Computer 2.1 advice needed-my head hurts! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-04-2012, 03:36 PM - Thread Starter
hal26's Avatar
Quoted: 13 Post(s)
...from trying to figure it all out. I have 2 6 ohm midsize bookshelf speakers on my desk and an 8 inch powered sub on the floor. I have a large setup elsewhere in my home for serious listening. I just want to listen to music while surfing the internet from one of the internet music services,Slacker,Pandora,etc. Whichever has the best quality sound. No other sources whatsoever,that is it. I would like a stereo receiver that has a dedicated subwoofer output. I would prefer a 2.1 receiver BUT..it seems as if all the latest and greatest inputs are available only with a 5.1 AV unit. EDIT:here is some more info I found out about my computer:On the rear of the chassis, Dell provides four more USB ports. The machine also offers 5.1-channel surround sound, a gigabit ethernet port, a VGA port, and an HDMI port. The absence of a DVI port is slightly disappointing; users who lack HDMI support on their displays will have to settle for VGA.
I have read everything I can find about this subject and frankly I am so bogged down that I can not pull the trigger on anything. I just want to do it right if I'm going to do it at all. I like the Nuforce products but they are not recommended for 6 ohm speakers. My computer has an HDMI connection but I am not sure if this is an input or output. No optical in or out. The sound card is ATI High Def Audio Device (?) in a Dell Inspiron 580 desktop that is approx. 2 years old. Should I just buy a nice $300 5.1 receiver that has basically every type of input and then get a nice sound card to link it up to....OR.... Keep searching for a 2.1 that has it all? Thanks for any help!
hal26 is offline
post #2 of 9 Old 05-04-2012, 06:52 PM
hedrick's Avatar
I'm currently using a Macbook Pro to a NAD integrated amp and a pair of LDS L500 speakers. I recently found that the built-in sound jack was at least as good as a good external DAC. My impression is that DACs these days are pretty much cookie cutter. The chip in your PC or sound card is probably good enough for the speakers you're going to be using. Also, many subs are designed to be used with normal 2.0 amps, and can do the necessary crossover themselves.
Given the current pricing, you may find it cost-effective just to get a 5.1 receiver. But if you really want stereo equipment you may find a simple 2.0 integrated amp is good enough for your application.
hedrick is offline
post #3 of 9 Old 05-04-2012, 08:27 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Harman Audio is selling their 3390 stereo receiver for $199 shipped on ebay. Not a bad price IMO. I've been using one in the bedroom for a couple of years now - works fine and sounds great. You can take the L/R out jacks from the computer and connect directly to the 3390. Set the computers audio to stereo. The 3390 has two subwoofer out jacks - they are full range so you'll need to control the high pass frequency on the sub. With 80wpc it should make those bookshelf speakers sing.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #4 of 9 Old 05-04-2012, 09:38 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
+1
Great receiver.
I have the HK 3390 hooked up to my PC. Using a Asus Xonar D1 card add on sound card, I felt the HK 3390 with the Xonar running analog out sounded slightly better to me than an HK 1600 A/V using the optical out from my computer. So I kept the 3390 and returned the 1600 because of the extra wattage.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #5 of 9 Old 05-05-2012, 12:13 AM
Hamilcar Barca's Avatar
That makes it easier.
It's an output. Your computer is an "HDMI Source."
An AVR is a big piece of equipment that uses electricity. Otherwise, sure. It'll
do what you're asking.
For your stated requirements, if you go that route, the minimum is an HDMI
output on your computer -- which you've got -- and one HDMI input on the
AVR. And speakers or headphones.
A "nice sound card" might give you a better digital-to-analog converter
(DAC), something unimportant unless you go the 2.1 route. Would your new
card have a better DAC than your new AVR? If not, you didn't need the sound
card.
For audio streaming, video streaming, DVD- and BluRay-playback, etc., you
don't need anything other than the HDMI connection on your computer, a
receiver, and your speakers.
Is the purchase, and installation, of an entry-level AVR reasonable? Do you
want to keep your speakers? Are there some 2.1 systems you've got your
ear on? What's your budget?
I don't have the space and don't want to run an AVR at my desk. That's the
only reason I run powered speakers (not that I don't like them.)
Hamilcar Barca is offline
post #6 of 9 Old 05-05-2012, 03:27 PM
Quoted: 385 Post(s)
Liked: 332
Not all HDMI outputs from a computer have audio output in that signal. They will all output a video signal. Check your computer documentation. The easiest way to get sound from your computer to an AVR if your computer doesn't have HDMI audio is via optical/coax connections.
***GO SEAHAWKS ***
post #7 of 9 Old 05-06-2012, 05:27 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
That is definitely true for computers and video cards that are a few years old. The last year or so everything new I've seen in the way of both computers with on board video and PCI-E video cards has done it right - provided both audio and video on the HDMI output.
It is a good thing to look out for, but if your hardware is reasonably new, you will find what you want. If you don't, even the < $30 video cards you buy now with HDMI outputs do it right. It's not a difficult or expensive upgrade.
arnyk is offline
post #8 of 9 Old 05-07-2012, 05:47 AM - Thread Starter
hal26's Avatar
Quoted: 13 Post(s)
Thanks everyone for your very kind help! I will keep you advised....OP
hal26 is offline
post #9 of 9 Old 05-07-2012, 06:02 AM
mpenton's Avatar
Perhaps something like this will make the task easier.
http://www.behringer.com/EN/Products/UCA202.aspx
USB to audio (analog & spdif) and you don't have to open your computer.
mpenton is offline
Reply 2-Channel Audio
