best sub for a 2.0 music-only system around $750 or less? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 06-13-2012, 07:33 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
BTW: if you want dual subs, turns out that Emotiva has some b-stock on the Ultra 10, the predecessor of the X-Ref 10. You could get two for the price of the single subs discussed in this thread. Here's the review of the Ultra 12 so you can see how it compares to the X-Ref series.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #32 of 44 Old 06-13-2012, 07:38 AM
cel4145's Avatar
Liked: 3002
Sorry. One concern that I forgot to check. Some of the subs do not have speaker level inputs. So hooking them up may be a problem with your Marantz amp.
cel4145 is offline
post #33 of 44 Old 06-13-2012, 08:54 AM - Thread Starter
lifeis11's Avatar
also, anyone have any experience with Rel subs? the t-9 looks particularly appealing.
Paradigm Studio 100 Floorstanding Loudspeakers
REL R505 Subwoofer
Marantz PM8004 Integrated
Marantz SA8004 SACD
Rega P6 Turntable
Rega Exact 2 Cartridge
Cambridge Audio StreamMagic 6
Salamander Archetype 5.0 Equipment Rack
Chord ChameleonPlus, CobraPlus interconnect RCA
Legend Audio Bi-Wire...
lifeis11 is offline
post #34 of 44 Old 06-13-2012, 09:16 AM
glangford's Avatar
Quoted: 319 Post(s)
Liked: 255
Yea, I don't think the emotiva xref accomodates that. The manual assumes some base management of the source. That would have been my vote for a musical sub.
glangford is offline
post #35 of 44 Old 06-13-2012, 11:15 AM
cel4145's Avatar
Liked: 3002
Look at the hookups on the back. You need a subwoofer line out to connect this sub.
cel4145 is offline
post #36 of 44 Old 06-13-2012, 11:21 AM
cel4145's Avatar
Liked: 3002
Looks like there is a specialized high level input, too, on the REL. Probably best to look at their manual and see how it would connect.
cel4145 is offline
post #37 of 44 Old 06-13-2012, 12:14 PM - Thread Starter
lifeis11's Avatar
its pretty wild - they want you to wire it inline with the speakers...
REL R505 Subwoofer
Marantz SA8004 SACD
Rega P6 Turntable
lifeis11 is offline
post #38 of 44 Old 06-13-2012, 12:16 PM - Thread Starter
lifeis11's Avatar
in reading more, it seems the sub out can be used in tandem with the high level, but idt its needed:
http://rel.net/support/rel-set-up/
REL R505 Subwoofer
Marantz SA8004 SACD
Rega P6 Turntable
lifeis11 is offline
post #39 of 44 Old 06-13-2012, 03:30 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Before the popularity of HT, most subs were wired this way. I stil do on my 2 channel rig. REL says that wiring the sub via the speaker level provides the same signal/character that the woofer in the mains gets providing better integration.
qguy is offline
post #40 of 44 Old 06-13-2012, 03:38 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
if your in the REL T9 price range, I would seriously consider looking at the Rythmik F12 / F15 models. I have the F15 and it one heck of a performer for 2 channel applications.
qguy is offline
post #41 of 44 Old 06-13-2012, 04:01 PM
wingnut4772's Avatar
Liked: 29
For 2 channel only I would go sealed whatever you get.
Kaboom.
wingnut4772 is offline
post #42 of 44 Old 06-14-2012, 12:06 PM - Thread Starter
lifeis11's Avatar
the f15 is MASSIVE - seems like overkill to me personally
the f12 might be a little closer, like the price to be sure. ill get into it a little bit.
no available professional reviews?
REL R505 Subwoofer
Marantz SA8004 SACD
Rega P6 Turntable
lifeis11 is offline
post #43 of 44 Old 06-14-2012, 12:24 PM - Thread Starter
lifeis11's Avatar
also, although massive, the REL R505 can be had for 1300 from vans in Rosewood, which would match my floorstanders.
that may be too good a deal to pass up...
REL R505 Subwoofer
Marantz SA8004 SACD
Rega P6 Turntable
lifeis11 is offline
post #44 of 44 Old 06-14-2012, 02:58 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
qguy is offline
Reply 2-Channel Audio
