What's the best CD ripping software? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #91 of 163 Old 03-17-2014, 06:01 PM
Goes to 11's Avatar
Liked: 25
Originally Posted by rdeyoung View Post
Interesting. Im just curious because I am pretty passionate when it comes to making sure I have the highest quality (of anything really) rip of my music but I haven't heard much of a difference, or argument for that matter, that FLAC has higher quality than ALAC or that this program has better ripping quality than this other program. Its kind of a bummer that there isnt a standard process across the board for all software programs. If you want the best rip from your cd it should be done "this way."
Most of the time when dbPowerAmp reports an error rip, I don't hear a problem on playback. But at least I know it's there, so I can listen critically to see if there is a problem.
Goes to 11 is offline
post #92 of 163 Old 10-24-2014, 03:31 PM
DtroitPunk's Avatar
IF EAC is a little difficult or seems like a hassle try EASY Audio Copy!
I must admit that I had some issues with EAC at first and then discovered Easy Audio Copy! Same creator, same ripper, same results with all guess work removed! I will be posting a review in just a few minutes.
Someone who truly loves others speaks the truth, not just what they want to hear.
DtroitPunk is offline
post #93 of 163 Old 11-26-2014, 06:33 PM
Liked: 0
EAC is horrible software IMHO
I tried EAC and was not impressed in the least. Not sure if the software is no longer being maintained, but my advice: avoid it like the plague!
Tried installing EAC on my Windows 8.1 machine and it was an absolute nightmare! Tried ripping a CD multiple times with EAC and each time it locked up my PC and I'd have to reboot. Then, when I finally uninstalled the software, don't ask me how, but it corrupted the driver for my CD burner and my computer would no longer recognize the device...so I had to reinstall that.
Weird, weird software that I'm guessing is not compatible with Window 8.
Just trying to help save someone the hassle I just went through with this craptastic software. It may have been great on previous versions of Windows, but not with Windows 8...at least in my experience.
You can try it, but don't say I didn't warn you!
KryptonianGL is offline
post #94 of 163 Old 11-26-2014, 09:47 PM
Liked: 0
Easy Audio Copy doesn't want to work either :(
So after uninstalling ExactAudioCopy, I read in another forum that EasyAudioCopy works much better. However, that didn't work for me either. But, at least it doesn't lock up my PC. It just gives me an error during the process of ripping.
Fortunately though I was able to use Windows Media Player and rip my music that way...and it worked great; only WMP won't let me rip a FLAC file.
Oh well, maybe I'll cough up some money for dBpoweramp.
post #95 of 163 Old 12-06-2014, 09:15 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
dBpoweramp is the way to go if you are planning to rip a bunch of CDs. I also use EAC, but dB is much faster. At most I can get 8x with my drive for secure with EAC, while with dB I can get 40x and faster. The label selection with dB is better and the ability to edit the metadata directly in the software allows for more choice.
Occasionally I'll have a rip issue with dB and EAC will work--I'd say 1 out of every 100 discs (on a particular track).
If your time is important to you then dB is the way to go.
B.
Brian B is offline
post #96 of 163 Old 12-10-2014, 02:45 PM
arcada's Avatar
Liked: 0
EAC has been the most reliable for me.
arcada is offline
post #97 of 163 Old 12-10-2014, 05:21 PM
wunderkind's Avatar
Quoted: 31 Post(s)
Liked: 29
I used EAC. It's a bit too fiddly when all I want is to rip FLAC or MP3.
Ended my search with Fairstars CD Ripper. It's easy and straight forward. A lightweight software that just works.
wunderkind is offline
post #98 of 163 Old 12-11-2014, 01:29 PM
clpetersen's Avatar
Quoted: 162 Post(s)
Liked: 52
B.
Just read through this thread (mostly).
Using a MAC for about two years to do ripping (moved completely away from the semi-proprietary Olive system about a year ago).
Here is what works for us:
1) XLD - free. Does a good job overall but can be slow. Links to Amazon web services for an amazing way to locate artwork, esp. for older CD's. Provides data on the accuracy of rips (jitter, retries, bad secotrs, etc.)
2) JRiver version 20. Not free. You get what you pay for. This has been updated a couple of times already and keeps getting better. Faster rips than XLD, provides info on the quality/success of the rip. Excellent artwork finding capabilities and/or artwork file uploads. Integrates with the (excellent) JRiver library management tools and has a very deep tag set, especially useful for classical. All tags edits are saved back into track metadata (not an independent database like Olive used) - hence something else like Sonos or BlueSound will 'see' all these changes including updated artwork etc. Highly recommended.
Most everything is FLAC or more recently, Apple lossless; some limited hi-res material and some very limited DSD material.
