new turntable and subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 04-20-2012, 02:38 PM - Thread Starter
benclement11's Avatar
Hi hooked up my project debut III, Rolls VP-29 phono pre-amp into my stereo. MY subwoofer doesn't seem to be behaving the same way as if I were playing cd or MP3. It moves a lot, but does not seem to be putting out much sound. Any idea what the problem may be?
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #2 of 21 Old 04-20-2012, 03:06 PM
A9X-308's Avatar
Quoted: 1288 Post(s)
Liked: 954
Record warps, arm/cart resonance maybe.
A9X-308 is offline
post #3 of 21 Old 04-20-2012, 03:27 PM - Thread Starter
it's a brand new record. I was wonderring if it had something to do with my connections. I have RCA running from Audio 1 on my receiver into out of pre-amp and the record player runs into the in of the phono preamp.
post #4 of 21 Old 04-20-2012, 03:28 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Well, a vinyl recording doesn't necessarily have the same range as digital...do the rest of the frequencies sound fine to you?
lovinthehd is offline
post #5 of 21 Old 04-20-2012, 03:35 PM - Thread Starter
the speakers sound great, but the subwoofer looked like it was working really hard. I have the record on vinyl and cd. The CD does not behave the same way.
post #6 of 21 Old 04-20-2012, 03:43 PM
A9X-308's Avatar
Liked: 954
Then it is a mechanical issue, and I gave the two most obvious candidates. New does not mean flat (even in the 70's when I started with vinyl) and due to the nature of the RIAA curve, if there is no LF roll off incorporated subsonic LF will be of high amplitude and cause the visible sub pumping.
A9X-308 is offline
post #7 of 21 Old 04-20-2012, 03:48 PM - Thread Starter
and the correction when playing these records would be...? Turn the bass down? I did this...way more than I normally would. The sub kept pmping really fast and faintly sound like a helicopter. So I turned it off, thinking I may damage it.
post #8 of 21 Old 04-20-2012, 04:03 PM
A9X-308's Avatar
Liked: 954
Any or all of the following:
turn off the sub, LF filtering, ensuring arm mass/cart compliance are appropriate, record clamp to flatten warps some.
If it's a ported sub, then the lack of cone control below tuning could be a major contributor to the sub pumping as even a good arm/cart match would have a resonance below almost every ported sub, except maybe a few LLTs.
LPs are not ipods, they don't plug and play. Subs were almost non existent when LPs were in their heyday, so ULF issues were very rare.
A9X-308 is offline
post #9 of 21 Old 04-20-2012, 04:08 PM
Webomatic's Avatar
I'm thinking that this is in the right ballpark. I could also be a misaligned cart, or cart counter-weight may not be set properly.
Webomatic is offline
post #10 of 21 Old 04-20-2012, 04:13 PM - Thread Starter
It it a ported sub tuned at 19 hz I believe. The record is Sublime Acoustic so I wouldn't think any content would be below tuning. What do you mean by resonance? I have the Debut III with Ortofon 2M Red cartridge. I'm going to try some different records and report back.
post #11 of 21 Old 04-20-2012, 04:16 PM
A9X-308's Avatar
Liked: 954
My first thought was this, but even with a great combination, any arm/cart resonance is going to be below the tuning of almost every ported sub and going to give one an excursion apoplexy with little effort.
I agree with this too, and was going to amend the previous post to include this possibility when I saw your post.
It's very hard to diagnose and correct electromechanical issues from a distance, especially with the dearth of knowledge of set up details that I see in 'new' vinyl users.
A9X-308 is offline
post #12 of 21 Old 04-20-2012, 04:17 PM - Thread Starter
Same thing...I play Paul Simon slip sliding away...very little bass and it does the same thing.
So I think your assertion is right. I called Needle Doctor and they basically said the same thing, but explained in a way I could understand(my 1st dive into vinyl). They think the cartridge is picking up the vibrations from the sub and creating a mechanical problem. They recommend that I separate the turntable and subwoofer. I don't have a lot of room right now so I may just listen to records with the sub turned off. It's not a deal killer, if I want big bass I can always listen to CD's. I just wanted to know why it wasn't working. Thanks for your help.
post #13 of 21 Old 04-20-2012, 04:27 PM
Webomatic's Avatar
I was looking at the specs of your phono pre and 35db gain seems a little low. Plus, it doesnt appear to have load capacity swithes either. Your TT is recommended to have 200-600 pF on the load capacity of the phono stage.
Maybe upgrade your phono stage. That's where the rubber hits the road.
post #14 of 21 Old 04-20-2012, 05:19 PM - Thread Starter
what does sensitivity gain mean? Sorry for my ignorance. This is a "budget" phono preamp I was recommended for my starter system. But, it would be nice to know what to look for in a phono stage. In the future I want a tube preamp...something like this. What shoudl I be looking for in the specs?
http://www.needledoctor.com/Bellari-...category=35249
post #15 of 21 Old 04-20-2012, 05:59 PM
Webomatic's Avatar
Depending on the output of the cart you may need more or less gain. Your cart is 4.0mv so it's ideal gain would likely be closer to 40db.
Here is a decent solution for you at $199 from Project
http://www.needledoctor.com/Pro-Ject...category=35249
post #16 of 21 Old 04-20-2012, 07:53 PM - Thread Starter
Well actually I upgraded the cartridge to the Ortofon 2M Red...this is 5.5 mV. So ideally it would be outputting 55db? What do I get if I match the specs or by using the phono stage I have now what am I missing in the music?
post #17 of 21 Old 04-21-2012, 04:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Subs and vinyl don't go together so well, because vinyl playback necessarily introduces a lot of subsonic and low bass disturbances. Most vinyl is produced through high pass filters so the lowest bass is either not there or in mono or both.
Better shock mounting of the TT (put the TT on a garden walkway slab sitting on an inflated bicycle tube) might help.
arnyk is offline
post #18 of 21 Old 04-23-2012, 08:52 AM
Rutgar's Avatar
As several have suggested, it sounds like you may need to add a subsonic filter. Years ago I purchased a pair Nakamichi SF-10 in-line passive filters, which worked really well. I don't believe the SF-10's are still available, and are rare due to being often sought after. However, I believe there are new alternatives available from many of the turntable specialists.
Rutgar is offline
post #19 of 21 Old 05-01-2012, 08:22 PM - Thread Starter
Thanks for the suggestions everyone. For now I turn the sub off when I listen to vinyl, which is fine. If I feel the need to thump I'll play cd's. Eventually when I move it to my basement I will probably take your advice.
post #20 of 21 Old 05-02-2012, 06:47 AM
Swampfox's Avatar
+1
Subs and vinyl are a bad mix. You can actually introduce mechanical positive feedback because of sensitivity to mechanical vibrations. Remember a vinyl system turns mechanical vibrations into electrical output into sound energy.
Swampfox is offline
post #21 of 21 Old 05-02-2012, 07:00 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
If you are using a sub, subsonic filter in phono preamp is a must. Turntable often produce a lot of very low frequency noise - down to 10 Hz or less. You do not want ot to reach your sub.
ap1 is offline
Reply 2-Channel Audio
