Amp & speaker match question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-24-2012, 04:22 AM - Thread Starter
Evildude's Avatar
Quoted: 31 Post(s)
Hi guys I currently have a cheap Sony str-dh100 that's rated at 100W x2 (according to the manual) and with it I'm using a pair of old sony bookshelf speakers rated at 120W, and I'm using it with my imac so I really don't play them very loud.
I just came across a nice pair of pioneer bookshelf speakers rated at 80W and I'm afraid to ruin either the amp or the new speakers..
Should I get the new speakers of will the sony amp brake them?
Evildude is offline
post #2 of 11 Old 02-24-2012, 04:05 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
You should treat the speaker "ratings" as meaningless. The new speakers will be fine.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 11 Old 02-25-2012, 07:42 AM
dsmith901's Avatar
At these (price and brand) levels, I agree. Where you can get into trouble is powering low impedance rated speakers (4 ohms and below) with inexpensive receivers or amps that cannot deliver enough current at higher sound levels and you get clipping and/or compression that destroys the speaker. This is critical when you have expensive speakers; not so much with Sony or Pioneer brands (no offense). H/K and NAD receivers are generally better in that regard, but the Sony should have no problems with those speakers unless the OP plays them so loud his hearing suffers.
"The truth is out there!"
dsmith901 is offline
post #4 of 11 Old 02-26-2012, 09:41 AM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
Your amplifier is not going to damage those speakers. Four-inch drivers are very small, though.
If you are not using a subwoofer, you might want to consider some speakers that have at least a 5.5 inch main driver.
For $140, you can get a pair of Polk Monitor 40 speakers, which have dual 5.5 inch drivers and should give you much more sound.
Originally Posted by Evildude View Post
Hi guys I currently have a cheap Sony oreId=10151&langId=-1&partNumber=SSB1000"]sony bookshelf[/url] speakers rated at 120W, and I'm using it with my imac so I really don't play them very loud.
commsysman is offline
post #5 of 11 Old 02-26-2012, 10:05 AM
diomania's Avatar
Liked: 50
That's a vague statement and not helpful to OP. Just because speaker driver is 5.5 inches or larger doesn't mean much. There are bunch of those out there with poor performance. What you are suggesting is to approach it from the wrong end.
diomania is offline
post #6 of 11 Old 02-26-2012, 10:09 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
The BS21s are only $70 shipped at Newegg through today.
However, if your older Sonys have much bigger drivers, you might be disappointed in the sound of those very small bookshelves. If you like the Pioneers, you might want to talk to the people in the owners thread for that speaker line. For instance, it might be worth saving up for the BS41s, which is the model getting great reviews: http://www.stereophile.com/content/p...lr-loudspeaker
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #7 of 11 Old 02-26-2012, 11:26 AM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3095
I agree. It might be better to save and get a pair of BS41s or the FS51 mini-towers. Newegg was having a sale on the FS51s for $130. That's a steal. I think you would be much happier with the FS51s. They have decent, clean bass as well. You won't be able to hit the super low notes (rap, house, or movies) without a subwoofer if that matters to you.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #8 of 11 Old 03-04-2012, 10:40 AM
SpotcheckBilly's Avatar
Somehow a certain speaker in a manufacturers lineup exceeds all expectations, and it's often not the most expensive or largest in the group. It seems that this is the case with the BS41. I recently purchased a pair through Amazon.com for $144. The BS41's larger and smaller brothers are more deeply discounted because they are less popular.. I strongly suspect the BS41 is stealing their thunder. Perhaps that's due to the extremely positive reviews in the press and the word-of mouth going around on the street
Some folks will dismiss them out of hand because they come from Pioneer ...too bad for them. You owe yourself a listen.
Cheers,
SB
SpotcheckBilly is offline
post #9 of 11 Old 03-07-2012, 01:02 PM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
Over the years, the speakers made by Sony, Pioneer, Yamaha, and other big Japanese manufacturers have ranged from the cheapest trash imaginable to some big-bucks high-end speakers that are excellent (and super-expensive). Sony currently makes speakers for under $100 that you probably wouldn't want to listen to, and they also make $30,000 speakers that you would love.
Going by the brand name is seldom a good idea, but that is even more true with these big companies. There are a few brands I trust to put out a good product, like Vandersteen and PSB, but companies that can match their track record are few and far between.
The big companies certainly have the engineering resources to put out good products when they choose to do so.
I remember some floorstanding Pioneer speakers I listened to in a recording studio in the 1960s that had built-in multiple power amplifiers and were incredibly good-sounding. They actually were three-way speakers with three separate power amplifiers in each speaker. They were about $2500 per pair though, which was more than I spent to buy my new 1967 Ford Cortina. I bought some Wharfdale speakers I could afford.
Cheers,
SB
post #10 of 11 Old 03-07-2012, 03:39 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 317
Cheers,
SB
Built by one of the best speaker designers in the business. Andrew Jones designed the Pioneer TAD series. He was also at one time head of KEF speaker design. Always a great challenge to create a great product on a limited budget. Very impressive speakers at that price point.
Class A is online now
post #11 of 11 Old 03-08-2012, 01:53 AM
A9X-308's Avatar
Quoted: 1300 Post(s)
Liked: 964
I agree that Andrew Jones is a talented designer. I would like to hear the SB41, but they don't seem to be available locally.
TAD also have a great heritage.
A9X-308 is offline
Reply 2-Channel Audio
