Best A-D box to rip vinyl - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 03-02-2012, 02:22 PM
mlknez's Avatar
Quoted: 207 Post(s)
Liked: 52
I have an Inport by Xitel that I have owned for 6 years or more. It was fine for ripping vinyl at 44.1khz/16bit. It also is a simple device in that it was small, standalone, had rca input and usb output and operated off of usb power. Is there anything somewhat like that but for higher-res output?
http://www.xitel.com/USA/prod_inportpro.htm
mlknez is offline
post #32 of 40 Old 03-02-2012, 02:48 PM - Thread Starter
fje00's Avatar
Originally Posted by Jinjuku View Post
M series from EMU is one heckuva audio device hands down.
So how do audiophiles adapt their interconnect RCA cable to a 1/4" jack? With a cheapo Radioshack adapter?
fje00 is offline
post #33 of 40 Old 03-02-2012, 02:57 PM
Jinjuku's Avatar
Quoted: 62 Post(s)
Liked: 148
I would go to Guitar Center for that. Hosa would be fine. Mogami is higher priced but not necessarily SQ higher end. Both are effectively affordable compared to the esoteric/boutique brands.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #34 of 40 Old 03-02-2012, 08:51 PM
syd123's Avatar
Quoted: 57 Post(s)
Liked: 59
Reading this thread sparked an interest in me to give vinyl to digital transfer a try. ..Since I have a macbook pro I simply connected the record out of my amp to the line-in on my laptop (RCA-to-1/8" plug) and used Garage Band Pro to record then export as AIFF. It sounds great!!! ..Wanting a bit simpler work-flow I downloaded VinylStudio for free (for 5 albums, then $30 after trial-period) and it's fantastic; it tags all of the tracks and accurately inserts track breaks, etc. ..Am I missing something doing it this way? ..I'm shocked at how easy this is.
McIntosh MA6600 Integrated amp (for 2-ch) | Onkyo TX-NR1030 AVR (TV/ Movies) | Paradigm Sig S8 v2's (front) | Paradigm Prestige 55C (Center) | Boston Acoustics Bravo 20 speakers (rear) | 2010 Technics SL-1200mk2 Turntable w/ AudioTechnica 440mla cartridge | Mac Mini Music Server | Emotiva XDA-2 DAC | Logitech Touch SB | Samsung PN58B860 Plasma TV
syd123 is offline
post #35 of 40 Old 03-03-2012, 05:51 AM - Thread Starter
fje00's Avatar
My motivation was in how bad CD can sound. Particularly the rock CDs from 80's and 90's. It started with listening to a lossless rip of Genesis "And Then There Were Three". Abysmal. Granted it isn't necessarily the CD in all cases, including this one. I have yet to hear this on vinyl. Could very well be the original master.
The deciding factor turned out to be my comparison of Genesis "Lamb Lies Down ...". My lossless CD rip I thought sounded pretty good. Then I heard a vinyl rip to 24/96k and was blown away how much better it sounded. That did it for me. Bought the box set of the Gabriel years on 180g.
BTW, I ended up going with the EMU 1616m pci. Amazon prime $400.
fje00 is offline
post #36 of 40 Old 03-03-2012, 07:34 AM
Jinjuku's Avatar
Quoted: 62 Post(s)
Liked: 148
I would be interested in hearing a track done on your existing pre-amp and then done on the pre included with the 1616M
Jinjuku is offline
post #37 of 40 Old 03-03-2012, 08:01 AM - Thread Starter
fje00's Avatar
Will do. Still waiting on the new gear to arrive.
turntable: Concept by Clearaudio
cartridge: Bluepoint Evo III by Sumiko
phono stage: M1 Vinl by Musical Fidelity
interconencts: Blue Oval by Analysis Plus
LP cleaning machine: Okki Nokki by Sumiko
fje00 is offline
post #38 of 40 Old 03-03-2012, 12:56 PM
Jinjuku's Avatar
Quoted: 62 Post(s)
Liked: 148
Maybe you could also make a recording with the Blue Ovals and some vanilla type interconnects. I would also like to hear that too.
Jinjuku is offline
post #39 of 40 Old 03-05-2012, 01:07 AM
Cyclone82's Avatar
Because i have a lap top i cant use the EMU 1616M. What would be the next best EMU unit i could use that either works with USB or Firewire?
Cyclone82 is offline
post #40 of 40 Old 03-05-2012, 09:41 AM
Jinjuku's Avatar
Quoted: 62 Post(s)
Liked: 148
Why not get the M-Audio you posted earlier?
Jinjuku is offline
Reply 2-Channel Audio
