Onkyo 8050 DAC Question ... Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-24-2012, 01:27 PM - Thread Starter
AdamITR's Avatar
So i'm a bit confused about this receiver. As I understand, I can plug in my iPod/iPhone to the 8050, and it will use the internal DAC, correct?
Question, currently a lot of my songs are in iTunes on my Mac Mini ... and I just run a cable out of the headphone jack that splits to the L/R rca cables ... into the Game input (for example) ... I assume that this is not using the DAC then ... correct? Any clarification or explanations are appreciated.
AdamITR is offline
post #2 of 8 Old 03-24-2012, 02:27 PM
Walk_Good's Avatar
If you use a LOD connection it bypasses the ipods amp but not its DAC. AFAIK the only way to bypass the onboard DAC is to have it imoded. Way too expensive and AFAIK redwine audio doesn't do it to all ipods only some models.
I don't use Mac's but AFAIK it's actually going thru your computers onboard sound card. The only way to bypass it would be to buy an external USB DAC.
Walk_Good is offline
post #3 of 8 Old 03-24-2012, 02:36 PM
Ovation's Avatar
Quoted: 102 Post(s)
Liked: 65
If you want to ensure your iTunes to use the TX-8050's DAC, simply run an optical cable from your Mac Mini's audio output (you'll need a mini-toslink adaptor for the Mac Mini end of things) to your Onkyo. That way, your Onkyo will do the work.
The way you are currently connected means the Onkyo's DAC may be in use or it may not--it depends upon whether you engage DIRECT or PURE AUDIO on the Onkyo. If you use either one, then your Mac Mini's DAC is doing the work. If you do not use either of those settings, then the Onkyo is converting the analogue signal coming from your Mac Mini to digital and back to analogue at the final stage.
If you want to avoid such extra conversions, then use an optical cable like described above. Otherwise, you can leave things as is.
Ovation is offline
post #4 of 8 Old 03-24-2012, 02:39 PM
Ovation's Avatar
Quoted: 102 Post(s)
Liked: 65
The audio out on Macs is both analogue and digital (optical). Using an optical cable with a mini-toslink adaptor will bypass the Mac's DAC without the unnecessary expense of an external DAC.
Ovation is offline
post #5 of 8 Old 03-24-2012, 02:54 PM
Walk_Good's Avatar
Originally Posted by Ovation View Post
The audio out on Macs is both analogue and digital (optical). ...
Thks, good to know even though I don't use a Mac ...
post #6 of 8 Old 03-24-2012, 04:10 PM - Thread Starter
AdamITR's Avatar
Thanks for all the help!!!!!!
AdamITR is offline
post #7 of 8 Old 04-07-2012, 10:04 PM
Justins123's Avatar
My understanding was plugging an iPod/iPhone into the USB port on the front of the 8050 will bypass the iPod's DAC. Is this not the case? The product description of the 8050 on several sites seems to indicate this.
Justins123 is offline
post #8 of 8 Old 04-08-2012, 09:25 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
A USB connection is digital. It has to be bypassing the iPod's DAC.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Reply 2-Channel Audio
