Amp picks up local radio - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 50 Old 03-08-2012, 08:54 AM
SAM64's Avatar
Liked: 78
read back
I did.
Any unshielded wire can be an antenna. But when in use as a speaker cable, it doesn't transmit those signals anywhere due to the high current energy traveling through it.
No, still not convinced.
SAM64 is offline
post #32 of 50 Old 03-08-2012, 12:42 PM
rntlee's Avatar
Originally Posted by Theonetruegreg View Post
Excellent work on your ability to copy and paste from another source.
Reading is an important life skill.
Did this paper also go on to say that the speaker wires that are cryogenically treated and blessed by saints are even better at resisting interferrence?
Are you purposely trying to come across as a dolt? The paper is about ferrite cores being used as low-pass filter to remove radio frequency interference...nothing magical there bud.
I have never seen any speaker wire in a properly designed and working system introduce audible noise, have you?
Once again, the "wire" is not the source of the noise. It's simply a path into the amplifier via the negative feedback loop. It would behoove you to read up on amplifier construction.
Have you happened to open any hi-end speaker's cabinet and peak around inside? Did you see twisted pairs in there? You didn't. It must be that wood is an amazing shield!
It's enirely possible his chosen length of speaker wire is some resonant fraction of the wavelength he is picking up. Say he's picking up RF @ 90 MHz (wavelength = 3.3m), a 1.65m speaker wire would equal 1/2 wavelength, a nice length for a 90MHz resonant antenna. Do your speakers have 5 1/2' lengths of extended wire in them?
Regardless, this bickering with you is pointless, so I'll not respond here further.
To the OP, hope you resolve your problem, be it with either the input or output wiring.
rntlee is offline
post #33 of 50 Old 03-10-2012, 07:51 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
From what you said about the change when you moved things, there is not much question that the interconnects are the proximate cause.
Get the RF filters (ferrites) and clamp them to either end of each interconnect cable (Post#16).
Originally Posted by AudioVideoPhilia View Post
Good to hear. I was not looking forward to tin foil wallpaper!
commsysman is offline
post #34 of 50 Old 03-11-2012, 07:22 AM
kenglish's Avatar
Liked: 40
I was just thinking about posting the same link. Jim Brown offers quite a bit of expertise on the subject of interference, with this and other publications. He may get a bit "technical" for some people's tastes, but I've never seen him include any smoke, mirrors, or snake oil (cryogenic or not) in his work.
As for the speaker leads, leave them connected, but turn the amp's power off, and see if you hear a "peep" out of the speakers. If not, try connecting one cable at a time, and see where you start to hear the interference. You may have a loop of some kind that is resonant to the station's frequency, or maybe (not unheard of) a bad solder joint in a connector.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #35 of 50 Old 03-11-2012, 07:37 AM
kenglish's Avatar
Liked: 40
Here's a couple of interesting links from the same site:
http://audiosystemsgroup.com/bio-jb.htm
http://audiosystemsgroup.com/publish.htm
Although it's pretty deep stuff, here are some links that show how interference happens, and how people design their systems to deal with it. It's not light reading, by any means, but skimming through it can give insight in to how much of a "science" it really is:
http://www.arrl.org/files/file/Techn...I_Handbook.pdf
http://www.arrl.org/files/file/Techn...seHandbook.pdf
kenglish is offline
post #36 of 50 Old 03-11-2012, 07:38 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
You forgot that he gets interference from FM broadcast. Unlike AM station, FM cannot be received and decoded by simple circuits. So it is very unlikely that it comes though common EMI path. Usually this type of interference comes from cross feed from another input, and happens in preamp. I am surprised that OP still gets it when his power amplifier s disconnected from preamp. There is definitely something in his surrounding, that receives FM broadcast and converts it into audio frequencies picked up but amplifier.
ap1 is offline
post #37 of 50 Old 03-11-2012, 08:49 AM
kenglish's Avatar
Liked: 40
Rectification could be occurring in a bad solder joint, or any other non-linear device (like a transistor or IC that's getting hit hard by the signal.
kenglish is offline
post #38 of 50 Old 03-11-2012, 09:47 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
For AM signal - yes, but not for FM. For FM signal to be heard, you need both nonlinear and resonant circuits to work together. This is much less likely occurs unintentionally.
ap1 is offline
post #39 of 50 Old 03-11-2012, 03:30 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Ap1,
I said that exact same thing once, but it turned out I wasn't entirely correct. Sometimes the theory has to give way to the realities of imperfect circuits.
The problem in my case was that the FM station had an AM component in its signal - a hard thing to avoid when high-power is involved.
Amplifiers are not always linear, and a 100,000 watt transmitter might not put out constant amplitude as the frequency is modulated. An FM receiver would not care, so there is no pressing need to fix it. So a high-powered FM station could have an AM component in its broadcast.
