Best way to switch sources? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-23-2012, 06:24 AM - Thread Starter
drjaymez's Avatar
I basically need a speaker level switch.
I dont have front channel preamp outs on the receiver, so an auto switching power amp for the front L and R wouldn't work.
Thinking about getting a 4pdt switch and wiring it into a wall plate. Not pretty but functional if i can figure out how to wire it. I have a long history of borking switch wiring.
Thoughts?
Stereo gear
6300 turntable
Philips dvd player as cd source
Yaqin ms-12b tube preamp
GAS son of ampzilla
HT gear
Tivo, blu ray, wdtv
Yamaha rx-v467
Stereo Speakers are
BIC DV62si
Center channel is a Mirage omnisat v2cc
drjaymez is offline
post #2 of 6 Old 05-23-2012, 07:12 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Search for OSD ATM-7 speaker selector. I use one to switch between tube and solid state amps. It comes with its own remote (or you can program universal one). This is the best device for your purpose.
ap1 is offline
post #3 of 6 Old 05-23-2012, 07:18 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Thoughts?
Stereo gear
6300 turntable
GAS son of ampzilla
HT gear
Tivo, blu ray, wdtv
Yamaha rx-v467
Stereo Speakers are
BIC DV62si
Here is something similar that may be prettier:
http://www.amazon.com/OEM-Systems-IW.../dp/B0002J1YEU
Tons of alternatives - google is you friend!
Thing is, as long as it is you doing the wiring, you can screw it up no matter what you buy. ;-)
arnyk is offline
post #4 of 6 Old 05-23-2012, 12:54 PM
Dave1027's Avatar
Quoted: 12 Post(s)
Stereo gear
6300 turntable
GAS son of ampzilla
HT gear
Tivo, blu ray, wdtv
Yamaha rx-v467
Stereo Speakers are
BIC DV62si
OT but hey Drjaymez, we have the same amp and speakers. Never thought I'd see that.
Would something like this work? switch box
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
post #5 of 6 Old 05-24-2012, 12:34 AM
Drew Eckhardt's Avatar
You can use a speaker to line level converter. It takes less than $1 (assuming you use 1% resistors) worth of resistors per side and if soldering isn't your thing you can buy ready-made units for the car audio market.
drjaymez likes this.
Drew Eckhardt is offline
post #6 of 6 Old 11-20-2012, 06:27 PM - Thread Starter
drjaymez's Avatar
To answer those curious and for posterity, I went with a Niles SPK-1 that I picked up cheap on eBay. It automatically switches sources when I fire up my stereo amp. I just finally wired everything up today and so far so good.
drjaymez is offline
Reply 2-Channel Audio
