a Galaxy Note 3 having a native USB audio feature is the following:
. using BubbleUPnP to discover new music stored on my NAS
. using UAPP for the best sound quality to listen my preferred music stored on a 64GB microSD card (waiting for a 128GB microSD card).
What are your apps able to play music files stored on your NAS?
DanBa is online now
Old 04-21-2014, 06:23 PM
jonmcdermott's Avatar
Hi, lots of great information here.
I have an old car (68 Chevelle) which currently has no audio system at all.  I'd like to build a head unit using something like a Samsung Galaxy Tab 3.  It seems like post #83 is most relevant to my project, but wanted to check since it was posted a while back, and things change fast.  My thinking was that I would install a standard car amp, then use the DAC and cables mentioned in post #83 to go: Tablet -> DAC -> Amp -> Car speakers
I haven't bought any gear yet, so I can adjust my plans if needed.
my questions are:
- will I need to use a specific audio player on the tablet, or will any player work?
- I like that the Behringer UCA202 is so economical, is it still the best option in this price range?
- Will I need to root my tablet?
- Anything else I need to be aware of ?
Thanks, Jon
jonmcdermott is offline
Old 04-22-2014, 01:54 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
It depends.
If your Android device has only a USB host feature (i.e. USB host-enabled Android device), only UAPP/UARP can drive a USB DAC. Most Android devices like the $40 Azpen A70 have a native USB host feature.
http://www.avsforum.com/t/1393599/enable-usb-audio-on-any-android-4-0-smartphone-tablet/180#post_23970959
If your Android device has a native USB audio feature (i.e. USB audio-enabled Android device), any player including UAPP/UARP can output a digital USB audio stream to a compatible USB DAC.
There is a list of stock Android devices reportedly working with compatible USB DAC on the fist post of this thread:
. Example of USB host-enabled Android device:
Samsung Galaxy Tab 3 8 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2013/06/03/samsung-galaxy-tab-3/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3360#post_9945126
. Example of USB audio-enabled Android device:
Samsung Galaxy Tab Pro 10.1 (tablet):
http://www.engadget.com/products/samsung/galaxy/tab/pro-10-1/
http://www.head-fi.org/t/558952/tablets-to-external-usb-dac/30#post_10308161
Nope!
"Plug & Play, if every USB audio-required component is functional ..."
FAQ:
http://*******/A4dCnP
Google Nexus 7, Timur's USB OTG CyanogenMod 10.1 Rom & USB audio:
http://rootzwiki.com/topic/37755-timurs-kernel-usb-rom-closed-21-aug-2013/
Nexus 7 running on Timur's USB OTG CyanogenMod 10.1 Rom >> USB DAC
DanBa is online now
Old 04-22-2014, 04:36 AM
Quoted: 269 Post(s)
Liked: 18057
Not exactly an app music player, actually through the "ES File Explorer" (https://play.google.com/store/apps/details?id=com.estrongs.android.pop.cupcake) I can access my NAS on the Windows Lan and play the most common media files, eg. MP3, FLAC, etc.
Regards!
Old 04-22-2014, 02:05 PM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
ES File Explorer is a file browser which can access (music) files stored on a remote PC.
Clicking on a music file will trigger a menu of installed music players (USB Audio Player PRO, ...) to be selected: the issue is only one music file can be played at a time (i.e. no random or next song playback mode available).
DanBa is online now
Old 04-23-2014, 05:55 AM
Quoted: 269 Post(s)
Liked: 18057
OK, I think that I have to wait for an app which could do everything that I need.
Thanks again, DanBa!
Best regards!
Old 04-23-2014, 03:25 PM
MC Maniac's Avatar
Hi
I purchased a Galaxy tablet - the Pro 8.4 model
I am contemplating getting the Hugo Dac
what will I need to do to have the Tablet function as the player?
