Optical to Stereo for my TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-04-2012, 05:18 AM - Thread Starter
subzero27's Avatar
Hello All,
My first post here , so please be kind
I had purchased a samsung d5000 40" LED TV sometime ago and now i want to connect my stereo amp to this tv. I couldn't see any stereo out other than headphone out ( which sucked ). My TV has a optical out only.
I want to know is there any way i can add a convert this optical signal to stereo which will be fed to my stereo amp.
I don't have a home theater and don't want to use it. Just want to connect my TV to my stereo amp. Any ideas?
If yes what should i use and what kind oa optical wire will fit.
Thanks for the help.
subzero27 is offline
post #2 of 21 Old 06-04-2012, 06:36 AM
ccotenj's Avatar
Liked: 101
get yourself one of these, and you'll be set to go....
spdif to analog converter
- chris
ccotenj is offline
post #3 of 21 Old 06-04-2012, 12:50 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Subzero,
There is a potential problem with that unit that Chris recommended: It only decodes stereo.
If the TV broadcast contains surround-sound (Dolby-Digital 5.1), my TV (Samsung) would only output that on the optical cable. There is no way to force it to output stereo instead. In that situation, I would hear no audio at all.
My solution was a Technics SH-AC500D ($40 on eBay), as recommended by Kal. It decodes the DD-5.1, and then down-mixes it to stereo.
MarkHotchkiss is offline
post #4 of 21 Old 06-04-2012, 01:22 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Originally Posted by MarkHotchkiss View Post
Hi Subzero,
Or a optical->stereo converter that handles DD, like:
http://www.markertek.com/Audio-Equip...ml?GTV-DD-2-AA
domino92024 is offline
post #5 of 21 Old 06-04-2012, 02:17 PM
Ratman's Avatar
Quoted: 1459 Post(s)
Liked: 1158
If you are not using the the TV's internal tuner, the device in post #2 will probably work fine.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #6 of 21 Old 06-04-2012, 02:21 PM
Liked: 85
Now that's a find! It's about time somebody did that.
I wish that existed a few years ago when I was looking. However, it is more than twice the price of what I paid for the SH-AC500D.
post #7 of 21 Old 06-04-2012, 02:22 PM
Liked: 85
But many TVs will only output on S/PDIF when using the tuner. TVs typically don't have the hardware/firmware to down-mix to stereo.
post #8 of 21 Old 06-04-2012, 02:57 PM
Ratman's Avatar
Liked: 1158
I would disagree.
When not using the internal tuner, most TV's will output (downmix) PCM stereo via the optical output from externally connected sources.
post #9 of 21 Old 06-04-2012, 09:50 PM
Quoted: 126 Post(s)
Liked: 216
It's 80 bucks including shipping at Amazon.
post #10 of 21 Old 06-04-2012, 09:54 PM
Quoted: 126 Post(s)
Liked: 216
I would disagree.
Yup, they gotta do it for the TVs speakers, so while downmixing for them...
post #11 of 21 Old 06-06-2012, 01:23 PM
Liked: 85
Your right. They do need to downmix for their internal speakers. But none of my Samsungs output anything on the optical except from the tuner. And then, it is only what is broadcast. Are the Samsungs simply lame? (I suppose so).
OK, then it is exactly twice what I paid for my SH-AC500D. But it is a good deal. Where else can you decode Dolby for under $100.
post #12 of 21 Old 06-06-2012, 01:47 PM
Ratman's Avatar
Liked: 1158
Nah... Samsung's aren't lame. I bet you may have overlooked an audio setting in the TV(s). Some have options to set to PCM only, DD only or "both".
post #13 of 21 Old 06-06-2012, 02:13 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
Last time I checked, this forum is for 2-channel only, so why even bring up 5.1?
The device in post #2 seems like a perfect choice for all of these TVs that have only an optical audio out.
commsysman is offline
post #14 of 21 Old 06-06-2012, 02:59 PM
Ratman's Avatar
Liked: 1158
Because we're trying to differentiate between broadcast TV (which is DD, not necessarily 5.1) and trying to help the OP get the optical working for stereo.
post #15 of 21 Old 06-06-2012, 10:26 PM
Quoted: 126 Post(s)
Liked: 216
And that device will output NOTHING if the OP uses his TV to tune any SD or HD signal on either cable or OTA. See...the OUTPUT going to his stereo IS 2-channel only. It's the input that could be DD or PCM.
post #16 of 21 Old 06-07-2012, 05:40 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
You can tell most TV's that can do multichannel to stick to 2 channels. It is a menu option.
arnyk is offline
post #17 of 21 Old 06-07-2012, 06:37 AM
Ratman's Avatar
Liked: 1158
post #18 of 21 Old 06-07-2012, 02:51 PM
Quoted: 126 Post(s)
Liked: 216
I challenge your use of the word "most." I cannot on my Sony, nor can I on my Mitsubishi. Many TVs have caveats warning users of the PCM/Dolby Digital dilemma, similar to ..."digital output might be Dolby 5.1 or PCM depending on what input source is used." No menu options given.
post #19 of 21 Old 06-08-2012, 02:11 AM
oOOBillO0o's Avatar
Originally Posted by subzero27 View Post
Hello All,
Its called a Digital to Analog Converter. or DAC for short. They can be outrageous or affordable. I use the Audioengine D1 and it works great.
McIntosh Labs! What am I listening to?
oOOBillO0o is offline
post #20 of 21 Old 06-08-2012, 06:01 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Without model numbers, the above comment is impossible to verify.
For example, my Mitsubishi TV has no menu options for stereo versus multichannel. It's always in stereo. You are right about the exact details (no menu option), but the outcome contradicts the thrust of your post (My TV worked perfectly with a simple DAC).
Without making claims that would take an industry-wide survey supervised by a major accounting firm to confirm, I'm willing allow for the existence of TVs that lack the menu option, and would need a multichannel decoder to work with all TV programs.
People should read their manuals. ;-)
arnyk is offline
post #21 of 21 Old 06-08-2012, 01:43 PM
Quoted: 126 Post(s)
Liked: 216
So any DD 5.1 contained in ATSC signals had to be transported to an AVR via analog. Or how?
But you were quite comfortable saying "most" had menu options ?? rolleyes.gif
Reply 2-Channel Audio
