What's the best CD ripping software? - AVS Forum
post #1 of 91 Old 06-14-2012, 07:30 PM - Thread Starter
gaucherre's Avatar
Hi, everyone. Would like to rip our CD collection to the computer. We have approximately 800 CDs, and also have plenty of hard drive space available for storage. It's a big project so would like to simplify it/automate it as much as possible while retaining the best quality sound. Want to rip everything in .wav format. Later on we may convert various music to FLAC or .wma lossless for smaller file sizes to take along on vacation, etc. Have heard that the free program Exact Audio Copy (EAC) does a good job of ripping with the fewest data errors or error correction, but am open to persuasion.
Beyond the basic task of high quality ripping to .wav files, there are a number of information and convenience factors to consider. Will list the main ones here and hope you experts can suggest what software would best handle everything. A friend suggested we might want to rip using one program (like EAC?) and to organise or catalog the music using a different program. Although we prefer free software, an excellent program that does it all very conveniently might be worth paying for. Here are some features we're hoping for:
After initial setup and configuration be able to insert a CD and have it automatically rip at highest quality to desired folder, probably organised by album title and with full artist, track, title information. If one or two quick mouse clicks are necessary with each CD that would be OK I suppose, but fully automated would be most convenient, of course.
Album art included would be nice.
Tagging or key words included would be nice. For example, locating a particular piece of classical music on an album containing various composers would be much easier if we could search tags or keywords.
There may be other useful features we haven't even thought about.
Thanks very much for your help!
Creating and saving playlists of various music would be nice.
gaucherre is offline
post #2 of 91 Old 06-14-2012, 09:36 PM
postrokfan's Avatar
Quoted: 38 Post(s)
Liked: 326
I like EAC for burning CDs. I use Media Monkey for the media server.
postrokfan is offline
post #3 of 91 Old 06-14-2012, 09:42 PM
cel4145's Avatar
Quoted: 212 Post(s)
Liked: 746
Me, too. I've used EAC for years to rip to flac. Then I use Media Monkey as a media server. I can take any selections of songs on Media Monkey and convert the flacs to mp3 or wav very easily.
Since EAC is freeware, might as well download and try it.
HT: Energy RC-50, RC-LCR, Veritas VS Surrounds | Dual CHT SS 18.1s | Denon AVR-888 | modified Dayton SA1000 | Antimode 8033C
Desktop: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | HK 3390
Headphone & Portable HE-400 | K612 Pro | HP150 | DX50 | E12
cel4145 is offline
post #4 of 91 Old 06-14-2012, 09:57 PM
AudioSerf's Avatar
I just use iTunes ALAC and check the CD. I store all of this on a 2TB external SATA3/6G hard drive. Then I use the home share on the Apple TV, iPhones and other computers running iTunes. A more universal format would be .wav but I play all my audio out of iTunes and you can convert ALAC to WAV or FLAC if you ever need to play it in something else that doesn't support ALAC. I can't find a cleaner interface, also Media Monkey tries to say they have a bunch of features that WMP and iTunes don't have but you can find most of them in iTunes (such as the mini player). I also shop on the iTunes store, so it's a win for me. Not sure if that meets all your needs though. You get the album art with iTunes as well, as far as automation you pop in a CD and it starts ripping, pulls the song info and grabs the album art.
AudioSerf is offline
post #5 of 91 Old 06-14-2012, 10:18 PM
MarkHotchkiss's Avatar
Liked: 82
Hi Gaucherre,
I have one minor suggestion: Rip to FLAC or ALAC instead of WAV. You would get the most convenience if your files are properly tagged, and WAV has very poor support for tagging. If you keep your library in FLAC, you can have EAC tag and include the cover-art, and you can always convert back to WAV later if you need.
I use EAC, but dbPowerAmp is also well regarded and is easier to setup. Configuring EAC for your needs can be time consuming, and may include a little trial&error. I still fuss with it, even after 13 years of using it. DbPowerAmp is not free (you can try it out for free), but those I know who have bought it claim it's worth the price.
MarkHotchkiss is offline
post #6 of 91 Old 06-14-2012, 10:24 PM
AudioSerf's Avatar
$38 Dollars, looks interesting like it has a lot of features. I would definately use that to convert as the free one I use isn't that good. Thanks!
post #7 of 91 Old 06-18-2012, 04:35 PM
Will2007's Avatar
Liked: 140
I've been using dBPowerAmp for years, and it's worth every penny. It's the gold standard for ripping, tagging, converting, and doing just about anything else with your digital music files you care to do. I used to use EAC, but frankly there's no comparison between the two.
