Quality RCA chassis sockets - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-11-2012, 09:36 AM - Thread Starter
Cyclone82's Avatar
I am trying to find some good quality gold RCA chassis mount sockets. 2 Years ago i found a website that had a range of different styles of sockets and i seem to remember some matt gold ones. The site was a manufacturers site so a brand name maker of these sorts of sockets. I know i was looking at these Neutrik brand ones, but i am sure i was on another site too and they had a few sifferent style/grades of what i guess were 'audiophile grade' sockets. I can no longer find that site, i just dont know the brand name. I am pretty sure it was in Europe but i am not 100% sure of it.
Can you guys maybe fire off some brand names other than Neutrik?
Cyclone82 is offline
post #2 of 9 Old 04-11-2012, 09:58 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
There's nothing wrong with Neutrik, they make great stuff. Paying more will not get you better sound quality, if that's what you were thinking.
--Ethan
Ethan Winer is offline
post #3 of 9 Old 04-11-2012, 10:23 AM - Thread Starter
Cyclone82's Avatar
Well i reckon it may have been these
http://audio-cmc.com/rca-jacks-c.html
I know i was looking at these connectors somewhere.
Not saying Neutrik are bad or anything though. There are fakes out there though. See their website.
Anyway i think i am getting on the right track now that i found these CMC type, but i am sure there was some euro website i visted once. More after the looks/good construction than anything else.
post #4 of 9 Old 04-11-2012, 12:00 PM
ccotenj's Avatar
Liked: 101
wonder if the op is thinking of "wbt"...
spending any more than what the neutriks cost isn't necessary...
- chris
ccotenj is offline
post #5 of 9 Old 04-11-2012, 12:37 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
I exclusively use the Philmore brand RCA jacks. They are good quality gold and can be easily isolated from the chassis with the hardware provided. They cost about $4.50 each retail.
In any case I would not spend more than that. I agree with Ethan in that all RCA connectors will sound the same. Even the classic crappy aluminum Switchcraft. The difference is in mechanical quality and service life.
In a couple of recent projects I used those multi RCA jack strips like you find on mid-fi gear.They are gold plated, not that great mechanically, but OK. I mostly make PC boards and these jack units are perfect for that. Here:
http://www.allelectronics.com/make-a...A-JACKS/1.html
Glimmie is offline
post #6 of 9 Old 04-12-2012, 07:48 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
Just so they are gold-plated, which prevents them from oxidizing.
Always be careful that the RCA plugs fit very tightly, to prevent poor grounding; amplifiers have been known to go into ultrasonic oscillation and be damaged because of poor grounding by cable plugs.
commsysman is online now
post #7 of 9 Old 04-12-2012, 09:06 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Like so many things, Gold all by itself is no assurance of absence of future oxidation.
Gold is soft and gets scraped off when the connector is used repeatedly. In the world of pro audio, gold connectors reminds many of amateurs, or other reasons for occasional use.
What's under the gold is very important. Often its Nickel, which is good.
Of course this begs the question of why not save some bucks and use just Nickel or other harder corrosion resistant metal in the first place. Chrome is as corrosion resistant and even harder...
arnyk is offline
post #8 of 9 Old 04-12-2012, 09:10 AM
SAM64's Avatar
Liked: 78
Do you really think these cadmium chromate dipped, nickel connectors are actually plated with gold?
SAM64 is offline
post #9 of 9 Old 04-22-2012, 10:36 AM
Tisbury Audio's Avatar
It wasn't HiFi Collective, was it? They're UK based and have a great selection, albeit rather expensive.
hificollective.co.uk/components/rca_sockets.html
Tisbury Audio is offline
Reply 2-Channel Audio
