Bedroom system 2.1-channel integrated/receiver recs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-21-2012, 08:23 AM - Thread Starter
Quoted: 919 Post(s)
Liked: 491
I'm looking for a new electronics box for my bedroom, to insert between
two sources (~90% of the time an streaming from an Apple AirPort Express, ~10% of the time spinning black circles on a B&O RX-2 TT)
and a small 2.1 channel speaker system (KEF Q100 mains, DIY sub with a Peerless XLS12, Peerless XLS12 passive radiator, and 500W Oaudio plate amp).
Requirements:
-Attractive construction, with minimalist appearance (a bare minimum of bright lights) and preferably more metal than plastic (will be exposed in a bedroom with decent furnishings)
-Remote control of power/volume/source select
-Three-figure price tag. The lower the better.
-At least 17dBW (50W) of clean power; I'm currently using a KEF Picoforte iPod dock that puts out about 10dBW, and it audibly clips at rousing levels. My Audiolab 8000A has adequate power, but no remote).
-Not from Denon/Marantz: their after-sales support is abysmal, so I'm not interested in providing them further business. McIntosh's support is separate, and...who wouldn't mind Mac gear?
-Subwoofer preout (preferred) or at least preout/main-in loops (after volume control, so a tape monitor won't work)
-No garish logos
-Electrical safety certification from an OSHA-approved NRTL (UL, ETL, CSA, etc.).
Would be nice
-Compact
-Optical digital input OR MM phono stage (can use separate small phono pre)
-An alarm clock function would be kind of cool.
-Room correction
Not opposed to used. Don't care about tubes/SS/Class D as long as it fits my functional, aesthetic, and price requirements, though all else equal a more energy efficient unit would be preferable.
Any recs?
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #2 of 15 Old 04-21-2012, 09:13 AM
commsysman's Avatar
Quoted: 983 Post(s)
Liked: 526
The Musical Fidelity V-LPS is one of the best phono preamps for under $300, and it is compact and affordable.
The Cambridge Audio 651A is $800 and should do the job.
Another possibility is the NAD 356BEE, and one of those is available used if you check the classifieds.
Requirements:
-Not from Denon/Marantz (their after-sales support is abysmal, so I'm not interested in providing them further business. McIntosh's support is separate, and...who wouldn't mind Mac gear?
-No garish logos.
Would be nice
-Compact
-Room correction
Any recs?
commsysman is offline
post #3 of 15 Old 04-21-2012, 10:38 AM - Thread Starter
Quoted: 919 Post(s)
Liked: 491
Please see edits.
$800 for a conventional-sized audio box?
Not for me.
If I'm going to spend that much and not get something in a more bedroom-friendly form factor, I'll go with the currently-on-closeout Sherwood-Newcastle R-972, or even add a third Anthem MRX 300 to my flat...
Serious Audio Blog
DS-21 is offline
post #4 of 15 Old 04-21-2012, 11:28 AM
postrokfan's Avatar
Quoted: 521 Post(s)
Liked: 3111
How about the Vincent SV-400. It's a bit pricey at $499 but it does most of you want minus having a phono stage.
50 W
Pre-out for subwoofer
remote control
onboard USB DAC
Another option would be the Music Hall A15.2. 75W, no DAC, MM phono stage...Also $499.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #5 of 15 Old 04-21-2012, 02:35 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Not compact, but the HK 3490 does most of what you want. Tons of power. Optical and coxial inputs. Subwoofer out (although no bass management or room correction). There is a dimmer function to make the display less bright or all the way off (dims everything but the power button light).
If you would like a 2 channel receiver with bass management (not compact though), check out the Outlaw RR2150. It has analog crossover switch on the back. That's nice for a turntable since most other receivers have to convert analog signals to digital and then back again to analog for their bass management.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #6 of 15 Old 04-21-2012, 05:14 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
I wouldn't buy that NAD 356BEE. I've heard from a reliable poster that it doesn't sound good at all!
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #7 of 15 Old 04-22-2012, 08:45 AM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15824
fwiw take a look at the teac a-h01 it has pretty much what you need for $599 its compact ,50 watts clean power,sub pre out,well built ,dac built in and optical dig.input and remote
i'm so laid back,i'm laid out
smasher50 is online now
post #8 of 15 Old 04-22-2012, 12:05 PM - Thread Starter
Quoted: 919 Post(s)
Liked: 491
That's the kind of thing I was looking for but didn't know enough to find.
