2.0 reciever vs a 5.1 reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 04-07-2012, 01:22 PM - Thread Starter
EagleDon's Avatar
This maybe a old question. I am thinking about upgraging my living room LR bookshelf speakers to towers. and move those bookshelf speakers to my bedroom. In my bedroom I have a Sat receiver, dvd player, and may add a CD player. I really don't won't a full blown 5.1 system in the bedroom. I will be satified with a 2.0 HT system . Should I go with a 2.0 receiver? Is there a problem with using an inexpensive 5.1 receiver? What's the pros and cons of both?
EagleDon is offline
post #2 of 18 Old 04-07-2012, 01:34 PM - Thread Starter
EagleDon's Avatar
This was probably not the right forum to post this question
EagleDon is offline
post #3 of 18 Old 04-07-2012, 01:34 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3000
The stereo receivers won't have HDMI connections if you need that. Some models don't even have optical connections. But you will get more amplifier for your money over an equivalent priced AVR.
If you are happy with just having analog (RCA) connections, the HK 3390 is a good price. For a little more, you can get the Onkyo TX-8050. It does have optical and some other extra features.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 18 Old 04-07-2012, 01:49 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
There's no problem with an AVR. The advantage of using an AVR in a 2.0 system would be the extra features you might get. Digital connections are one, although some 2-channel gear is coming equipped with at least optical (not HDMI that I've seen). Room correction, in your better AVRs, but that may have limited value in a 2.0 system.
Just use the DVD player for CDs.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 18 Old 04-07-2012, 01:55 PM
walbert's Avatar
Given what you're hooking up, a stereo receiver is probably the most cost effective option - there's a number of models under $200 that would be perfectly suited here. A 5.1 AV receiver will have more features, but also cost more - some of those features may be useful to you, but it's really a matter of how much you want to spend. If you're going to break the $300 barrier I would get a 5.1 AVR, otherwise, grab a stereo unit with a remote and be happy.
walbert is offline
post #6 of 18 Old 04-07-2012, 02:20 PM
gregzoll's Avatar
Liked: 33
For CD playback, use the dvd player.
gregzoll is offline
post #7 of 18 Old 04-07-2012, 02:23 PM
zieglj01's Avatar
Quoted: 1422 Post(s)
Liked: 1261
A refurbish Denon 1612, will take care of business.
http://www.accessories4less.com/make...eceiver/1.html
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Harman Kardon Ten > Boston VS240 -- Receiver > Integra 50.2
zieglj01 is online now
post #8 of 18 Old 04-07-2012, 02:32 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
so would a refurb 1611...a tad cheaper too.
id get either over a sub $200 sony or sherwood 2 channel receiver. way better feature set, future expandability possibilities, plenty of digi connections and room correction (if desired).
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #9 of 18 Old 04-08-2012, 06:02 AM - Thread Starter
EagleDon's Avatar
You guys right about the CD player. Thanks
EagleDon is offline
post #10 of 18 Old 04-08-2012, 03:12 PM
JohnyBGood's Avatar
Of the few stereo receives I've priced at online stores I've noticed that on their product page they list "No" for DTS, Dolby 5.1, TrueAudio, etc. However, 5.1/7.1 stereo receivers list "Yes" for all those modes and offer phantom modes for 2.0 home theatre setups and more digital inputs. Do phantom modes, which can potentially offer enhanced dialogue and enhanced surround effects make 5.1/7.1 receivers a better option for 2.0 setups (setting aside the fact that you're initially paying more for extra amplification to channels that will never be used)? Also, will receivers conserve energy on channels not used in a 2.0 setup, or are you automatically going to use more power running a 2.0 setup with a 5.1/7.1 receiver vs a stereo receiver?
(I'm not very knowledgeable about audio equipment, so I'm excited to learn. Is there a section where I can ask a bunch of dumb questions without being attacked for not using the search button?)
