External Sound for Panasonic TC-L37E5 TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-07-2012, 04:21 PM - Thread Starter
noobtuber's Avatar
I'm looking to set up stereo audio to complement my new TV. I recently moved to an apartment and bought a small HDTV for the living room. This panny TC-L37E5 has marginal speakers built in so I want to give it some more range. I'm using a pair of old Wharfdale 70s as a tv stand and would like to drive them with a simple stereo amp. Problem is the tv only has optical audio out, PCM/Dolby Digital depending on the input. Right now I have the tv hooked up to the internet and rabbit ears for OTA TV and Netflix instant movies. I'll probably add a BluRay player soon.
Since it's an apartment, a good home theater sound system is out of the question. Headphones or the Wharfdales at a low volume are about it. So far the best I can see is an old stereo amp from Craigslist along with a toslink to RCA decoder. It appears a simple convertor won't cut it with this particular tv.
Is this the way to go for what I'm trying to do? Should I be looking for a used AV receiver that has optical in and stereo out? I'm concerned with the decoding and conversion when the tv puts out Dolby Digital. And what will happen when the BluRay player can send 9.1 4D Surround? Will the tv convert it to conventional Dolby Digital?
-RC
noobtuber is offline
post #2 of 6 Old 05-08-2012, 09:37 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Wow; Wharfdale Model 70s! I bought a set of those in 1968 to use with my Harmon-Kardon A500 tube integrated amp. That's going back some. The big walnut cabinets are nice.
The only thing that sounds practical to me is to get an HT receiver and feed the optical audio out to it and use it to drive the Wharfdales. I suggest the Denon AVR-1612, which you can get for $225 on Amazon. It will do what you want, and will make it simple to go to a 5.1 system anytime in the future, if that becomes an option.
-RC
commsysman is offline
post #3 of 6 Old 05-09-2012, 05:08 PM - Thread Starter
noobtuber's Avatar
The Denon looks like it will fit the bill. First I need to have a look at the Wharfedales. My son pointed out the tweeters crackle. My hearing is no longer in that range unfortunately.
post #4 of 6 Old 05-14-2012, 01:09 PM
commsysman's Avatar
Liked: 569
Oak Tree Enterprises says they have replacement tweeters for the W70, but I would try replacing the capacitors in series with the tweeters first; that might fix it.
post #5 of 6 Old 06-18-2012, 08:25 AM
AVfile's Avatar
Quoted: 285 Post(s)
Liked: 138
Get a Yamaha sound bar.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #6 of 6 Old 06-18-2012, 01:38 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
http://www.amazon.com/Gefen-GTV-DD-2-AA-Digital-Audio-Decoder/dp/B0021QBIBQ/ref=pd_sim_e_5
This DAC will convert DD or PCM optical digital to L/R analog stereo. About eighty bucks.
domino92024 is offline
Reply 2-Channel Audio
Panasonic Viera Tc L37e5 37 Inch 1080p Full Hd Ips Led Lcd Tv