Then, all you would need is a diode to detect it.
MarkHotchkiss is offline
post #40 of 50 Old 03-13-2012, 11:24 AM - Thread Starter
AudioVideoPhilia's Avatar
Over the week-end, the dealer who sold me the amp lent me a line conditioner and a high end AC power cord to test. It didn't help the RFI the amp is experiencing but the line conditioner does wonders for my plasma TV. But thats for an other forum. The RFI is strongest when the pre-amp is conected to the amp but still audible when the amp is powered on with only speakers hooked up. By wraping my speaker wires in tin foil I managed to reduce the RFI to the point where I only hear it when I put my hear right next to the speakers, headphone style. Unfortunately, when I hook up the pre-amp the RFI comes back as loud as ever. So I'll keep on tinkering with it for a while until I get fed up and ask the dealer to take it back.
Thanks for all the information guys!
AudioVideoPhilia is offline
post #41 of 50 Old 03-13-2012, 12:09 PM
Liked: 85
. . . I was not looking forward to tin foil wallpaper!
Hi AudioVideoPhilia,
Sorry to say, but that may be you only solution, short of returning the amp. (Be sure the wallpaper is connected to ground).
The fact that shielding the speaker cables reduced the interference indicates that it is indeed entering through the speaker cables. The fact that plugging in the pre-amp makes it louder indicates that it is also entering through the line-level inputs. It appears that wherever the RFI can get in, it is getting in. So it seems to me that the designer of the amp overlooked the possible effects of a local radio station.
Bottom-line: It is simply a poorly designed amp.
post #42 of 50 Old 03-13-2012, 01:02 PM
whoaru99's Avatar
Liked: 69
Yeah, I'd try a different amp if you can. Different as in different brand, not just different model of the same.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #43 of 50 Old 03-13-2012, 01:15 PM
kenglish's Avatar
Liked: 40
Just did a Google search on your amplifier, and saw a couple of posts about interference...especially from "HomePlug" (data via power line) stuff, getting in through the power input.
Did you try the ferrites? I would try them, right at (just as close as possible) the point where the power cord goes in to the unit. Try them on the power, and also on the speaker leads, again at the unit itself, simultaneously.
You want to block any path that can let the interference sneak in.
kenglish is offline
post #44 of 50 Old 03-13-2012, 03:25 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
These ferrites are mostly to prevent HF leak FROM device, not into it. If level of RF signal in the room is within allowed limits, I would change the brand. Get something from major manufacturer. High volume manufacturers usually do more rigorous testing for EMI.
ap1 is offline
post #45 of 50 Old 03-16-2012, 07:10 PM
math-geek's Avatar
I would dump the amp off ASAP. There is probably no magic cure! A great deal of technical data has been presented here. You cannot overcome (easily) a poorly designed amplifier! One member mentioned the "high feedback" that "all" solid state amps use to acheive low THD...That is bunk!!! Some mfgs use a lot, some little and some none.
I live in a city with many radio stations very nearby and have never, ever had this issue, end of story. I have had ground loops (hums) caused by preamp amp combos but have never one time picked up a radio station! If you have not experienced this issue before it is not voodoo that will fix it. If you have to use a ferrite magnet to "fix" the Exposure amp, then something is wrong!
BTW, I use only SS amplifiers.
math-geek is offline
post #46 of 50 Old 04-06-2012, 11:25 AM - Thread Starter
Quick update. I brought the amp back to the shop so they could run some tests. They were able to reproduce the problem and they've greatly reduced the RF interference after a bit of soldering. They're waiting for an order of ferites to come in to see if they can eliminate it completely. They tell me they plan to use the ferites internaly. I'll know more in a few weeks.
post #47 of 50 Old 04-06-2012, 02:34 PM
Webomatic's Avatar
Good to hear that they are doing what they can to eliminate your problem. I've had issues with radio stations nearby. I've either capped of the unused RCA inputs or soldered a 50 ohm resistor on a RCA connector and placed it on the inputs. It seemed to work.
Webomatic is offline
post #48 of 50 Old 02-01-2013, 08:34 PM - Thread Starter
Just to close the book on this. It was all speaker cables' fault. Took a long time to get around to buying new ones because the RFI was down to almost inaudible levels but new Chord Company shielded cables fixed it once and for all.
post #49 of 50 Old 02-02-2013, 11:12 AM
rntlee's Avatar
Glad you got it sorted, bro.
rntlee is offline
post #50 of 50 Old 02-02-2013, 12:24 PM
chashint's Avatar
Liked: 54
Good grief, why put up with an amp that has obvious design issues when there are so many available that work the way they are supposed to ?
Charlie
chashint is offline
Reply 2-Channel Audio
