NEed circuit pinout on Logitech x-220. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-07-2012, 04:33 AM - Thread Starter
c0reyl's Avatar
I got this for free because the circuit was damaged as in the wires were pulled out like that. I need to figure out where what wires go to that number related to color of wire to number of pin.
I plan on making this into a portable audio solution, powered by an APC battery possibly, which can easily be regarched with my car battery charger. it will last HOURS, and it can probably be used while charging as well.
c0reyl is offline
post #2 of 4 Old 04-07-2012, 02:46 PM
walbert's Avatar
That 9-pin setup goes through the DIN connector back into another unit, right? Can you just open the other unit up and see how it's wired on the other side?
Otherwise, I'd probably not spend too much time on this - you can purchase a comparable 2.1 multimedia set for $20-$30 most days from most places.
walbert is offline
post #3 of 4 Old 05-03-2013, 04:39 PM
Giovani Chaves's Avatar
I'm having some noise when adjusting the volume so I need to replace the trimpot, but I can't figure out how to disassemble the speakers.
Could you give me a hint on how open it?
Giovani Chaves is offline
post #4 of 4 Old 05-16-2014, 02:08 PM
mik052's Avatar
The wire pattern is
pin 1-Yellow
pin 2-Red
pin 3-Blue
pin 4-no connection
pin 5-glossy black
pin 6-brown
pin 7-violet
pin 8-grey
pin 9-matte black
The green wire in your picture is not connected to anything
mik052 is offline
Reply 2-Channel Audio
