2ch reciever/integrated advice for kitchen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-08-2012, 10:09 AM - Thread Starter
porksoda's Avatar
Hiya,
I am putting in two cw180R in the kitchen and need soem advice SQ wise for the receiver/integrated.
I will use appletv or apple airport express as source with optical.
I was going to grab the onkyo 8055 but started to look into used market and found Arcam avr 100 and Nad t76X receivers for decent pricing.
I don't care for bells n whistles as i will have airplay no matter what i get so i am more concerned about audio sq.
Any opinion in arcam vs nad vs onkyo ?
porksoda is offline
post #2 of 13 Old 03-08-2012, 11:57 AM
Nethawk's Avatar
Liked: 119
I have the Onkyo TX-8050, for just over $250 from Amazon, and am quite pleased with it. I can't comment on the other suggestions.
Nethawk is offline
post #3 of 13 Old 03-09-2012, 03:59 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Do you really need a receiver ? There are more choices with better SQ in an integrated amp.
qguy is offline
post #4 of 13 Old 03-10-2012, 07:43 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
For an integrated amplifier, I prefer NAD and Cambridge and Musical Fidelity.
I recently upgraded from a Cambridge 340A to a Musical Fidelity M3i, so I might be able to fix you up with a good deal on a nice 340A.
That might work out for you.
Send a PM if you want details.
Originally Posted by porksoda View Post
Hiya,
commsysman is offline
post #5 of 13 Old 03-17-2012, 06:29 PM
fredgarvin's Avatar
You might want to try out the tiny Dayton DTA 100a. They really sound good and seem a nice choice for a kitchen system. . A T-amp at a nice price, $89.
http://www.parts-express.com/pe/show...=dayton%20100a
fredgarvin is offline
post #6 of 13 Old 03-17-2012, 09:35 PM
walbert's Avatar
Yep - you're spending far too much.
I like this option. There's also a number of stereo receivers in the $100-$300 range that would be perfectly suitable.
Alternately, to the OP - do you have a multi-zone receiver that you can tap into?
walbert is offline
post #7 of 13 Old 03-18-2012, 06:13 AM
Nethawk's Avatar
Liked: 119
More choices in an integrated amp than a receiver? Can I get an explanation please?
Nethawk is offline
post #8 of 13 Old 03-18-2012, 10:38 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Here is another option, too, if it would help to have a smaller footprint: the Emotiva mini-X a-100. No frills. Just a volume control and power switch, but smaller in size than other receivers and integrated amps in this budget range.
UPDATE: Sorry. I forgot you are looking for optical input. While you could certainly use a separate DAC with optical, this would increase the cost dramatically.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #9 of 13 Old 03-18-2012, 11:18 AM
walbert's Avatar
Oh I've got a solution to that!
http://www.amazon.com/FiiO-Digital-A...2094680&sr=8-2
walbert is offline
post #10 of 13 Old 03-22-2012, 10:41 AM - Thread Starter
porksoda's Avatar
thanks for all the input guys. I was leaning towards an arcam used reciever because of optical input... if i can find a good "cheap" used integrated i would for sure do that. Dac would be an issue but i can always add a dac later as well.
I was initially attracted towards denon as it has iOS device control so i can volume up down change source via my phone and not have to go to the device itself (the amp/int/rec would be in the pantry).
porksoda is offline
post #11 of 13 Old 03-23-2012, 04:59 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Hiya,
Waste of money. Integrated amp - waste of money.
A receiver may be a good idea because you never know when you may want to tune something on radio.
An $80 Sherwood receiver will do the job spendidly. Anything more is eye candy.
arnyk is offline
post #12 of 13 Old 03-23-2012, 05:00 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
I have a T-amp that I use from time to time and it doesn't sound bad.
On the test bench, the same $80 invested in a Sherwood stereo receiver gets you a heck of a lot more and measures far better.
arnyk is offline
post #13 of 13 Old 03-26-2012, 08:47 PM - Thread Starter
porksoda's Avatar
That's why i was going the receiver route and or a stereo receiver route. Used market has a lot to offer in the arcam nad ht receiver world.
I will look into sherwood as well, not sure who sells them here in canada.
porksoda is offline
Reply 2-Channel Audio
