Are the Swan M200MK3 speakers considered monitors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-16-2012, 04:21 PM - Thread Starter
Waloshin's Avatar
Is there anything better then the M200MK3 speakers in the $400 range?
Waloshin is offline
post #2 of 3 Old 06-20-2012, 09:33 PM - Thread Starter
Waloshin's Avatar
Bump.
Waloshin is offline
post #3 of 3 Old 06-21-2012, 04:34 PM
stalkerte's Avatar
I just ordered a pair of Pioneer BS41's from Newegg for 99/- and a Onkyo TX-8050 from Onkyo directly for 215/-.
Can't give you a direct comparison but these trump my D1080 MKII's easily enough. I'm sure you should be able to build a nicer setup for 400/- if you are patient and shop around for deals.
stalkerte is offline
Reply 2-Channel Audio