JohnyBGood is offline
post #11 of 18 Old 04-08-2012, 03:29 PM
walbert's Avatar
Stereo receivers don't have decoders for multi-channel formats (although I think a few of them have Dolby Virtual Surround), but that doesn't matter because generally speaking your player equipment will have those multi-channel decoders. For example, a DVD player has a stereo output, so there's your decoder. The receiver is then just providing "everything else" (volume control, amplification, etc).
Power consumption is tricky - with modern AVRs most of your power demand is from the DSPs until you push them to insane output levels (many modern AVRs will "idle" at 100W or more), while most stereo receivers are "dumb" by comparison, and all you're providing for is the amplifier's needs and whatever basic microcontroller runs the device (things like the remote control receiver). Older AVRs can actually be fairly good power consumption wise (close enough to a stereo receiver to not really worry about it, relative to the extra features); I'm not sure where the very cheapest but very modern AVRs fit in (I would say as they increase in DSP features and similar, they will increase power demand). Anyways, at most we're talking around 100W (even for normal-ish output levels, at least in stereo), which is not extreme (and it's not like you intend to run the thing 24x7, right?).
A lot of the power consumption stuff is based on measurements of my own equipment and other forum posts.
walbert is offline
post #12 of 18 Old 04-09-2012, 11:38 AM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
A DVD or BD player tends to take quite a bit longer (several seconds) to detect and start playing a CD than does a dedicated CD player. Also, very few DVD or BD players can decode CD Text to display the artist and track title information for CDs which have that info.
Selden
Selden Ball is offline
post #13 of 18 Old 04-09-2012, 05:34 PM
tlalotoani's Avatar
Quoted: 20 Post(s)
Liked: 37
I had measured the power consumption of a Denon AVR-391 in 5.1 and 2.1 modes, there is no norticeable difference between both configurations, in idle the AVR´s consumption is around the 40W, and dependig on the volume and the type of music you play it increases, I must say that this AVR has a 200 (and something) watts peak consumption, but to get to that consumption must be with the AVR almost burning, because with the music LOUD the power consumption reaches 65-70 Watts, I believe that a 2.0 channel mus have a lower power consumption.
tlalotoani is offline
post #14 of 18 Old 04-09-2012, 05:41 PM
gregzoll's Avatar
Liked: 33
Actually not. Our Sony BDP-S370 starts right up when you put in the CD, with no delay. It takes no longer to start playing a CD or SACD, than playing on a conventional CD player.
gregzoll is offline
post #15 of 18 Old 04-10-2012, 02:32 AM
Liked: 1637
That's good to know. My understanding is that most brands of BD players take a while to determine the disc type.
It depends on the design of the analog amplifier circuitry. Class A amplifiers draw the same amount of power at all times, whether or not they're actually amplifying a signal. See http://en.wikipedia.org/wiki/Electro...lifier_classes
Selden
post #16 of 18 Old 04-10-2012, 03:40 AM
mphfrom77's Avatar
Quoted: 476 Post(s)
Liked: 344
It sounds like to me you may be the perfect candidate for a craigslist avr. I bet you could get a nice one for $100 or less to satisfy your needs. I guess that doesn't answer your question though.
Btw, I use my bluray player for CDs and can't stand it. I need to figure out what I want to do about them.
mphfrom77 is offline
post #17 of 18 Old 04-10-2012, 01:29 PM
walbert's Avatar
From what I've seen and heard, it varies (wildly sometimes) from player to player. Some of the oldest and most expensive Blu-ray players are just drudgingly slow (for anything), but many modern units are as quick as a DVD player. For reference, old CD players aren't usually the quickest to load a disc either.
walbert is offline
post #18 of 18 Old 04-10-2012, 04:47 PM
SuperToMMo's Avatar
If 2 or 2.1 channel is the end of the road for your rigs in a particular set up. You could benefit from an integrated amp with external dac connected to your player. Since most of the players if not all can be set to send pcm out on their digital ports. Amp with pre or sub out will prove convenient if you are planning to add a subwoofer to your system.
SuperToMMo is offline
Reply 2-Channel Audio