Except...it looks like that 50W rating is at 4Ω (oddly, it's rated 22W/8Ω). I assume it uses either the Icepower 50ASX2, or the precedessor model.
So it's not much, if any, more power than the KEF Picoforte dock I'm using now (rated 25W/8Ω).
Doh.
Serious Audio Blog
DS-21 is offline
post #9 of 15 Old 04-22-2012, 07:33 PM
lurking2's Avatar
Would Rega fit the bill (used?)
app.audiogon.com/listings/rega-brio-r-integrated-amplifier (cute and just hits 50W) but it misses the preout.
lurking2 is offline
post #10 of 15 Old 04-23-2012, 12:52 PM - Thread Starter
Quoted: 919 Post(s)
Liked: 491
Sigh. Unfortunately no, because that's the kind of aesthetic I was looking for.
But the preout is required (the plate amp on my sub doesn't have high-level input), as is electrical safety certification from an OSHA-approved NRTL, which Rega seemed too cheap to acquire.
Serious Audio Blog
DS-21 is offline
post #11 of 15 Old 04-23-2012, 02:09 PM
cel4145's Avatar
Liked: 2991
I think you have a hard set of criteria to satisfy
NAD - C-326BEE? Typical rack width, but low profile in height and lacking in annoying digital display. Does have the NAD logo and model# on it.
post #12 of 15 Old 04-23-2012, 02:20 PM
Selden Ball's Avatar
Quoted: 3091 Post(s)
Liked: 1509
Well, there's the Marantz NR1402, although it has more of the HT receiver aesthetic than you seem to want.
http://us.marantz.com/us/products/pa...oductid=nr1402
Selden
Selden Ball is offline
post #13 of 15 Old 04-23-2012, 02:23 PM
cel4145's Avatar
Liked: 2991
Also this Rotel RA-1520 currently on sale at Audiogon.
post #14 of 15 Old 04-23-2012, 06:47 PM
lurking2's Avatar
Arcam is another option. Not as nice looking as the Rega. Here's one from ebay.
www .ebay.com/itm/Arcam-FMJ-A18-Integrated-Amplifier-BLACK-/370604842513?pt=LH_DefaultDomain_0&hash=item5649c51e11
And a slightly cheaper one on Audiogon. Both have preouts
app .audiogon.com/listings/arcam-a70-intergrated-amp
Modify the links so they work
lurking2 is offline
post #15 of 15 Old 05-02-2012, 03:59 PM - Thread Starter
Quoted: 919 Post(s)
Liked: 491
FWIW, I ended up picking up a used Meridian 551 integrated amp and a Monoprice HDMI -> component video and stereo audio DAC to connect the AppleTV2 I shifted from the living room to the bedroom. (I bought an ATV3 for the living room to replace it.) It's is attractively designed, and reasonably compact at about 13" x 13" x 3.5".
I would have gotten a Peachtree Audio Nova. It's expensive, but I like the way it looks and had a small separate phono preamp I could've used. And, being a long-time Atlantan, I also like the brand name. Had Peachtree been civilized enough to acquire electrical safety certification from an OSHA-approved NRTL, I would've picked one up. But the lack of proper safety certification makes me wonder where else corners were cut.
The 551's not perfect. While it has a phono preamp built-in, it lacks bass management or even preout/main-in loop to allow me to highpass-filter the mains via the sub's plate amp. But I quickly learned that the product I want - a compact and attractive integrated amp or receiver a remote control, and ideally a phono preamp, at least one digital preamp, and some form of bass management - simply doesn't exist.
I'm a little surprised that the "high end" industry has come up so short in this market. Many "budget" integrates out there (Music Hall, Cambridge, NAD etc.) are simply too large. Except for Luddites and retro fetishists, why would anyone willing to use a box that big go for something so obviously inferior in functionality and (due to the lack of room correction) sonics to, say, an Anthem MRX 300 receiver? On the same speakers, ARC and good bass management will invariably lead to superior sonics over a more primitive device.
Add that to the fact that most of the so-called high enders are too cheap/lazy/classless to get the proper NRTL electrical safety certifications - NAD is, here, a notable exception - and no wonder why none of them can offer a satisfying product. They don't understand what "premium" means, any more, except for "high priced."
Serious Audio Blog
DS-21 is offline
Reply 2-Channel Audio
