Tubes for EAR 834p - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-05-2012, 07:20 PM - Thread Starter
chileboy's Avatar
I have an EAR 834p phone preamp (with the ""Thorsten modification", if that matters) - I am beginning to experience some distortion which I'm thinking may be associated with a tube beginning to fail. There are three in the unit, all of them 12AX7 (ECC83). I admit knowing very little about the nuts-and-bolts of this.
I have two questions which I was hoping someone could help me with:
1) I know this is subjective, but what would be the "best" tubes to use as replacements, and where to obtain them? The ones that are currently installed are Telefunken ECC83/12AX7. The originals (I believe) which I also have are marked DPF (?) ECC83, two have the marking N8AN8, and one A9AN8.
2) What is a good new or used (via eBay, I suppose) tester for these? I'd be looking for something relatively inexpensive, as I don't currently own any other tube-based components (although I plan to get a couple of amps when I can). Understand too, I am unsure how to interpret the readings, so I will be back to ask about that, as well...
Thanks very much for any input.
- Mark
chileboy is offline
post #2 of 13 Old 03-05-2012, 11:00 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Telefunken 12AX7 ECC83's come in 2 versions smooth and ribbed plate. Smooth is the earlier version. Some of the best tubes ever made that can last you up to 10 yrs. Not cheap they run between $50 to $200 ea for NOS tubes. But w/their long life they should give you years of trouble free operation. Highly sought after just be careful who you buy from as there are alot of knock offs out there.
Class A is offline
post #3 of 13 Old 03-06-2012, 08:44 AM - Thread Starter
chileboy's Avatar
Thanks, Class A - I know the Telefunkens are good but I don't know if my distortion problem is due to one of them - if they generally are good for 10 years, I'm probably at about that, age-wise - but they don't actually have many hours on them, and as I said, I don't have a tube tester.
chileboy is offline
post #4 of 13 Old 03-06-2012, 09:26 AM
rntlee's Avatar
- Mark
Good tube testers are expensive, require periodic calibration, and usually won't test the tubes in the operating conditions they experience in actual use. I thought about buying one of these boutique tube testers a while back, and still may if I can find a used one for sale.
rntlee is offline
post #5 of 13 Old 03-07-2012, 06:24 AM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
alltubetesters.com Good article on a variety of tube testers.
Class A is offline
post #6 of 13 Old 03-07-2012, 06:56 AM - Thread Starter
chileboy's Avatar
Great, thanks - I was looking for a site like that. Much appreciated.
- Mark
chileboy is offline
post #7 of 13 Old 03-07-2012, 10:00 AM
bhaaf's Avatar
This is the tube recommended to me by Kevin at Upscale Audio. Highly recommended for tubes and other components.
http://www.upscaleaudio.com/products...Old-Stock.html
bhaaf is offline
post #8 of 13 Old 03-07-2012, 12:17 PM - Thread Starter
chileboy's Avatar
Thanks for that - link doesn't work for me, but I found the ones you're referring to - $90 apiece, correct?
- Mark
chileboy is offline
post #9 of 13 Old 03-08-2012, 07:04 AM
Maceo23's Avatar
Hey Mark,
Just a word of caution, they say that tubes actually sound their best right before they blow. Just be sure that that is your problem before you spring on a new set.
Maceo23 is offline
post #10 of 13 Old 03-08-2012, 10:13 AM
bhaaf's Avatar
- Mark
Or $100 for Platinum Grade and $8.00 for Cryo if you want.
bhaaf is offline
post #11 of 13 Old 03-09-2012, 07:45 AM - Thread Starter
chileboy's Avatar
Originally Posted by Maceo23 View Post
Hey Mark,
Yeah, I have the originals from the unit - I am going to try swapping them out this weekend and see if there is a difference.
chileboy is offline
post #12 of 13 Old 03-09-2012, 07:46 AM - Thread Starter
chileboy's Avatar
Is the Cryo worth getting?
chileboy is offline
post #13 of 13 Old 03-09-2012, 03:57 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Tubes should be heated in induction oven, rather than cooled in the feezer, to work better.
ap1 is offline
Reply 2-Channel Audio