WAV does not allow metadata to my knowledge. Given current processor capabilities, can't see a reason for WAV.
Occasionally use XLD and Amazon web services to locate artwork for some obscure CD found in used record store (boston area) or similar that 'stumps' JRiver. This is getting less and less frequent. But any search tool would suffice as long as you can save the image file.
Keep everything on a recent vintage time-capsule which is network visible. Back-up onto a separate USB hard drive, kept in my office. CD's kept in simple archival binders, but nothing obsessive.
--> does dBpoweramp work for OSX (Mac's)?
clpetersen is offline
post #99 of 163 Old 12-11-2014, 06:06 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Sorry, should have mentioned I meant for PC. I have read that XLD is popular for Mac, but as I'm stuck in a Windows world I don't know anything about it.
Does JRiver use AccurateRip? I get burst copy speeds with dB vs. EAC even though I'm getting secure rips. The time savings is so big I would never go back to EAC.
B.
Will2007 likes this.
Brian B is offline
post #100 of 163 Old 12-14-2014, 05:48 AM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
dBpoweramp gets my vote.
Sure, it costs $38 the last time I checked, but it does everything I need, and it's faster than EAC. They are also actively developing a Mac version, which I think their site says is getting officially released in January 2015 as of the moment. I've also had a pretty easy time getting it to run under WINE in Linux Mint 17. All you need to do is adjust the CD-ROM drive passthrough options in dBpoweramp and it works.
I believe Spoon is the developer who posts on their forums all the time, also added a CUE sheet encoder which is really nice. The program also takes far less setup than EAC, and requires none of the command line options to use an encoder (though the CLI Encoder option is available to those who want it).
I also LOVE the batch converter. If I want to convert my library of FLAC files to a lossy format for my portables, all I do is pick the folders I want, pick the encoder, let it run and set it to automatically shut down the computer when complete.
I don't see a reason to use anything else.
hogger129 is offline
post #101 of 163 Old 12-18-2014, 02:40 PM
Quoted: 24 Post(s)
Liked: 0
I had no idea there was much of a discussion... EAC
FolsomAudio is offline
post #102 of 163 Old 12-21-2014, 03:08 PM
ZoNtO's Avatar
I find EAC pretty limited without utilizing scripts and third party plugins (REACT). I set it up years ago and have no idea how I did it, so if anything ever went wrong I would just switch to dB software now.
I'm more interested in how to tag and organize classical music now. I'm finding that Apple Lossless tags with iTunes are severely lacking and am considering re-ripping everything to FLAC with custom tags for work, composer, opus, etc.
ZoNtO is offline
post #103 of 163 Old 01-19-2015, 11:09 AM
theblackangus's Avatar
Quoted: 199 Post(s)
Liked: 141
Silly question, I am finally getting around to ripping all my CD, I was going to use EAC but it appears you need to purchase a subscription to a meta data service to have all the CD data be populated w/o manual entry.
Does dbPoweramp or JRiver have the same requirement?
Is there a free source for metadata for use with EAC?
theblackangus is offline
post #104 of 163 Old 01-26-2015, 03:31 PM
Stanton's Avatar
Quoted: 1411 Post(s)
Liked: 741
You don't have to subscribe to anything to get correct Metadata, etc.; I just ripped some more CD's yesterday. If you're just getting started, the important thing to do is make a "plan" for how you want your library to be constructed (e.g. artist/album); I go back and add something like the track# at the beginning of the CD directory structure so (common) playing software will sort them in release order (much like it sorts the tracks in the order of the number at the begining of the title).
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #105 of 163 Old 01-26-2015, 07:08 PM
TimothyR's Avatar
The "build-in freedb engine" works well for me and no subscription required. Often you'll have varying choices of different versions of the same album, be sure to select the right one as some have bonus tracks. I'm currently using EAC version V1.0 beta 3 from 29 August 2011. Works well for me on Windows 7.
TimothyR is offline
post #106 of 163 Old 01-28-2015, 04:02 PM
Gerardo2068's Avatar
Quoted: 263 Post(s)
Liked: 64
So EAC is only windows? ... Next I guess.
Gerardo2068 is offline
post #107 of 163 Old 02-28-2015, 01:35 PM
neekos's Avatar
Quoted: 61 Post(s)
Liked: 58
I have a question as I am not too savvy on some programs. I currently hae all my cd's ripped to a FLAC file and they are connected from my Toshiba external hard drive to my Oppo 105. I play my music this way, but what if I have disks like 2L the Nordic Sound which has files in 2.0 LPCM 24/192KHz format? How or what kind of program can I rip this cd with in order to get higher quality processing ?