John
MC Maniac is offline
Old 04-24-2014, 03:43 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
“Plug & Play, if every USB audio-required component is functional …”
FAQ:
A list of USB OTG cables:
http://*******/4JyOe5
http://www.avsforum.com/t/1393599/enable-usb-audio-on-any-android-4-0-smartphone-tablet#post_21633143
Android device >> USB OTG adapter cable + regular USB cable usually provided by the USB DAC maker (i.e. standard USB plug to standard / mini / micro USB plug cable) >> USB DAC >> amp >> headphones
Each component of the Android rig should be separately tested:
1. Test the USB DAC with a PC or a Mac:
PC >> regular USB cable provided by the USB DAC maker >> USB DAC >> amp >> headphones
2. Test the Android device with a USB OTG adapter cable and a simpler USB peripheral like a USB mouse or a USB keyboard:
Android device >> USB OTG adapter cable >> USB mouse
3. Finally, test the setup with a USB OTG adapter cable:
Android device >> USB OTG adapter cable + regular USB cable >> USB DAC >> amp >> headphones
If the final test is unsuccessful, then this Android device doesn't have a native USB audio feature, or the native USB audio feature is not compatible with this USB DAC (i.e. developers don't have the same understanding of some part of the USB specification): the USB Audio Player PRO app which includes its own USB audio soft-driver could be used to fix this interworking issue.
If the USB Audio Player PRO music player is not compatible with this USB DAC, then Davy Wentzler, the developer of USB Audio Player PRO, should be contacted.
Anyway, the USB audio soft driver of USB Audio Player PRO can drive a Chord Hugo USB DAC/amp.
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/4395#post_10390704
DanBa is online now
Old 04-24-2014, 08:09 AM
MC Maniac's Avatar
Thanks Dan
I have ordered OTG adaptor
John
Old 04-28-2014, 12:48 PM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
XMOS Multi-Function Audio Design Reference:
. speed up the development of a USB DAC compatible with Android, PC and Mac
. tested against Samsung Galaxy S3 / S4 / Note[3], Sony Xperia Z1, HTC One.
https://www.xmos.com/support/downloads/xkits/Reference%20Designs?product=17498
The XMOS people should also test their XMOS Multi-Function Audio Design Reference against the USB audio soft driver of USB Audio Player PRO, anyway very likely compatible.
DanBa is online now
Old 05-09-2014, 06:31 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
USB Audio Player PRO is capable of folder playback.
I like the possibility to play files:
. not recognized as "audio" by Android like mp4 video files
. stored on a folder on a (2TB) USB drive continuously in shuffle mode: USB DAC and 2TB USB drive connected to a Galaxy Note 3 via a battery-powered USB hub.
DanBa is online now
Old 05-09-2014, 10:02 PM
MC Maniac's Avatar
I now have the Hugo
It works fine but I have to use USB Audio Player PRO as the player..
hope they enhance this player - it is Ok but not as good as others
however I am grateful that the player exists - the HUGO really is impressive!
John
Old 05-12-2014, 03:29 PM
NathanielMead's Avatar
I had been using USB Audio on my Xperia Z for at least a year, worked with any media player, finally settled on the inbuilt Sony Walkman with a FiiO E17/FiiO E18 and AKG Q701/AKG K550 headphones. Suddenly it stopped working, I'd get three seconds of music then silence accompanied by the "USB using too much power" message. Everything worked perfectly with the AKG K550's but not with the Q701's. Trawled through every solution online but was still stumped. The only thing I had changed was headphone cable for the Q701's - so in desperation switched back to the previos cable et voila! Everything worked perfectly again! The new cable was the same brand as the previous cable, just shorter. So, if anybody has an issue - try swapping headphone cable over!!
 Have to say, listening to early Cure stuff on an Xperia with "surround sound" enabled, hooked up to the E17 or E18 and the Q701's is like hearing the albums new all over again! I do prefer the E17 to the E18, looks better and is more sturdier, I think it gives better sound also. Vinyl ripped to 24Bit FLAC is just gorgeous ..........
NathanielMead is offline
Old 05-20-2014, 04:19 PM
WhiskeyJack's Avatar
I wanted to ask if it was indeed true that the Audioquest Dragonfly v 1.0 is capable of being used as a dac with the Samsung s3 with an otg to micro usb? I believe I saw one connected otg cable, so I am on the edge of grabbing one or the HRT Music Streamer which I can get either one for 100$ or under for the MS II. I know there is the AMB Gamma 1 Lite which I am hoping that I can use with my S3 phone. any one had any luck with that diy DAC
WhiskeyJack is offline
Old 05-20-2014, 05:12 PM
How does the Fiio e17 sound as far as a dac is concerned? I can get one currently at 80ish USD. I am going to be using it with my phone, but I could also get the Dragonfly for a 100$ and the HRT MS II for 90. I am at a loss. I hater not being able to try these out.
