Cambridge, Yamaha and other integrated amps under $400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-25-2012, 01:32 PM - Thread Starter
outlawskinnyd's Avatar
Hey now fellars...
I'm putting together an iPod/phono audio system. I'm looking at Yamaha a-s500bl, Onkyo tx8050, pioneer a35r, can bridge audio azure 550 for my integrated amp.
If anyone has any experience with the above mentioned please let me know. What you like, what you didn't like.
You're not cultured. You're stupid.
outlawskinnyd is offline
post #2 of 8 Old 03-25-2012, 02:37 PM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1329
I set up a Yamaha S500 for my Dad, it was easy and sounded great. Has throw-back capability for tape loops and plenty of inputs. Also has the ability to monitor one input while recording another. That capability can also be used as a "zone-2" output. Plenty of headroom too. I would recommend one without hesitating.
rdgrimes is offline
post #3 of 8 Old 03-25-2012, 04:37 PM - Thread Starter
I'm starting to lean towards Onkyo a5vl. Just wish it had a subwoofer
post #4 of 8 Old 03-25-2012, 09:02 PM
coolsax's Avatar
If you can go another hundred look at the Music Hall A15.2. I really like mine. Has phono in, line in and fixed preout that will allow a subwoofer.
coolsax is offline
post #5 of 8 Old 03-25-2012, 09:05 PM - Thread Starter
I'll check it out.
Do you run a preamp with it? Ive seen some set ups with and without.
post #6 of 8 Old 03-25-2012, 09:21 PM
coolsax's Avatar
No it's an integrated so I just use the internal pre. I'm running a squeezebox touch for most of my music and a cheap technics tt for vinyl. Would like to get a dad at some point though.
coolsax is offline
post #7 of 8 Old 03-26-2012, 10:27 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
The Cambridge Audio amplifier is a better-sounding amplifier than the others from my experience.
I used a Cambridge 340A for a couple of years in one system before upgrading to the Musical Fidelity M3i and it is quite good-sounding. It is like new and can be had for a very reasonable amount.
Send a PM if interested.
Originally Posted by outlawskinnyd View Post
Hey now fellars...
commsysman is offline
post #8 of 8 Old 03-26-2012, 02:54 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Commsysman, if you would like to sell your CA 340A, there is a section on AVS for selling used gear. Please stop spamming threads.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
Reply 2-Channel Audio