Will2007 is offline
post #8 of 91 Old 06-19-2012, 06:29 AM
coolsax's Avatar
I too use Dbpoweramp.. its so easy to use and set up.. ripped more than 500 CDs in the last 2 years best 38 bucks spent. it even allows dual ripping.. i rip to FLAC for my main system(squeezebox) use and to mp3 for portable ipod use and it does it at the same time.
coolsax is offline
post #9 of 91 Old 06-19-2012, 09:42 AM
its phillip's Avatar
Liked: 54
EAC gets my vote.
its phillip is offline
post #10 of 91 Old 06-19-2012, 10:02 AM
Nethawk's Avatar
Liked: 115
+1 for this reason. You can rip into multiple different formats/compression levels in one pass. Another benefit to dbpoweramp, if you have multiple drives you can run multiple instances at the same time. I have two internal, a third USB CD drive and had all three cranking at the same time. It also has ability to look up selections in multiple choices for selection and association of metadata.
Nethawk is offline
post #11 of 91 Old 06-19-2012, 08:10 PM
Tank_PD's Avatar
Liked: 51
Another +1. I used to use EAC as well, but dBPowerAmp is much better. To start with the tagging is far better and it is much faster at secure ripping. If you value your time, it's well worth $38. You will also get the batch conversion program so you can rip to loseless and convert to any other audio format you need.
Tank_PD is offline
post #12 of 91 Old 06-19-2012, 08:45 PM
postrokfan's Avatar
Quoted: 38 Post(s)
Liked: 326
That's pretty cool. I may have to take a look at dbpoweramp.
post #13 of 91 Old 06-20-2012, 11:03 AM
holt7153's Avatar
Liked: 104
Considering everything I have at home is Apple based (imac, ipod, Apple TV, etc, ) is there any downside to using dBpoweramp as opposed to ALAC? Obviously I would need to be able to stream and play it from existing players.
I want to die peacefully in my sleep like my grandfather, except not while driving a school bus.
holt7153 is offline
post #14 of 91 Old 06-20-2012, 12:53 PM
TheWind's Avatar
I’ve read a lot of praise for dbpoweramp and EAC over the years; they must be good programs. However, I don’t recall having seen them directly compared & contrasted to Nero Burning ROM.
Do dbpoweramp or EAC do anything significantly better than Nero Burning ROM? – For example:
Do they actually produce better quality rips.
Does dbpoweramp create better tagging than Nero and its Gracenote plug-in?
Not trying to push Nero or anything; I’m just seeking knowledge. – And for me, the entire Nero Multimedia Suite (which includes Nero Burning ROM) is basically like freeware because, I only update when the cost after rebates is $0.
Dave
TheWind is offline
post #15 of 91 Old 06-20-2012, 01:10 PM
Liked: 82
Hi Dave,
Short answer:
Much of the time.
Long answer:
EAC, which stands for Exact-Audio-Copy was written to do something that the other ripping software at the time (Real-Audio, Nero) did not do: Insure that the data read from the disk was an exact copy of what was meant to be there. That meant understanding the error-correction capabilities and buffering mechanisms of many different CDROM drives. The software would go through great lengths to read accurate data from the CD. I had a Notorious B.I.G. disk that took two days to rip, because of error-recovery due to scratches. Other software would do a simple read of the CD, errors and all. DbPowerAmp did the same as EAC, and added another level of protection as well.
So if you have pristine CDs with no errors, Nero would most likely produce the same results as EAC and dbPowerAmp. But if any of those CDs have dirt, scratches or flaws, EAC and dbPoweramp will create a more accurate rip, although it will take longer.
Nethawk likes this.
post #16 of 91 Old 06-21-2012, 01:44 AM
TheWind's Avatar
Thanks Mark!
That was very helpful. – Fwiw, like gaucherre, I’m about to begin ripping my CD collection to a hard drive. Since the vast majority of my CDs are in very good condition and ripping speed will probably be a factor, I think I’ll stick with Nero and see how it goes.
Thanks again,
Dave
TheWind is offline
post #17 of 91 Old 06-21-2012, 08:28 AM
Twylight's Avatar
dbpoweramp
REW...most expensive freeware ever...
Twylight is offline
post #18 of 91 Old 06-21-2012, 10:24 AM
Tank_PD's Avatar
Liked: 51
Thanks Mark!
Thanks again,
Dave
Speed doesn't matter if there is no error correction. You will need to rip again.
Tank_PD is offline
post #19 of 91 Old 06-21-2012, 12:05 PM
cel4145's Avatar
Quoted: 212 Post(s)
Liked: 746
Thanks Mark!
You do realize you probably won't be able to easily tell if there are any errors, but you won't have made exact copies of your CDs.
And I use Nero for burning. EAC is not any harder to use for ripping. Not only that, but there is the cost savings benefit of having error correction. I almost never buy new CDs any more if I can buy "like new" used ones off Amazon for less money since I can count on EAC to deal with any minor disk imperfections.
cel4145 is offline
post #20 of 91 Old 06-21-2012, 12:10 PM
VeeArSix's Avatar
Another vote for dbpoweramp. One feature that I like is that it makes use of multi-core processors. I have a quad-core i7 processor and was flying through my collection.