Old 05-21-2014, 03:57 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Yes with USB Audio Player PRO according to the list of compatibility at the bottom of the 1st post.
For more details like headphones matching / synergy, you should ask the owner of the DragonFly who posted the Galaxy S3 - DragonFly compatibility information.
DanBa is online now
Old 05-23-2014, 10:23 AM
I like it a lot, makes  a massive difference to audio clarity, treble in particular. Also has an 'Optical Line' in which comes in handy. I have a FiiO e7 DAC you can have for the price of postage if you want to experiment with that?
Old 05-23-2014, 11:22 AM
Yeah I ended up not being able to get any of the ones I wanted to do to a ear infection medicine cost for my kid, and on top it htey put me on new meds that is not covered by my insurance which was ridiculous. 3 months of being out of work with a clot has seriously put a depressing cloud over my life currently. I jsut wish my luck would change for just a day.
Old 05-23-2014, 11:24 AM
Check your messages, your luck may have changed a tiny bit.
Old 05-29-2014, 03:38 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Sony Xperia Z2 & USB audio:
http://www.androidcentral.com/specs-lg-g3-versus-samsung-galaxy-s5-htc-one-m8-sony-xperia-z2
http://www.innerfidelity.com/content/trusted-traveling-companion-centrance-hifi-m8-portable-headphone-ampdac
http://www.cnet.com/news/the-best-in-ear-headphone-in-the-world-the-fitear-togo-334/
http://www.head-fi.org/t/633511/pictures-of-your-portable-rig-part-xvi/12225#post_10583824
Sony Xperia Z2 >> CEntrance HiFi-M8 >> Fitear Togo! 334
DanBa is online now
Old 06-03-2014, 04:03 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
USB OTG-Y cable from Elijah Audio: apparently a clean 5V from an external battery could improve the USB DAC sound
https://www.facebook.com/ElijahAudio?ref=stream
. micro OTG (ID pin grounded) plug to micro / mini / standard plug USB OTG-Y cable:
Galaxy S4 >> micro OTG plug to standard type-B plug USB OTG-Y cable powered by a 5V battery >> Digitech USB DAC/amp with a standard type-B receptacle
. micro OTG plug to standard type-A receptacle USB OTG-Y cable:
Android phone >> micro OTG plug to standard type-A plug USB OTG-Y cable powered by a 5V battery >> USB DAC with a standard type-A plug like LH Labs Geek Out, AudioQuest DragonFly, HiFimeDIY Sabre, ....
Android phone >> micro OTG plug to standard type-A plug USB OTG-Y cable powered by a 5V battery + regular USB cable provided by the USB DAC maker >> USB DAC
So-called USB OTG cable with separated power and data signal lines from Elijah Audio:
https://www.facebook.com/ElijahAudio/posts/547143015400331
Android phone >> micro OTG plug to micro / mini / standard plug USB cable >> USB DAC
Galaxy S4 >> micro OTG plug to mini-B plug USB cable >> HRT Microstreamer USB DAC/amp with a mini-B receptacle
DanBa is online now
Old 06-08-2014, 10:54 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Hyped / affordable OnePlus One (OPO) & USB Audio:
http://www.engadget.com/2014/05/08/oneplus-one-review/
http://www.soyacincau.com/2014/04/23/by-the-numbers-oneplus-one-htc-one-m8-samsung-galaxy-s5-sony-xperia-z2-and-oppo-find-7-compared/
https://forums.oneplus.net/threads/opo-usb-audio.20694/#post-1004430
"Yes there's support for USB DAC already, and that's a feature Steve [Steve "Cyanogen" Kondik] himself use a lot apparently. smile.gif
I suppose not every single USB DAC out here will be supported tho, as not all of them behave the same despite following the same spec (this includes power requirements).
