Integrated Amp vs Stereo Receiver with sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-13-2012, 12:14 AM - Thread Starter
Jobie111's Avatar
Hey Everyone,
I need some help on deciding on an upgrade for my current set up with a budget at $600 for a new receiver/integrated amp. The inputs would be a record player, and a desktop PC for digital music and games. Bookshelf speakers will be paired with the receiver/amp.
Now, I had thought I would order the Marantz PM6004. However, I noticed that it does not have a sub output. While I don't require a sub for music, I do want one for gaming. I am fully aware that I can connect a sub through the high-level speaker inputs/outputs, however I have read contradicting statements on whether or not I will get the best sound and bass out of that setup. Any integrated amp with sub output that I have found is out of my price range.
So what I am wondering, is if I will be perfectly fine using the high level inputs/outputs, or if I would be better off getting a quality 2-channel receiver like the HK 3490 or Marantz SR4023 for my needs. Thanks all for any help given, I appreciate it.
Jobie111 is offline
post #2 of 14 Old 05-13-2012, 04:28 AM
glangford's Avatar
Quoted: 198 Post(s)
Liked: 170
The outlaw ausio stereo reciever is highly thought of, although its a little more costly than the HK 3490. It's here. It has base management. Another option is just to use two channels of an avr. Then you can use audyssey to help blend the sub to the mains.
glangford is online now
post #3 of 14 Old 05-13-2012, 08:10 AM
Flt Simulation's Avatar
How about the Onkyo "TX-8050 NETWORK STEREO RECIEVER"
It's a dedicated 2-channel reciever. And it does have pre-outs ... to include a sub pre-out.
Works with your WiFi modem too for streaming music via the internet or listening to songs stored on your home computer.
Also has a USB input on the front panel.
Supported Files: MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, LPCM audio
Music Streaming: Pandora, Rhapsody, Slacker, Sirius-XM, vTuner, LastFM, Napster, Aupeo
Can be had for $349
http://www.amazon.com/Onkyo-TX-8050-.../dp/B004UR486G
Onkyo's web page + specs:
http://www.onkyousa.com/model.cfm?m=...s=Receiver&p=i
Features Video: http://www.onkyousa.com/Video/TX-8050.swf
BTW ... An integrated amp is a good way to go, but if you want to stream music or play music files you have on your computer, you will also need to buy something like a Squeezebox ... With this Onkyo 2-channel reciever, you don't need to buy a Squeezebox too.
Flt Simulation is offline
post #4 of 14 Old 05-13-2012, 08:13 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
There is no problem using the high-level inputs to the subwoofer (from the speaker terminals). As a matter of fact, there are some who claim this is a better method, since the characteristics of the amplifier are passed through to the sub that way.
There are also many integrated amplifiers that have preamp outputs which can be used to go to the sub (but not the 6004). The Cambridge Audio 550A might be a good one to look at.
Originally Posted by Jobie111 View Post
Hey Everyone,
commsysman is offline
post #5 of 14 Old 05-13-2012, 03:34 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Interesting. I agree with the idea that that using the speaker-level input terminals will pass the characteristics of the amp to the sub, but that strikes me as a good reason to avoid them.
Agreed.
arnyk is offline
post #6 of 14 Old 05-13-2012, 07:28 PM
Just remember that the OP has a budget of no more than 600 bucks!
post #7 of 14 Old 05-13-2012, 08:48 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 333
Either the HK 3490 or Onkyo 8050 will do what you want to do. I'm not that familiar with the 8050 but I'm familiar with the 3490 - I have a 3390 and had a 3480 prior. Connect the sub to sub out 2 and your main speakers to #1 and you can turn input to the sub on and off by remote. And who cares if the sub gets a full signal while gaming? Gaming isn't a critical listening session is it?
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #8 of 14 Old 05-13-2012, 11:04 PM - Thread Starter
Jobie111's Avatar
Hey all, thanks for all the responses. I appreciate all the willing help.
