Have a few questions regarding DAC's - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 140 Old 04-17-2012, 07:31 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Really?
Cites?
Brian C.J. Moore, Introduction to the Psychology of Hearing. Final chapter, or appendix, depending on the edition.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #122 of 140 Old 04-17-2012, 07:36 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
From Moore, op. cit., 4th edition:
CD and DAT players generally have a specification which is far better than that of other components in a hi-fi system, especially cassette decks and loudspeakers. Essentially, the output signal which they provide is indistinguishable from that which would be obtained from the master tape produced by the recording studio (studio recordings are now usually digital recordings). Thus, provided a CD or DAT player is working according to specification, it will produce no noticeable degradation in sound quality. It follows from this that most CD players and DAT players sound the same.
The basic performance of even a moderately priced hi-fi amplifier is likely to be so good that improvements in technical specification would make little audible difference. For example, a moderately good amplifier will have a frequency response from 20 to 20,000 Hz +/– 1 dB, distortion less than 1% and a signal-to-noise ratio greater than 90 dB (for input signals with a reasonably high level, such as from a CD player). These values are better than the limits required by the ear.
mcnarus is offline
post #123 of 140 Old 04-17-2012, 07:52 AM
SDL
SDL's Avatar
Originally Posted by mcnarus View Post
Human beings are not calibrated test instruments, not even close. They shouldn't pretend to be.
Now, obviously there are some things that cannot be left entirely to objective measurementsspeaker preferences, room set-up. There you have to trust your ears. But you should also be honest about their limitations.
I agree completely! Human beings are not calibrated test instruments and clearly have personal preferences about music and how they listen to it.
SDL
SDL is offline
post #124 of 140 Old 04-17-2012, 08:02 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Looks like quite a book, if even a bit misnamed due to all of the information about physiology.
It appears that they devote a whole chapter to audio, both the highs and the lows (metaphorically speaking).
arnyk is offline
post #125 of 140 Old 04-17-2012, 08:04 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
However, there is a hard and fast rule - to have a sonic preference, there first has to be reliable sonic detection.
When you're talking speakers and rooms, reliable detection is generally easy to establish. Indeed the one big problem is that audible differences abound to the point of being distractions.
When you are talking amps and DACs, not so much. Usually, not at all.
arnyk is offline
post #126 of 140 Old 04-17-2012, 08:07 AM
SDL
SDL's Avatar
I apologize for taking the DAC discussion off into the blind testing debate. It wasn't my original intent, but that's where a lot of the posters on this thread seemed to want to go.
In regard to that issue, what does everyone think about the comments on this link from a supporter of blind testing who sees both its strengths and limitations? http://trustmeimascientist.com/2012/...stening-blind/
SDL
SDL is offline
post #127 of 140 Old 04-17-2012, 08:20 AM
diomania's Avatar
Liked: 50
SDL
What do you think about this book by Robert Harley? Check out the reviews. http://www.amazon.com/Complete-Guide...owViewpoints=1
diomania is offline
post #128 of 140 Old 04-17-2012, 08:37 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Thanks for the link. It should be noted that the limitations he discusses are not so much limitations of blind tests themselves as legitimate cautions about interpreting the results. (And I suspect he's misinterpreting the results of that hardware vs. software test he cites, though I can't tell for sure because his description of it is too sketchy.)
mcnarus is offline
post #129 of 140 Old 04-17-2012, 08:38 AM
walbert's Avatar
Exactly!
If you can't actually tell A and B apart, you can't like A better than B.
walbert is offline
post #130 of 140 Old 04-17-2012, 08:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
This article is very common sense, and thorough.
The rest of the site, especially some articles by other authors, not so much.
arnyk is offline
post #131 of 140 Old 04-17-2012, 08:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
People I know like to tear it apart.
arnyk is offline
post #132 of 140 Old 04-17-2012, 08:52 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
That doesn't seem to stop a lot of people.
The history of DBTs is that we invented ABX thinking that it would be a good qualification test for some other tests we wanted to do for preference.
Some of us, but not all of us were blown away when all the stuff we wanted to rate by preference turned out to be indistinguishable.
Truth is, there is some stuff that sounds different, but the differences are so small that it seems pointless to even try to form a preference.
Of course you read all of these audiophile sites where everybody seems to think that everything sounds different. As the old saying goes: "Ignorance is bliss", except of course for many of us it isn't.
arnyk is offline
post #133 of 140 Old 04-17-2012, 08:53 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
But you can think you do!
mcnarus is offline
post #134 of 140 Old 04-17-2012, 01:44 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Arny,
I should invoke TOS 8 based on listening tests using a general run of commercial recordings. ;-)
Sorry, I don't know what TOS 8 is. That's why I'm here - In many respects, I'm still an audio newbee. Can you point me?
Here's the reason why - clipping or at least significantly higher distortion just below FS is not that uncommon. However, its relevancy to listening enjoyment is most people's primary concern. . .
. . . But its audible consequences for clipping in the last dB before FS? Not so much!
Ok, I can accept that.
However, in the case I cited, the clipping was serious - far from FS. I wouldn't have tested otherwise, but as soon as I plugged it in, I could hear something was wrong. The audio was seriously distorted. I would have just trashed it, but I bought it to test something else, and had it apart anyway.
Long ago, I generated a bunch of full-scale sine waves in FLAC that I use for testing the hardware that I design. On the scope, the 1kHz wave was clearly flat-topped both top and bottom. Reducing the gain of the output buffer was all it needed.
So maybe the hardware I've been building is not correct? I always leave headroom such that a full-scale signal will never clip, even with worst-case tolerances on the components. Am I being too conservative?
MarkHotchkiss is offline
post #135 of 140 Old 04-18-2012, 12:05 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
Most DACs have a DC offset at ~2.5V so the signal swings 0-5V effectively. If Vcc is 5V which it is in USB, and the buffer has any gain then the signal swing sould easily exceed the voltage rails. Even if it didn't, there are fewer opamps that will actually swing signal rail to rail, typically CMOS units. Most will need a volt or so clearance between signal and rail to not clip.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #136 of 140 Old 04-18-2012, 04:42 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Audio is a lot about quantification - how far below FS was it clipping?
0.1 dB?
1.0 dB?
3 dB?
The differences above can be determined from a sine wave in a glance.
If you would, please PM me the make and model. I might buy one just because its been so long since I saw anything that seriously broken!
Sounds like someone was not on their toes. An overconfident designer? Tolerance build up? This enquiring mind wants to know! ;-)
Not at all. It's just that I've been testing too much good hardware lately - everything seems to be working well.
arnyk is offline
post #137 of 140 Old 04-18-2012, 10:50 PM
Liked: 85
Hi A9X-308,
Exactly right. This was a S/PDIF to analog dongle. The supply was 5 volt, down from a 9 volt AC wall-wart transformer through a bridge and a 7805. Besides the power supply, the only circuitry was an SoC and the output-buffer opamps. I suspect that the opamps were not rail-to-rail.
post #138 of 140 Old 04-18-2012, 11:12 PM
Liked: 85
Hi Arny,
PM sent.
post #139 of 140 Old 04-19-2012, 06:13 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Hi Arny,
PM sent.
Received - awaiting part 2! ;-)
arnyk is offline
post #140 of 140 Old 04-19-2012, 06:14 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Hi A9X-308,
Someone went cheap on the op amp! :-(
arnyk is offline
Reply 2-Channel Audio
