Hook up only 2 speakers to a 5.1 avr - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-28-2012, 08:18 AM - Thread Starter
Leary Herrinf's Avatar
I have a HK AVR 154. Can I hook up only two floor speakers to the front outputs and not hook up any speakers to the center, surround and sub outputs?
I know this will produce stereo only. My concern is, will I damage the reciever?
Leary Herrinf is offline
post #2 of 6 Old 02-28-2012, 08:37 AM
Ovation's Avatar
Quoted: 102 Post(s)
Liked: 65
No. I do that with my older AVR in my living room. No troubles. Enjoy the tunes/films.
Ovation is offline
post #3 of 6 Old 02-28-2012, 08:38 AM
underminded999's Avatar
Quoted: 29 Post(s)
Nah, you'll be fine.
A lot of people buy their AVR's with the hopes of "future proofing" their purchases, to add more speakers later.
There is no harm, in only using two channels of a 5.1,6.1,7.1,9.1, etc... system.
Enjoy what you have, and know that once you decide to expand, you have the ability, to do so.
underminded999 is offline
post #4 of 6 Old 03-03-2012, 09:21 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
There is no problem at all with doing that. Not using the other channels also makes more power available for the front 2 channels than might be the case running all 5.
commsysman is offline
post #5 of 6 Old 03-03-2012, 04:41 PM
ckcoolic's Avatar
The only downside is that series of HK won't auto calibrate with only two speakers, but I think it only adjusted levels and time delays anyway. If I recall right, that AVR had no room correction EQ so you won't be losing that much functionality. Level matching for a stereo setup can still be done by hand. I ran my old AVR 247 which was the previous model year to yours as a 2.0 and later 3.0 setup for a while.
ckcoolic is offline
post #6 of 6 Old 03-04-2012, 11:56 AM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
Just in case....
Tube amplifiers can/will be damaged by running with no speakers attached. It has to do with the output transformer being unloaded.
Solid state amps with no output transformer (anything made since about 1970) are fine running unloaded.
Glimmie is offline
Reply 2-Channel Audio