Xbox Live: ChestR0ckWell23 (that's a zero after the R)
PSN: VeeArSix
VeeArSix is offline
post #21 of 91 Old 06-21-2012, 12:25 PM
TheWind's Avatar
Based on my experience this is probably total misinformation.
Over the past 12 years or more, I have ripped lots of music with Nero Burning ROM. The resulting music sounds exactly like the original and I have NEVER had to rip again with alternate software for any reason whatsoever.
I’m not saying that dbpoweramp or EAC don’t offer some advantage, but telling people that Nero’s ripping function doesn’t really work is misleading and wrong.
TheWind is offline
post #22 of 91 Old 06-21-2012, 11:10 PM
Tank_PD's Avatar
Liked: 51
Whenever I've ripped CDs without error recovery I have run into problems; I have sometimes encountered large artifacts like blips, static, or skips. I have quite a few used CDs and they are not in perfect condition. So I have had to rip discs again.
Even without using error recovery / verification features, dbPowerAmp is still the best ripper I have used.
Tank_PD is offline
post #23 of 91 Old 06-26-2012, 07:44 AM
caper_1's Avatar
Liked: 24
My vote is EAC to FLAC, playback with foobar.
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #24 of 91 Old 07-05-2012, 07:46 PM
GlassWolf's Avatar
EAC with LAME or a FLAC encoder.
caper_1 likes this.
-GlassWolf
My Home Cinema
GlassWolf is offline
post #25 of 91 Old 12-23-2012, 11:18 PM
KimbaWLion's Avatar
You all should try this one its called EZ CD Audio Converter
http://www.poikosoft.com/
It does the following:
Unique features of EZ CD Audio Converter:
Multiple services for retrieving high-quality metadata
Intuitive and easy-to-use interface
Best audio codecs out of the box for best audio quality
Exact and reliable CD ripping with error detection and two-pass verification of audio
Extremely high-performance ripping and converting that takes advantage of the multimedia features of processors
Multi-core audio converter that allows parallel audio conversion with up to 8 parallel converters
ReplayGain for automatic loudness leveling on playback
Supported audio formats include: Dolby Pulse, AAC / HE AAC, MP3, FLAC, Vorbis, Opus, Apple Lossless, Windows Media Audio, and more.
I may not be the BEST guy, BUT I am NOT the bad guy!!- Coop from Megas XLR
KimbaWLion is offline
post #26 of 91 Old 12-24-2012, 07:40 AM
CruelInventions's Avatar
Quoted: 27 Post(s)
Liked: 176
... If you're pay that much, may as well just get dbpoweramp instead. That's not to suggest this program is no good. Only that, upon first skim, the feature list looks similar to dbpoweramp.
Mourning the disappearing usage of the -ly suffix. Words being cut-off before they've had a chance to fully form, left incomplete, with their shoelaces untied and their zippers undone. If I quote your post (or post in your thread) without comment, please check your zipper.
CruelInventions is offline
post #27 of 91 Old 12-24-2012, 08:19 PM
kraut's Avatar
Liked: 60
My opinion: anyone who pays today for a cd ripper is just...nuts.
I ripped with cowon jet audio - free, and foobar that allows you to download converters to just about any format for free.
No problems, ripped in flac.
As for metadata - use mp3tag for free as well.
kraut is offline
post #28 of 91 Old 12-24-2012, 09:15 PM
KimbaWLion's Avatar
I paid a LOT less have used it for years and years! I like the LIFETIME updates etc. etc.
I just wanted point out another program. Everybody likes choices :-)
post #29 of 91 Old 12-25-2012, 03:39 PM
EnjoyingMyRide's Avatar
dbpoweramp. . .
Steve
EnjoyingMyRide is offline
post #30 of 91 Old 12-26-2012, 09:55 AM
Goes to 11's Avatar
I have a collection of over 1000 CDs that were ripped over a period of several years to MP3 files for loading onto a Creative Labs Zen. All (almost all) the CDs were stored in two Pioneer 300-CD jukeboxes and one Sony 400 CD jukeboxes. Now that I'm using a Logitech Squeezebox to play all of my music, I'm going to start re-ripping all of them to FLAC. Oh, the fun that lies ahead!
This helpful thread has me convinced, I think, to go with dbPoweramp, mainly because of the speed advantage and the ability to create a simultaneous second rip in a different format for use on a portable player. One thing I don't quite understand is the necessity of calculating my CD drive's "offset" in order to use AccurateRip. That is, it looks like it's a necessity to me. Can anybody explain this a little better than the set-up guide for dbPoweramp does? Thanks.
[Edit] Second question: dbPowerAmp's site talks about it being a "one off" purchase. Does that mean if I soon replace my aging desktop with a new computer, I have to buy it again?
Don't mean to hijack this thread, hopefully these questions are closely-enough related to the OP so as not to.
Goes to 11 is offline
Reply 2 Channel Audio
User Tag List
