Looking for new pre-amp to replace C-5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-19-2012, 08:25 PM - Thread Starter
shimonmor's Avatar
The amp is a Carver TFM-45 with a couple of DT BP-10s and a DT sub. The only source I have is an Oppo-93.
One feature I would like to have (and I'm not sure if it's even available) is to have a switched outlet on the back of the preamp which can handle the amp. The amp switch doesn't work on a remote and the C-5 can't handle the amp on its outlets so I always need to manually switch the amp on and off. Everything else works with my Harmony One remote except for the amp.
I don't think it needs any digital inputs since the analog outputs on the Oppo seem to be working great (love that Oppo).
-Shimon
shimonmor is online now
post #2 of 8 Old 04-20-2012, 10:15 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
Unfortunately, the preamps for under $2000 are few, and most are not very good. Parasound has a couple that are under $1000, but I wouldn't recommend them to anyone.
The one that is pretty good for less than $1000 is the Vincent SA-31, which I think goes for $650. I think you are stuck with manual operation on the power amplifier, though, because the current surge at turn-on would be too much for a switched outlet on a preamp, even if it had one. I have the same problem with my Bryston amplifier.
Another possibility would be to find a good used integrated amplifier that has preamp outputs and use it as a preamp. A Cambridge 550A or 650A can be used that way, or a NAD325 or 326.
Originally Posted by shimonmor View Post
My Carver C-5 pre-amp (bought in 1992) is dying. When raising/lowering the volume knob, I get loud, annoying crackling sounds. Also, the power switch is broken (remote works ok). I would like to find a replacement but am out of touch as to what is decent (don't want to bother with repairs). Looking for something under $500. Used is an option too if there is a good model out there.
commsysman is offline
post #3 of 8 Old 04-20-2012, 11:04 AM
diomania's Avatar
Liked: 50
Likely the contact point in volume potentiometer is dirty. It will take opening up the chassis but couple shots of electronics contact cleaning spray will solve that. A few $ solution.
Having someone to replace the switch and clean the volume pot is a lot less than $500.
diomania is offline
post #4 of 8 Old 04-20-2012, 11:53 AM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1330
All Carver components are usually repairable for a flat rate fee at one of the shops in Washington state. I think that's your best option, and cheapest.
I'd suggest going to the source: http://www.ritasvintageaudio.com/
360-568-4700 The flat rate should be $270.
If you're willing to wait for it, you can usually get the unit autographed by the man himself.
Send the TFM-45 in too, it's due for a re-cap and tune up.
Resist the temptation for something newer, what you have is great and you'd just miss that sound.
rdgrimes is offline
post #5 of 8 Old 04-20-2012, 03:45 PM
A9X-308's Avatar
Quoted: 1293 Post(s)
Liked: 956
Ditto.
A9X-308 is offline
post #6 of 8 Old 04-20-2012, 08:13 PM - Thread Starter
shimonmor's Avatar
Thank you to all who replied!
Well, it seems that my best option is to have my C-5 repaired. Especially since it's only located about 1 hour away. I think I will take both the C-5 and the TFM-45 in and have them gone through and brought up to spec. Those two units have served me well for 20 years and I do like them so I guess I will treat them right and give 'em a "tune-up" and repairs.
Thanks, rdgrimes, for posting that link to the service facility. I will call them on Monday and see about dropping off both units soon.
As for turning on the amp with a remote...I'm sure there is a device out there that the amp can plug into and has a remote receiver. I think I'll post that question in the Harmony One thread and see if anyone has some ideas.
Thank again to all who took the time to provide sound advice.
-Shimon
post #7 of 8 Old 04-20-2012, 09:17 PM
rdgrimes's Avatar
Liked: 1330
As for turning on the amp with a remote...I'm sure there is a device out there that the amp can plug into and has a remote receiver. .
Consider a simple power strip with "master" and "slave" sockets. When the master turns on the slave(s) are powered on. Just be sure it has adequate load ratings.
rdgrimes is offline
post #8 of 8 Old 04-21-2012, 05:27 PM - Thread Starter
shimonmor's Avatar
Good suggestion. Thanks. I was only able to find this one: http://www.amazon.com/Smart-Energy-S...cmu_pg__header
Are there other the products that are of higher quality? This one looks like it is a cheap, Chinese product (what isn't, these days?).
-Shimon
Reply 2-Channel Audio
