Need Advice On A Setup For Trance Music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-08-2012, 05:16 PM - Thread Starter
theaf1don's Avatar
I current'y live in an apartment building so I can't play music too loud. But still want to get the best quality as I listen to music a lot. I listen to mostly trance music and some hip- hop. I stream podcasts and music from my computer to my Apple TV which is connected to my Pioneer 1021 AVR with 2 bookshelf PSB speakers. It's a decent setup but I want to see how I can improve it.
theaf1don is offline
post #2 of 16 Old 03-08-2012, 05:42 PM
zieglj01's Avatar
Quoted: 1672 Post(s)
Liked: 1565
And the budget is?
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #3 of 16 Old 03-08-2012, 06:22 PM - Thread Starter
theaf1don's Avatar
Originally Posted by zieglj01 View Post
And the budget is?
Well the budget really depends on what equipment I need and the type of output I will get from the setup. I was thinking keeping it under $500. Perhaps just replace the bookshelf's? Maybe just get a peach tree nova or decca later on?
post #4 of 16 Old 03-08-2012, 06:47 PM
zieglj01's Avatar
Liked: 1565
What is the model number of the PSB speaker?
Who AM I
post #5 of 16 Old 03-09-2012, 01:26 AM - Thread Starter
theaf1don's Avatar
I have no way of telling. They were a hand me down from a family member. The back of the speakers only has the shop name and a serial number, but no model number anywhere. They are probably around 10 years old.
post #6 of 16 Old 03-09-2012, 07:23 AM
zieglj01's Avatar
Liked: 1565
You may have an old PSB Aplha speaker.
A little over budget - however, I would look at:
Monitor Audio Silver RX-1 speakers
http://www.audioadvisor.com/prodinfo.asp?number=MRSRX1
Or, KEF Q300
http://www.vanns.com/shop/servlet/it..._c=site_search
Some KEF b-stock here
http://www.accessories4less.com/make...rs-pair/1.html
Who AM I
post #7 of 16 Old 03-09-2012, 02:27 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Trance and hip hop.. add a subwoofer. You may not be able to play it loud but you get a fuller sound which wont make you need to crank up the volume.
qguy is offline
post #8 of 16 Old 03-09-2012, 03:20 PM - Thread Starter
theaf1don's Avatar
Thanks, I read that trance doesn't use low bass, that its mostly mid range so a subwoofer won't help too much. But hip hop, on the other hand, has a lot of low db bass so I may need that.
Any suggestions for around $200ish for a sub? Remember I live in an apt so I don't need one thats too crazy.
What about going with a Peachtree tube amp? I think I can connect that to my Apple TV. I'm not sure how it would integrate with the Pioneer 1021 though as it doesn't have any pre-out.
post #9 of 16 Old 03-09-2012, 03:50 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
I have largish bookshelves that has outstanding bass for its class, it has a 7 inch woofer and believe me a sub does wonders for Trance. Trance and hip hop may not have content in the 20-30 hz range, but even a small sub will produce better bass than most small speakers from 35 hz onwards..
http://www.avsforum.com/avs-vb/showthread.php?t=1364182
I would go with adding a sub, first then decide if you still need to upgrade other stuff.. a correctly integrated sub does wonders specially for your type of music.
qguy is offline
post #10 of 16 Old 03-09-2012, 04:11 PM - Thread Starter
theaf1don's Avatar
Thanks! How is the Energy 10.3 Sub? Its on sale on NewEgg right now for $250.
http://www.newegg.com/Product/Produc...82E16882269026
post #11 of 16 Old 03-09-2012, 04:31 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Energy is a reliable brand, but I am not familiar with that particular model. You may want to post your question at the subwoofer forum
qguy is offline
post #12 of 16 Old 03-09-2012, 04:40 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
That would be a good choice. It's an good value at that price for a 10" sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #13 of 16 Old 03-14-2012, 06:06 PM - Thread Starter
theaf1don's Avatar
What do you guys think about getting 2 Klipsch Reference II 82 series floor standing speakers?
MSRP is $600each but I can get them for around $350-400 each. So it would just be 2 of these plus the energy sub I ordered.
post #14 of 16 Old 03-21-2012, 11:28 AM - Thread Starter
theaf1don's Avatar
What do you think about adding a peach tree nova to the system?
post #15 of 16 Old 03-21-2012, 12:10 PM
bukiwhitey's Avatar
If you get the 82's in an apartment, you probably won't need the sub.
bukiwhitey is online now
post #16 of 16 Old 03-21-2012, 01:28 PM - Thread Starter
theaf1don's Avatar
Well, I already have the Energy 10.3 sub which cost me around $200. Are the bookshelf style PSB generally considered decent speakers? Maybe I just stick with them?
Reply 2-Channel Audio
