I dont want to use a receiver with my turn table - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 05-13-2012, 05:04 AM - Thread Starter
TroyHR's Avatar
Space is limited and I dont want to use a bulky receiver hooked up to my turn table..! Is there another option to listen to records with out it ?
TroyHR is offline
post #2 of 17 Old 05-13-2012, 06:44 AM
smasher50's Avatar
Quoted: 376 Post(s)
Liked: 18526
fwiw, parts express has the art dj pre2 phono pre amp for $48and add a lepai tripath amp for $25 and your set to go. small enough to hide behind turntable with enough power and very good sound also parts express has no questions asked 45 day returnand if product is defective they will send you new one no cost to you. imo for their prices i think these are two of the industries best componets to come out in a long time you'll be very suprised with their sound . better than some $300 and higher receivers and amps that i haved owned. just my 2 cents
i'm so laid back,i'm laid out
smasher50 is online now
post #3 of 17 Old 05-13-2012, 06:49 AM
Ratman's Avatar
Quoted: 1459 Post(s)
Liked: 1158
... and a set of speakers.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #4 of 17 Old 05-13-2012, 06:55 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
The Rega Brio R is an excellent compact integrated amplifier (less than 9 inches wide) with a built-in high quality phono stage. That should do what you want and give great sound quality.
commsysman is offline
post #5 of 17 Old 05-13-2012, 09:11 AM - Thread Starter
TroyHR's Avatar
Finally, Thankyou, I've scoured the web for answers like those...
TroyHR is offline
post #6 of 17 Old 05-13-2012, 07:55 PM
Knucklehead90's Avatar
Quoted: 495 Post(s)
Liked: 423
+1 for the Lepai tri-amp. Great sounding amp. I'm pleasantly surprised each time I go out to the garage and turn it on. It is amazing what technology is giving us - and for so little money.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #7 of 17 Old 05-23-2012, 02:32 PM - Thread Starter
TroyHR's Avatar
Rega Brio R would be the only component I need...?
TroyHR is offline
post #8 of 17 Old 05-23-2012, 02:51 PM
Bryceo's Avatar
I know every one else gave you advice but active speakers
Bryceo is offline
post #9 of 17 Old 05-23-2012, 05:17 PM
matteos's Avatar
Can you not just put the amp underneath the turntable?
matteos is offline
post #10 of 17 Old 05-23-2012, 06:45 PM
ccotenj's Avatar
Liked: 101
sure, if you want to bake the turntable...
- chris
ccotenj is offline
post #11 of 17 Old 05-23-2012, 07:04 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
I suspect you're more likely to damage the amp first.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #12 of 17 Old 05-23-2012, 07:12 PM
ccotenj's Avatar
Liked: 101
yea, fair enough point...
- chris
ccotenj is offline
post #13 of 17 Old 05-23-2012, 07:36 PM
Ysay's Avatar
You might as well just use an iPod and a dock
Ysay is offline
post #14 of 17 Old 05-24-2012, 09:30 AM
AudioSerf's Avatar
AudioSerf is offline
post #15 of 17 Old 05-26-2012, 07:04 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Its never been a problem. Right now I have a Marantz 15S1 TT sitting on top of a HK 3390 receiver. They never even come close to hot. About 2" of air in between and completely open all around.
Now if it was an Onkyo AVR, that might be a different thing.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #16 of 17 Old 05-29-2012, 03:55 PM
Barnfry's Avatar
Hi Troy -
Yes, the Brio R would be all you need (apart from the turntable and speakers, but you already knew that).
The Brio R is a great sounding amp (I have the pleasure of getting paid to say that) but if your primary concern is size, you might want to look at the Pro-Ject mini components, which are even smaller.
Best regards
Barnaby Fry
The Sound Organisation
Barnfry is offline
post #17 of 17 Old 05-30-2012, 05:34 AM
Stutz320's Avatar
Stutz320 is offline
Reply 2-Channel Audio
