Newbie looking to replace Logitech Z-5500s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-17-2012, 09:06 AM - Thread Starter
masterblingpimp's Avatar
Hello everyone,
I have been browsing the forums for a while now. I guess I finally decided to make a move and get some real speakers.
Currently, I have the Logitech Z-5500, their top of the line computer speakers.
Through some research, I have realized that a good budget set up (2.0) would be the Polk Audio 40s (with stand), and the Denon 1612. I would be using it mainly for music (and movies at time).
So I have a few questions.
1. Is the proposed set up the best available for around ~$500?
2. I have never heard the Polks before, would you say that they are much better than the Z-5500?
3. Are there any parts of the Z-5500 I can use with the set-up (mainly the subwoofer I am curious about)? Or should I keep the Z-5500 for movies?
4. Suggestions on what else I should buy as a newbie enthusiast?
Thanks a lot for your time!
masterblingpimp is offline
post #2 of 4 Old 06-17-2012, 10:43 PM - Thread Starter
Anything guys? Even commenting on the speakers I want to get is fine smile.gif
post #3 of 4 Old 06-18-2012, 05:30 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Check out the Energy RC-10s. These are generally considered to be better speakers than the Monitor40s. Research in the Energy owners thread to learn more.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 4 Old 06-18-2012, 05:41 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
The 1612 is a good choice.
You can get the Monitor 50 for about $110 each from Amazon; I would suggest that they would be better than the 40 (plus cost of stands?).
commsysman is offline
Reply 2-Channel Audio
