Integrated Amplifier with 2 Optical Inputs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-20-2012, 10:23 AM - Thread Starter
AdamITR's Avatar
I'm looking for an Integrated Amplifier that has 2 optical inputs. Any suggestions? Budget = $500.
My latest setup:
NAD TT - RCA Input
Apple TV - Optical Audio Input
Mac Mini/iTunes - Optical Audio Input
Onkyo CD Player - RCA Input
I never use a Standard Radio Tuner ... so it's not really necessary. I would be powering Smaller Advents/Klipsch SW-110 sub.
I have been using a Onkyo 8050 receiver (it works fine) ... but *might* consider making an upgrade.
AdamITR is offline
post #2 of 7 Old 05-21-2012, 06:07 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
My latest setup:
NAD TT - RCA Input
You've got some options besides an amp with two optical inputs.
If the amp has a coax (RCA jack) digital input, then optical-to-coax converters are bit-perfect and reasonably inexpensive.
There are also such things as optical switches that let you run two different optical sources into the same optical input without cable swapping.
arnyk is offline
post #3 of 7 Old 05-21-2012, 07:15 AM
underminded999's Avatar
Quoted: 29 Post(s)
...Apple TV - Optical Audio Input
Mac Mini/iTunes - Optical Audio Input...
Why do you still need the ATV, if you have the Mac Mini?
underminded999 is offline
post #4 of 7 Old 05-21-2012, 08:59 AM - Thread Starter
AdamITR's Avatar
I use the Mac Mini on my desk for normal computer use (Photoshop, etc.) with a computer monitor ... and also use it for iTunes ... The Apple TV for an occasional movie. Am I doing this wrong??
AdamITR is offline
post #5 of 7 Old 05-21-2012, 09:05 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
The Onkyo TX-8050 has pre-out and main in. If you would simply like more amplifier power, you could add a power amp.
If you are looking for better SQ, then sell your speakers or sub and upgrade to get the most for your money. For example, a good sealed sub like the SVS SB12-NSD would be an upgrade over the Klipsch SW-110. What model Advents do you have?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #6 of 7 Old 05-21-2012, 09:34 AM - Thread Starter
AdamITR's Avatar
I have the "Smaller Advents" ...
Info here:
http://www.stereophile.com/historical/506advent/
Interesting idea regarding a power amp, never thought of that.
AdamITR is offline
post #7 of 7 Old 05-21-2012, 10:13 AM
cel4145's Avatar
Liked: 2985
Info here:
You might ask on the AVS speaker forum if $500 would get you a significant upgrade in SQ over the Advents. (I don't know. )
Looks like from this page that the sensitivity is fairly low. Upgrading those speakers to a more sensitive rating of 89 or 90db would give you a little more volume without upgrading the amp. For instance, if you upgraded your amp to get double the power, you get 3db more SPL.
Maybe you can find a used one on Audiogon or Craigslist.
cel4145 is offline
Reply 2-Channel Audio
