Receiver matching B&W 684 Fronts - AVS Forum | Home Theater Discussions And Reviews
Old 04-26-2012, 11:36 AM - Thread Starter
cybose's Avatar
Hi,
I have a Yamaha RX-V671 amp
( products/audio-visual/av-receivers-amps/rx/rx-v671_black_u/ )
Rated Output Power (1kHz, 1ch driven) 125W (8ohms, 0.9% THD)
Rated Output Power (1kHz, 2ch driven) 105W (8ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven) 90W (8ohms, 0.09% THD)
Dynamic Power per Channel (8/6/4/2 ohms) 130/170/200/240W
Matched with a B&W 684.
(Speakers/Home_Audio/600_Series/684.html)
Nominal impedance 8Ω (minimum 3.0Ω)
Recommended amplifier power 25W - 150W into 8Ω on unclipped programme
If I don't drive the amp to about 75% of it's max volume, it sounds 'mushy' and flat. I'm not talking about bass either;not expecting much from the 684s.('Not loud enough'. This being my first hifi setup, not sure how to explain this). These are the only speakers hooked up to the amp. Bi-amping does not help much.
The question is, are the speakers and the amp, fundamentally mismatched ? Or is it some setting on the amp that needs to be tweaked ? Or is this typical for this setup ?
cybose is offline
Old 04-26-2012, 12:46 PM
DJ Superstylin's Avatar
To be honest, the 684's if I remember correctly are the smaller brother to the 685's and they are nowhere near as open as the other B&W's.
If possible, I'd suggest swapping them back for the 685's (I own these). The 684's are best as surrounds.
However, if this is not an option, on your reciever, turn it off from the main button, hold "Tone Control" and hit the Main Zone button to go into the advanced menu. Here you can select "Impedance" and set it to 8. Also if you want, enable "Bi-Wire" and bi wire your speakers. This made my 685's way more open and defined.
Try EQ'ing them with a boosted midrange if possible.
DJ Superstylin is offline
Old 04-26-2012, 02:16 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Not sure what the problem is, but "matching" is definitely not the culprit. (Nor will biwiring solve anything, except in your head.)
Pull out your receiver manual and check that all your settings are appropriate. Have you used the room correction on the Yamaha? Also, try tweaking the tone controls.
Absent that, I'd say you aren't very happy with your speakers.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Old 04-26-2012, 04:48 PM
I agree totally.
Owning a Yamaha V563, these amps when biwired do sound better because it uses a whole different internal amp (the one for the surrounds) to drive the speaker. So it is bi-amped in a very loose sense and I have noticed a stark difference with my B&W's when I did. However this should not be the reason your speakers sound bad.
McNarus, I used to work at Best Buy in HT, and I know for a fact those 684's sound very underwhelming. They have a phenomenal tweeter but that midrange driver is too small. It's really intended to be a rear speaker. I ended up pulling the gun on the 685's for that reason.
I hate to say it but every speaker company makes a speaker that kinda shoots itself in the foot and the 684 regrettably is that speaker.
Old 04-26-2012, 07:59 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
Originally Posted by DJ Superstylin View Post
I agree totally.
I believe you are mistaking the 684 for the 686,
which is a smaller bookshelf than the 685.
The 684 is a floorstanding speaker.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
Old 04-26-2012, 08:54 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
684 are not very good speakers. In 68x line you should either take 685 (but you need a sub along with them) or 683. Almost any receiver will be able to work with 685. But for 683 you need really powerful amplifier. Which means either top of the line receiver, or separate power amplifier with at least 250w of power at 8 ohm.
ap1 is offline
Old 04-26-2012, 10:07 PM
I have shamed myself as a B&W enthusiast...
The floorstanders LOVE a solid amplifier behind them. While they are at an 8 ohm impedance, I did find that the models I tested back at Magnolia sounded the best matched with either a Marantz or the 1xxx line of Yamaha's.
There is no reason those speakers should sound muddy; even despite not having the FST.
Try giving them an EQ adjust if possible.
Old 04-26-2012, 10:54 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
It might have something to do with what PEQ, parametric EQ, setting you have selected. Have you performed the speaker calibration?
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
Old 04-27-2012, 07:50 AM
ccotenj's Avatar
Liked: 101
you aren't helping the "reputation" of bb/magnolia employees any...
- chris
ccotenj is offline
Old 04-27-2012, 08:09 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
There is nothing wrong with your receiver. I have listened to those speakers, and if I was making a list of floorstanding speakers in the $1000 price range, I would put them dead last on the list. They would sound the way you describe with any amplifier.
If you want some really really nice-sounding floorstanding speakers in that price range, these are the ones that sound the best to me:
1) PSB Image T6
2) PSB Image T5
3) KEF Q500
4) Monitor Audio Bronze BX-6
Any of those speakers will sound far far better than what you have IMO.
I don't know of any way to make your current speakers sound decent; sorry.
One point; despite their labeling, the impedance of the 684 is quite low at many frequencies and they should be treated as a 4 ohm speaker.
commsysman is offline
Old 04-28-2012, 04:49 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
Not sure what happened to the OP but I don't think negative comments on the OP's choice of speakers are helpful. He must have liked the sound of the 684s or the purchase wouldn't have been made.
I used a Yamaha receiver with my pair of 685s at one time and noticed the same things and changing the EQ helped a bit.
Old 04-28-2012, 05:00 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by cybose View Post
Hi,
With just 1 6.5" woofer your speakers are not exactly dynamic range champions.
Probable cause of mushy sound is overpowering the small woofer.
One word: subwoofer.
arnyk is offline
Old 08-06-2012, 01:07 AM
honeymonster's Avatar
It may be worth experimenting with room positioning of your speakers, siting them away from walls and corners - also, if possible experiment with the speakers firing down to opposite side of the room, as the room acoustics may be better one way than the other. I have heard B&W 684 loudspeakers and they can sound great when set up optimally.smile.gif
honeymonster is offline
Old 08-06-2012, 10:57 AM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
This!!!
I had similar feelings about my B&W 604's for the longest time. I upgraded receivers from a Yamaha HTR-6090 to an HK AVR 3600, and although there was a fairly significant improvement (probably the EZset/EQ vs. the YPAO of that time) I was still not happy with the sound of my speakers. It wasn't until I set up my speakers following "The Golden Ratio" that my speakers really came alive. Also, you need to carefully select your listening position to avoid peaks and nulls in your room. A key rule of thumb for listening position is to avoid sitting in the middle of the room for all dimensions, L/W/H. I believe I read that 2/3 the length, or width is a good place.
Tweaked05 is offline
