What to do with CD Changer faulty in Bose Lifestyle system? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-04-2012, 06:10 AM - Thread Starter
houselizard's Avatar
Hi,
I have a Bose Lifestyle system for a number of years and recently, the CD changer is having a problem and it's beyond repair. May I know how can I use the rest of the system,ie. amp/base and 2 speakers, without using the CD Changer? As the CD changer connects the amp/base to the speakers, how I can use another alternate component to replace this changer?
Should I discard the amp/base instead?
Tks!
houselizard is offline
post #2 of 8 Old 05-04-2012, 07:06 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Originally Posted by houselizard View Post
Hi,
Other than aesthetics, what keeps you from plugging in another media player?
The amp and speakers of a Bose integrated system are generally highly optimized for each other. The amp/base and the speakers should not be separated.
arnyk is offline
post #3 of 8 Old 05-04-2012, 08:53 AM - Thread Starter
Yes, the amp and speakers were great but they are linked up by a CD changer which is not working now. The speaker zone is connected from the CD changer to the amp and amp to speaker. I don't intend to get another Bose CD Changer because it's expensive.
Is there any way to use any CD player but have a connector that suits Bose?
post #4 of 8 Old 05-04-2012, 08:57 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
All the information available to me suggests that the line in or aux in connectors on Bose systems are standard RCA connectors that consumer audio gear uses.
arnyk is offline
post #5 of 8 Old 05-05-2012, 06:59 AM
commsysman's Avatar
Quoted: 1079 Post(s)
Liked: 567
If you have an input available with RCA jacks, which I think you do, any CD player can be plugged in there.
The TEAC PDD-2610 is a 5-disc changer that is only $105 on Amazon.
commsysman is offline
post #6 of 8 Old 04-30-2013, 11:24 AM
SMITHWHO's Avatar
ON THE BACK OF BOSE LIFESTYLE 20 YOU WILL FIND RCA PLUGS FOR CD ON ANY AUDIO INPUT
SELECT THE INPUT TO ACCEP THIS INPUT
SINCERLY J.R. SMITH
OR USE VIDIO INPUT FOR MONO INPUT
SMITHWHO is offline
post #7 of 8 Old 04-30-2013, 03:47 PM
Ratman's Avatar
Quoted: 1434 Post(s)
Liked: 1146
SINCERLY J.R. SMITH
One year later? AND ALL CAPS??rolleyes.gif???
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #8 of 8 Old 04-30-2013, 08:07 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
And suggesting he use the video input for mono audio???
WilliamZX11 is offline
Reply 2-Channel Audio
