switching to integrated stereo amp instead of marantz receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 94 Old 05-31-2012, 07:08 PM - Thread Starter
tostaylo's Avatar
Hi all,
Right now I have a Marantz SR6006 AV receiver but Ive decided I mainly want something for 2 channel stereo. How much would I have to spend to make a significant improvement in sound quality over the Marantz?
tostaylo is offline
post #2 of 94 Old 05-31-2012, 07:21 PM - Thread Starter
tostaylo's Avatar
Im thinking the Anthem Integrated 225 would be better but havent heard. Reviews are rockin on it though.
tostaylo is offline
post #3 of 94 Old 05-31-2012, 07:23 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
What are your speakers? How big is your room? How loud do you typically listen?
Unless you have speakers that are an especially tough load, or you have a really large room and/or listen to loud levels and need more power, then you actually might take a step backwards in sound quality by switching to an integrated amp. Your AVR has MultEQ XT, so it has some advantages over integrated amps.
It's most likely you would get bigger improvements in sound by spending on other things (speakers, placement, room treatments(?), etc..).
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #4 of 94 Old 05-31-2012, 07:24 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Reviews are always rockin on high-priced gear, aren't they?
beaveav is offline
post #5 of 94 Old 05-31-2012, 07:37 PM - Thread Starter
tostaylo's Avatar
thats an interesting perspective about the receiver.
I have the Monitor Audio BX 2's but looking to get some floor standers. probably the MA RX6 since I do like the MA sound. Placement and room treatment are pretty much set in stone but the room is 20x20. I like to listen to vinyl loud but still able to have a conversation comfortably. I tried the audyssey on the receiver but did not really like the results with 2.1 setup. Now i think i enjoy just 2 channel and no sub.
tostaylo is offline
post #6 of 94 Old 05-31-2012, 08:04 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Ah, that's right - a fellow Monitor Audio owner. I remember you from the MA owner's thread, I think. I have the RX6s myself in a 2.0 setup.
I like buying used gear and trying it out/playing around with it, just for the fun of it. I've tried three integrated amps, two separates setups (separate preamp and amp), and a couple of AVRs. At reasonable listening levels, all of them sounded the same to me. My room is 13x17 and I never crank it up loud. I've just recently started playing with Audyssey MultEQ XT. My first impressions are that it cleans up the bass nicely if I don't have the speakers positioned well (like against a wall or something). But with a 2.0 setup with good positioning of the speakers, its effects are more subtle.
I think you'll like the RX6s, but I don't think you'll find much difference in sound quality going from the AVR to an integrated amp. If, for reasons of simplicity or convenience, you want an integrated amp with a turntable input, then I can understand that. But I wouldn't put much $$ or effort into finding an integrated amp if it's improved sound quality that you're after.
beaveav is offline
post #7 of 94 Old 05-31-2012, 08:20 PM - Thread Starter
tostaylo's Avatar
good post beavav. those RX6's are definitely my priority I think. Im going this weekend to compare the BX2's, RX2's, and RX6's. From what Ive heard from others I think that the RX6's will suit me just fine.
Good info on the integrated amp. I think the best bang for my buck on better vinyl playback may just be a new tt. I use the Marantz's phono stage and a pro-ject debut iii. Last weekend I tested a Clearaudio concept alongside another debut 3. The difference was pretty impressive with the Clearaudio. Although i don't know if it is $1500 more impressive. ha.
tostaylo is offline
post #8 of 94 Old 05-31-2012, 09:42 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
You can get integrated stereo amp and still have room correction - HK990.
ap1 is offline
post #9 of 94 Old 06-01-2012, 07:14 AM - Thread Starter
tostaylo's Avatar
Nice. But I dont think room correction is a game changer for me.
tostaylo is offline
post #10 of 94 Old 06-01-2012, 08:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Hi all,
Unless the Marantz is faulty or a bad design there may not be such a thing.
