Yamaha P-450 turntable tonearm lubrication - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-05-2012, 06:21 PM - Thread Starter
chileboy's Avatar
As the Subject says...I have an admittedly-old Yamaha P-450 turntable...not the greatest, but it has served my needs over the years.
Lately the tonearm pivot (the left-right, up-down) where it connects to the base has stopped moving freely. I've had to increase the tracking force in order to get it to drop normally onto the record - not a good solution, I know.
I've ordered a service manual so I can hopefully ascertain how to remedy this, but my thinking is that after all of this time, it simply needs lubrication - but I don't if this is advisable or possible, and, if so, what lubricant to use.
I was hoping to get some advice.
- Mark
chileboy is offline
post #2 of 5 Old 03-06-2012, 01:24 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Vinylengine.com. Free to sign up, and all the resources you can imagine for Turntables!
jdcrox is offline
post #3 of 5 Old 03-06-2012, 08:31 AM - Thread Starter
chileboy's Avatar
jdcrox, thanks for that, I have done so.
chileboy is offline
post #4 of 5 Old 03-07-2012, 12:48 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
A silicone lubricant such as is used for locks etc, is usually a good choice, but there are many different situations.
The old lubricant may have dried out and become solid or gummy, and needs to be flushed out with a solvent first.
- Mark
commsysman is offline
post #5 of 5 Old 03-09-2012, 07:43 AM - Thread Starter
chileboy's Avatar
Thanks very much for that, much appreciated - haven't received the service manual yet, I may try and open the thing up anyway this weekend and have a look anyway.
- Mark
chileboy is offline
Reply 2-Channel Audio
