Does a Mark Levinson 38 Preamp have a phono stage (for Rega RP3) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-04-2012, 09:39 AM - Thread Starter
ChadhaT's Avatar
I have caught the bug to try my hand/ears to a turntable again and am considering the Rega RP3.
I have a "spare" preamp the Mark Levinson 38 that I am thinking of having a small 2 channel system in my home office. How do I check if it has a phono stage or not - I have not got the turntable yet to test it ?
Tarun
Tarun
ChadhaT is offline
post #2 of 4 Old 07-05-2012, 09:30 AM
commsysman's Avatar
Quoted: 983 Post(s)
Liked: 526
It does not have a phono stage.
You would need to buy a dedicated phono stage to use with it.
I am using the Musical Fidelity V-LPS, which is only $200, and it is excellent.
commsysman is offline
post #3 of 4 Old 07-05-2012, 05:31 PM
Class A's Avatar
Quoted: 297 Post(s)
Liked: 317
The easiest way to determine if you have a phono stage on a preamp or receiver is you'll find a grounding terminal for your TT on the back of your unit.smile.gif
Class A is offline
post #4 of 4 Old 07-08-2012, 02:36 AM - Thread Starter
ChadhaT's Avatar
Thx
Tarun
ChadhaT is offline
Reply 2-Channel Audio