I'll keep in mind the idea of maintaining a compatibility list." [Supercurio]
DanBa is online now
Old 06-11-2014, 02:56 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
HRT microStreamer USB DAC/amp & USB Audio Player PRO :
http://www.6moons.com/audioreviews/hrt5/1.html
http://www.innerfidelity.com/content/logitech-ue-900-ear-monitors
http://www.head-fi.org/t/647693/sonic-satori-hrt-levels-the-field-with-the-microstreamer/945#post_10614769
Sony Xperia Z >> HRT microStreamer >> Logitech UE 900 IEM
DanBa is online now
Old 06-26-2014, 08:48 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Upcoming Android L & USB audio:
http://www.androidpolice.com/2014/06...1-burst-photo/
Hopefully, it will be standard USB audio, and not specific Jelly Bean USB audio.
DanBa is online now
Old 06-27-2014, 03:40 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Standard USB audio is supported by Android L!
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/4995#post_10666723
Google Nexus 5 running on Android L >> USB audio out >> AudioQuest DragonFly USB DAC/amp >> IEM or headphones
DanBa is online now
Old 07-03-2014, 06:05 PM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Android L - Native USB audio:
https://code.google.com/p/android/is...ummary%20Stars
"We are also working on other audio features for L including adding USB audio support.
Please bear in mind that there are myriads of use cases and devices out there.
And while we may not support all of this initially, we will do our best to support as many as we can at launch and work to bring this support to the entire ecosystem as fast as we can."
https://groups.google.com/forum/#%21...dk/SnZ2j6odZSM
A list of standard USB DAC reportedly interworking with the native USB audio of Android L:
http://*******/x3loEQ
Google Nexus 5 running on Android L > digital USB audio out >> USB OTG cable (ID pin grounded) >> standard USB DAC >> amp >> headphones
. AudioQuest DragonFly (USB DAC/amp):
http://www.stereophile.com/content/a...b-da-converter
http://www.head-fi.org/t/595071/andr...#post_10666550
. FiiO E07K (USB DAC/amp):
http://headfonics.com/2012/12/fiio-e07k-the-andes/
http://www.reddit.com/r/Nexus5/comme..._on_android_l/
. FiiO E18 (USB DAC/amp):
http://headfonics.com/2013/12/the-e18-kunlun-by-fiio/
http://www.reddit.com/r/Nexus5/comme...roid_l/cin6wh3
Reportedly non-compatible USB DAC:
. Aune T1 (USB DAC/amp):
. FiiO E17: wrong USB OTG cable (?)
http://forums.androidcentral.com/and...usb-audio.html
Google Nexus 7 running on Android L > digital USB audio out >> USB OTG cable (ID pin grounded) >> standard USB DAC >> amp >> headphones
http://forum.xda-developers.com/show...2&postcount=20
. FiiO E17 (USB DAC/amp):
http://www.headfonia.com/the-upgrade-fiio-e17-alpen/
http://www.head-fi.org/t/724933/nexu...#post_10671435
. HiFimeDIY Sabre USB DAC ES9023 96KHZ/24BIT
. Schitt Modi:
http://www.head-fi.org/t/724933/nexu...#post_10673959
How to install Android L:
https://www.youtube.com/results?sear...drid+l+install
"Install the L Preview System Image
1. Download and uncompress the Android Developer Preview package
2. Follow the instructions at developers.google.com/android to flash the image onto your device.
Revert a Device to Factory Specifications
If you want to uninstall the L Preview and revert the device to factory specifications, go to developers.google.com/android and download the image you want to flash to for your device. Follow the instructions on that page to flash the image to your device."
http://developer.android.com/preview/setup-sdk.html
DanBa is online now
Old 07-07-2014, 08:36 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
Well-praised review of "Resonessence Herus + Dell Venue 7 / HTC One + USB Audio Player PRO (UAPP)":
http://everythingaudionetwork.blogsp...-heru-dac.html
"... audiophile playback ... the sound quality via the tablet was as good through the Herus as the Macbook Pro and Audirvana playback, Clean, quiet, smooth and plenty of detail, especially for the money...."
DanBa is online now
Old 07-10-2014, 02:42 AM - Thread Starter
DanBa's Avatar
Quoted: 139 Post(s)
Liked: 433
DanBa is online now