If you want a dramatic improvement or at least an audible change in sound quality, and you have not done so, please take a serious look (as in spend a day with it) at the MultEQ XT feature that is already there. According to the manufacturer's blurb, they even put an appropriate mic in the box!
If you are waiting for an attractive blonde to show up on your front steps and run the MultiEQ for you, you may have a long wait. ;-) OTOH, if you spend the big bucks on another piece and never try it, this does not make you look like a capable, dedicated audiophile...
arnyk is offline
post #11 of 94 Old 06-01-2012, 09:19 AM
buddahead's Avatar
Wrong again.Just because you cant hear differences in integrated amps and receivers does not make it the golden rule.I would say 99% of the poster here have no clue as to what to eve listen for.Their is much to matching electronics to the right speakers.Their are plenty of site's where you can get good advice. I have a pair of MA rs6 and I tried many integrated's.All had their own sound.Your Anthem choice is a good one.
buddahead is offline
post #12 of 94 Old 06-01-2012, 09:35 AM - Thread Starter
tostaylo's Avatar
That is a good idea trying the Multi EQ once more. Last time I did it was with a sub. This time Ill just run a 2.0 and see if how it goes.
tostaylo is offline
post #13 of 94 Old 06-01-2012, 10:01 AM
diomania's Avatar
Liked: 50
buddahead, do you sell electronics?
diomania is offline
post #14 of 94 Old 06-01-2012, 11:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Wrong again.
Tom, I've asked you whether or not you've done any level-matched blind tests and your response (or lack of it) tells me that for you, not so much.
Here's a little hint: Without level matching and bias controls, *everybody hears differences among power amps*
I would say 99% of the poster here have no clue as to what to even listen for.
Without level matching and bias controls, you don't need to know what to listen for. You'll hear differences regardless, due to the level differences and your own personal bias.
Much is made of this, but in fact if the electronics are good, they shouldn't care that much about which speaker they are driving. Amps that change their sound with different speakers are very old school.
There are a ton of sites where there are self-appointed eggspurts who will tell you all sorts of things.
I have a pair of MA rs6 and I tried many integrated's. A l had their own sound. Your Anthem choice is a good one.
Tell me about your level matched, bias controlled listening tests, Bob.
Until then, you're probably just talking about your outdated test procedures and how they lead well-meaning people such as yourself down the high end audio primrose path.
arnyk is offline
post #15 of 94 Old 06-01-2012, 12:49 PM
nymartyk's Avatar
If you're looking to upgrade stereo sound quality, I would first start with speaker placement. Square rooms are notoriously difficult to position speakers in. Try Cardas method and play from there. After that, try room treatment. Then if you still want more, switch equipment. Start with speakers. If you're looking for better bass without sub, go bigger. Then when you have the right speakers, try different source -- turntable or DAC. After all of that, then change Marantz. I think you'll hear much bigger differences and find what you like with this approach. After a lot of playing around I'm realizing that amplification contributes less to SQ and musicality than speakers or source. Happy hunting!
nymartyk is offline
post #16 of 94 Old 06-01-2012, 01:55 PM - Thread Starter
tostaylo's Avatar
I think youre right. Im just looking for a little a little bit more mid-range when listening to metal and hard rock. With the BX2's the mids are there but they are covered up a little bit by the highs and lows. I figure the RX2s or RX 6's will give me similar to better highs and lows with an improvement to the mids.
Dont' get me wrong, I think what I currently have sounds great And I don't feel the need to immediately replace anything. But just looking for a couple small improvements that when Im ready to make a change I'll know exactly what will do the trick. Doesnt sound like a different amp will give me what Im looking for though.
My sources are either 180gram vinyl, flac, apple lossless, and 256kbps aac so that should not be a problem. The room is not ideal and probably doesn't allow for the best placement. Room treatment is not an option unfortunately.