As far as I know, EAC and Media Monkey are all restricted to standard CD bit and sampling rates?
neekos is online now
post #108 of 163 Old 03-01-2015, 08:00 AM
Michael Sargent's Avatar
Quoted: 179 Post(s)
Liked: 164
Already answered in the other thread, but just in case someone is searching and comes here first:
DVD Audio Extractor works well for all DVD/BR audio (with the exception of dts-HD MA tracks where it only gets the core dts). $38.50US http://www.dvdae.com/dvdae/
Mike
Michael Sargent is offline
post #109 of 163 Old 03-05-2015, 12:09 AM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
For Linux, Asunder CD Ripper is awesome. Easy to use and gets the job done quick. No nosense.
On Windows, I agree with people suggesting dbPoweramp. Great program and worth the $40.
lulimet is offline
post #110 of 163 Old 03-21-2015, 10:26 PM
sulakd's Avatar
Quoted: 40 Post(s)
Good thread, I'm going to try the free trial of dbpoweramp based on all of the recommendations. I'm going back and re-ripping cds that I ripped years ago in lossy format. I want to make a high-quality backup copy and portable copy that I can stream from my nas through ps3 or whatever.
Aside from the ability to rip the flac file and m4a at the same time, does dbpoweramp have any big advantage over just using itunes? And is there a reason why everyone in this thread recommends flac over aiff? I was planning on aiff (harddrive space is cheap, and I don't have that much music anyway), but if there's a good reason to go flac, I will.
sulakd is offline
post #111 of 163 Old 03-22-2015, 07:46 AM
Quoted: 179 Post(s)
Liked: 164
FLAC is vendor neutral. It is supported by most companies, so your investment (in time, mostly) will never be wasted.
Mike
post #112 of 163 Old 03-22-2015, 07:46 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Because it has nothing to do with crapple.
A9X-308 is offline
post #113 of 163 Old 03-22-2015, 11:01 AM
Quoted: 263 Post(s)
Liked: 64
Lol love Apple haters. They are funny. Either way ACC and ALAC is open source, free and any company worth their reputation will support those files in their products. So it doesn't matter which way you go. Lossless is lossless.
post #114 of 163 Old 03-24-2015, 01:50 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
Most likely because Flac is better supported than AIFF.
lulimet is offline
post #115 of 163 Old 03-25-2015, 01:55 PM
clpetersen's Avatar
Quoted: 162 Post(s)
Liked: 52
Hello Stanton - not sure I understood what you meant by 'sorting in release order'- could you elaborate a little more? thx -
post #116 of 163 Old 03-26-2015, 03:23 AM
madaudio's Avatar
Quoted: 116 Post(s)
Liked: 59
Itunes files, as far as I know, can only be played on devices which have itunes installed.
Flac files can be carted around and played on most devices.
A point to keep in mind: if you are ripping new cd's to flac, and you want to play the sames files on, say, your car system that probably doesn't support flac, you can use dbpoweramp to convert your flac files in batches to mp3 to play in your car.
Speed Daemon likes this.
madaudio is offline
post #117 of 163 Old 03-26-2015, 11:14 AM
sulakd's Avatar
Quoted: 40 Post(s)
Thanks for the response (and to the others who chimed in too!). Ended up looking at my receiver's manual, and it can play flac files streamed from nas, but cannot play aiff. PS3 cannot play either one, but can play m4a. Wife has an ipod, so m4a copy is helpful to have. So a simultaneous rip to flac and m4a through dbpoweramp seems like the best option for me. Price is about $40 for one computer, or $60 for 2-5 computers. With the one-off option, does that mean that when my old computer breaks, I have to purchase the program again?
sulakd is offline
post #118 of 163 Old 03-27-2015, 07:48 AM
Quoted: 179 Post(s)
Liked: 164
I think it's a transferable license. Check with Illustrate to be sure, but that's the usual way these things work.
Mike
post #119 of 163 Old 08-30-2015, 06:32 PM
Altheia's Avatar
Quoted: 49 Post(s)
I cannot find this option? I can only rip one format at a time. I can then use the db converter in a separate step?
Altheia is offline
post #120 of 163 Old 08-30-2015, 07:02 PM
Speed Daemon's Avatar
Quoted: 91 Post(s)
Liked: 47
I'm still using abcde in Linux to rip CDs. I found the ideal settings years ago, and still use the same abcde.conf file I made way back when. That ensures a continuity between older and more recent rips.
EDIT: BTW, I simultaneously encode to FLAC, Vorbis (.ogg) and MP3 to be compatible with systems that don't support FLAC. I'll probably add AAC to that as well.
You get what you pay for.  For professional advice, pay the professional rate.
Speed Daemon is offline
Reply 2-Channel Audio
