2-channel preamp needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-03-2012, 10:41 AM - Thread Starter
nymartyk's Avatar
Hi. I'm looking for a good, quiet, transparent preamp for 2-channel setup. Source is MacBook Pro > musical Fidelity V-Link > Peachtree Dacit > Margules ADE-24. I want a preamp that has at least 2 preamp outs to drive McCormack amp and a tape out to hook up a headphone amp. For budget I'd like to stay below $500 and I'm willing to buy used. Any recommendations?
Marty
nymartyk is offline
post #2 of 9 Old 04-03-2012, 10:57 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
It is pretty hard to find good preamps used, and that is a pretty low price for anything decent.
One new preamp that is an outstanding value is the Vincent SA-31, which is only $650. It is the best-sounding preamp I know of for under $2000.
Another thing you might consider is buying a Cambridge Audio 550A integrated amplifier, which is now only $399 (was $599), and use it as a preamp. It will do what you want.
Marty
commsysman is offline
post #3 of 9 Old 04-03-2012, 11:49 AM
diomania's Avatar
Liked: 50
Are you trying to shill for some online av retailer? You keep mentioning the models and their prices so I'm wondering...
diomania is offline
post #4 of 9 Old 04-03-2012, 06:44 PM
runnin''s Avatar
Liked: 45
Uh, maybe if he mentioned an online retailer by name? Although I've done that myself on occasion and am only an enthusiast.
I agree that you do not have many options in your budget. The Emotiva USP-1 is an option, also the Parasound 2100 if on sale. Other than that, I'd research some recent models to find some suitable options then see if they pop up on Audiogon.
runnin' is offline
post #5 of 9 Old 04-03-2012, 08:10 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Marty
Since you like Mickie-C in the power section, I'd recommend an RLD-1. I tried one...and even though I've moved way up in price since, I thought it was a helluva unit for the money.
CD
CDLehner is offline
post #6 of 9 Old 04-03-2012, 11:11 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
The Parasound Zpre2 is a quality small form factor preamp. You can get one new within your price range. Otherwise, I would look at used or an integrated amp.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #7 of 9 Old 04-04-2012, 07:07 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Since all inputs are line level, you really don't need a preamp, it would appear that all you really need an input selector switch, a volume control, and perhaps a buffer in a box.
Most preamps with 2 outputs whose circuits I've reviewed simply put the output jacks in parallel, so that need could be satisfied with a pair of Y-cables.
You may find that it is more economical to trade up to a DAC with a volume control.
Hope this helps.
arnyk is offline
post #8 of 9 Old 04-06-2012, 06:14 AM - Thread Starter
nymartyk's Avatar
Thanks. Are you recommending passive preamp or something more like NHT PC which is basically a single input/output with a volume control?
As to full preamps, appreciate the recommendations. Would you get a new Emotiva USP-1 or a used Acurus or Rotel, etc. ? In looking at bottom tier high end brand preamps that are 20 years old going for $400 - $600 on eBay and wondering if they could really be that much better than the Emotiva.
nymartyk is offline
post #9 of 9 Old 04-06-2012, 07:23 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Passive controllers, of which I own including 2 NHT PVCs plus at least one home made unit with two inputs and two volume controls, a number are special purpose devices. If you have a basically solid state system, and cable lengths are under a couple of meters, they can work.
I already own a number of legacy tubed and SS preamps including a CJ, a Dyna, and a Holman, so I'm not going to be buying any more soon!
The Emotiva USP-1 preamp might fit your needs.
As far as legacy preamps, I see a number of Adcom, NAD, Rotel, etc. items that I might find attractive for under about $200.
arnyk is offline
Reply 2-Channel Audio