For the most part I am very happy and not overly picky about the sound. There are just 1 or 2 areas I think can be improved upon down the road.
tostaylo is offline
post #17 of 94 Old 06-01-2012, 02:13 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
If only I had your knowledge of audio electronics!! (And your spelling ability!)
beaveav is offline
post #18 of 94 Old 06-01-2012, 02:16 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
I agree with this. Speakers, their placement, and the room are going to be your biggest factors for sound quality.
beaveav is offline
post #19 of 94 Old 06-01-2012, 03:11 PM
syd123's Avatar
Quoted: 57 Post(s)
Liked: 59
If differences b/w amps are so significant, then why is there any debate regarding the existence of ANY differences??
McIntosh MA6600 Integrated amp (for 2-ch) | Onkyo TX-NR1030 AVR (TV/ Movies) | Paradigm Sig S8 v2's (front) | Paradigm Prestige 55C (Center) | Boston Acoustics Bravo 20 speakers (rear) | 2010 Technics SL-1200mk2 Turntable w/ AudioTechnica 440mla cartridge | Mac Mini Music Server | Emotiva XDA-2 DAC | Logitech Touch SB | Samsung PN58B860 Plasma TV
syd123 is offline
post #20 of 94 Old 06-01-2012, 05:06 PM - Thread Starter
tostaylo's Avatar
There has to be some difference in amps right?
Maybe just up until a certain price point there are differences but when you get to that point maybe the differences are too small to realize.
tostaylo is offline
post #21 of 94 Old 06-01-2012, 06:06 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
There are certainly measurable differences. The question is whether those measurable differences are large enough to actually be audible. The best evidence we have says that any two amps are not audibly distinguishable if the following conditions are met:
1) there are no impedance problems between amp and speakers that causes an audible change in frequency response
2) neither amp is driven to audible clipping
3) the amps' output levels are matched to within 0.1 dB
#1 is rare in solid state amps. #2 speaks to the issue of adequate power, which is important (though most speakers can be driven by most amps). #3 is just an obvious test condition. If the levels are different, of course they'll sound different.
Price is not a technical spec. Even cheap amps sound alike, assuming they meet the conditions above.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #22 of 94 Old 06-01-2012, 06:53 PM
Stutz320's Avatar
If you don't need a sub out and $1500 isn't out of your price range.
http://www.audioadvisor.com/prodinfo.asp?number=MFM3I
Stutz320 is offline
post #23 of 94 Old 06-01-2012, 07:20 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Those are some pretty expensive watts!
beaveav is offline
post #24 of 94 Old 06-01-2012, 09:06 PM
Stutz320's Avatar
You won't say that after listening to one.
Stutz320 is offline
post #25 of 94 Old 06-02-2012, 04:57 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Ever compared it to anything else in an unbiased listening test?
arnyk is offline
post #26 of 94 Old 06-02-2012, 08:14 AM
buddahead's Avatar
I think everyone here is sick of your bias listening test.The MF m3-1 is a top notch Integrated that gets many great reviews.People like you ruin this forum.If you do not have suggestion then quit posting.
post #27 of 94 Old 06-02-2012, 10:10 AM
bfreedma's Avatar
Liked: 51
Somehow, I think measurements and listening tests are far more valuable than subjective reviews. Or your favorite, selecting by MSRP and flowery marketing prose.
Darvis likes this.
bfreedma is offline
post #28 of 94 Old 06-02-2012, 11:25 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
I think everyone here is sick of your bias.
mcnarus is offline
post #29 of 94 Old 06-02-2012, 12:33 PM
jpco's Avatar
Quoted: 630 Post(s)
Liked: 283
I won't presume to speak for everyone, but for me, the incessant posting about proper blind listening tests gets old. It seems that too many threads have that position interjected over and over again.
When it's the topic of the thread or a singular response to a question, it's fine. At this point, it's like some have a mission to condition everyone to their way of thinking, which detracts from the topic conversation.
jpco is offline
post #30 of 94 Old 06-02-2012, 12:40 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
I won't presume to speak for everyone, but for me, the incessant posting about opinions not based on proper blind listening tests gets old.
mcnarus is offline
Reply 2-Channel Audio