That looks like a great choice, but is unfortunately just a bit out of my price range. I definitely could just use an AVR, I just feel like I would be paying for a bunch of stuff that I would not be using and might sacrifice some sound quality in the process.
Can be had for $349
I had seen that one, but like I said above I am afraid I would be paying for a bunch of things I don't need. I should have been more clear before, the PC will be directly connected to the Amp/Receiver via a DAC, so I won't be needing a squeezebox or network capable receiver.
So you would say that using the high level inputs wouldn't really be a problem for games? Like I said, for music I don't care as my music isn't at all bass heavy. I had seen the Cambridge Audio 650 but unfortunately it was out of my price range. I can't seem to find the 550 anywhere. Do you know of any retailers that have it in stock?
Indeed!
Agreed.
So you guys would say that I would be better off just getting a stereo receiver that has sub out? The reason I was thinking integrated amp was because I was of the understanding they tended to sound better because they focus on the sound and that alone. I agree that gaming is not a critical listening session. I am wondering however, about getting the most out of the sub during gaming. I had read many contradicting things about using high level connections and losing some of the bass during home theater applications.
If I were to go the 2 channel receiver route, would the Onkyo but just as good sound wise compared to the Marantz or the HK? I currently have a Pioneer VSX - 1021 in my living room that I have been happy with and had an Onkyo before that, so I am familiar with those. I have not however, ever heard a Marantz or HK receiver.
Jobie111 is offline
post #9 of 14 Old 05-14-2012, 05:28 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Since the market for receivers is far larger than the one for integrated amps, you probably have more options in that market segment. Since receivers are made in far larger numbers, you generally get better price/performance there.
Unfortunately, that's outdated thinking.
I think that stereo receivers as compared to multichannel AVRs makes the bass management much more reliable for games.
In your application, yes.
arnyk is offline
post #10 of 14 Old 05-14-2012, 07:36 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Except you probably aren't paying any more than you would for something less feature-laden. The makers of mass-market receivers enjoy massive economies of scale compared to the makers of integrated amps, which have a much narrower market. So all those features really come for free. If you don't want them, you don't have to use them. You aren't sacrificing anything.
There's no evidence that they actually do sound better than receivers, however. Remember, the receiver companies can buy the same quality for less.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #11 of 14 Old 05-14-2012, 08:14 AM
Nethawk's Avatar
Liked: 118
The TX-8050 is reasonably priced (I think I paid $260?) so it's additional features aren't costing you much.
I have a similar setup - computer directly connected to the 8050 (without the DAC), so I didn't need the network features either, but the convenience can't be denied. I use Onkyo's android app to control the player and another to control foobar2000 from anywhere in the house. Additionally with the built in Onkyo streaming services I can see what's playing, skip tracks, like etc. without having to walk to my computer. It's really changed the way I listen to music, and I listen much more often.
I don't need a sub, can't help you there but I can't imagine any problems.
Nethawk is offline
post #12 of 14 Old 05-16-2012, 02:28 PM - Thread Starter
Jobie111's Avatar
Hey Guys,
I just wanted to thank you for pointing me in the right direction. Amazon had great open box prices on both the Marantz SR4023 stereo receiver and the Onkyo 8050. So with what I was planning on spending for an integrated amp ($600), I was able to buy both! I put the Marantz where I was planning on originally and am going to start a bedroom setup with the Onkyo since it is perfect with its networking capabilities. So thanks much for the excellent advice.
Jobie111 is offline
post #13 of 14 Old 11-02-2012, 03:36 PM
HAmmer32261's Avatar
Will media servers like media monkey stream to that onkyo receiver?
John
HAmmer32261 is offline
post #14 of 14 Old 11-02-2012, 04:40 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
I think so. But best place to ask questions about media streaming is in the networking and media server forum on AVS.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply 2-Channel Audio
