DAC suggestion - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 214 Old 08-13-2012, 02:14 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Good example is Bricasti M1 DAC (http://www.bricasti.com/m1.html). You do not need "golden ear" to hear the difference between several filter options in that device.
ap1 is offline
post #182 of 214 Old 08-13-2012, 02:18 PM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
http://jn.physiology.org/content/83/6/3548.abstract
Although it is generally accepted that humans cannot perceive sounds in the frequency range above 20 kHz, the question of whether the existence of such “inaudible” high-frequency components may affect the acoustic perception of audible sounds remains unanswered.
Psychological evaluation indicated that the subjects felt the sound containing an HFC [high-frequency components] to be more pleasant than the same sound lacking an HFC. These results suggest the existence of a previously unrecognized response to complex sound containing particular types of high frequencies above the audible range. We term this phenomenon the “hypersonic effect.”
Greg121986 is offline
post #183 of 214 Old 08-13-2012, 02:19 PM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
My local dealer just got this in. I have yet to listen to it. Hopefully I will be able to test it out one of these days.
post #184 of 214 Old 08-13-2012, 04:25 PM
Hamilcar Barca's Avatar
Yet,
Attempts to independently reproduce these results [the "hypersonic effect"] have so far been unsuccessful.
-- http://en.wikipedia.org/wiki/Hypersonic_effect#cite_note-Colloms2006-3
[Note: Wikipedia is not an independent reference.]
Judging from this review of the subject, the case for an ultrasonic reproducing bandwidth is not proven, and 20kHz remains the practical limit for the chain as a whole.
-- Proceedings of the Institute of Acoustics, Vol. 28. Pt.8. 2006
As a result, no significant difference was found between sounds with and without very high frequency components among the sound stimuli and the subjects.
-- NHK Laboratories Note No. 486 (2004)
Hamilcar Barca is offline
post #185 of 214 Old 08-13-2012, 06:25 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
It's not much of a mystery. High frequencies can produce distortion in the audible range. That's now understood to be the explanation for that paper's unique findings.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #186 of 214 Old 08-13-2012, 06:28 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
If so, one wonders how those filters are distorting the signal.
mcnarus is offline
post #187 of 214 Old 08-13-2012, 06:41 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Any filter distorts signal in either frequency or time domain, the difference is how much and what type of distortion it adds. If it wasn't the case we wouldn't have dozen of possible transfer functions implemented in different DACs. Every sharp cutoff filter is a compromise, those which operate in real time even more so due to limited computing power.
ap1 is offline
post #188 of 214 Old 08-13-2012, 07:09 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
But if they're distorting the signal enough to be audible, their virtue escapes me. (And that if is intentional. I'm not conceding that they are in fact distorting the signal that much.) I want undistorted sound out of my source components. At least four of its five filters are doing something wrong, by that standard.
mcnarus is offline
post #189 of 214 Old 08-14-2012, 05:55 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Really?
Here are the specs:
http://www.bricasti.com/images/M1.pdf
Table of filter characteristics at 48khz.
48khz Passband Stopband Passband ripple Stopband attenuation delay
Filter 0 20kHz 24kHz .001dB 111dB .73ms
Filter 1 20kHz 24kHz .005dB 102dB .63ms
Filter 2 19.5kHz 24kHz .004dB 103dB .56ms
Filter 3 19kHz 24kHz .005dB 102dB .51ms
Filter 4 18.5kHz 24kHz .003dB 106db .50ms
Filter 5 18kHz 24kHz .001dB 114dB .50ms
Filter 6 21.8kHz 26.3kHz .0002dB 110db .72ms
Filter 7 20kHz 24kHz .001dB 110dB .7ms
Filter 8 20kHz 24kHz .001dB 110dB .7ms
Table of filter characteristics at 44.1khz
44.1khz Passband Stopband Passband ripple Stopband attenuation delay
Filter 0 20kHz 22.05kHz .001dB 110dB 1.43ms
Filter 1 20kHz 22.05kHz .161dB 71dB .72ms
Filter 2 19.5kHz 22.05kHz .046dB 82dB .72ms
Filter 3 19kHz 22.05kHz .014dB 92dB .72ms
Filter 4 18.5kHz 22.05kHz .005dB 102db .72ms
Filter 5 18kHz 22.05kHz .001dB 112dB .72ms
Filter 6 20kHz 24kHz .0002dB 111db .78ms
Filter 7 19kHz 22kHz .001dB 110dB 1ms
Filter 8 20kHz 22kHz .001dB 110dB 1.5ms
All ripple is less than 0.1 dB (and not by just a little!) and all filters are flat out to at least 20 KHz.
What am I missing here?
arnyk is offline
post #190 of 214 Old 08-14-2012, 06:00 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
In the previous post (189) I provide the actual specs of the filters.
All appear to be flat out to 20 KHz, with far less than 0.1 dB ripple.
AP1 appears to be inventing new science when it comes to audibility. ;-)
Wise, not to concede to AP1's apparent false claims.
Actually, all options represent brilliant performance. But there will be no end of audiophiles and reviewers who will publish a short poem about what they think it sounds like - all based on the sheerest of all imagination. If they harnessed that literary skill to writing about the partner of their choosing, at least they'd get a little lovin' ;-)
arnyk is offline
post #191 of 214 Old 08-14-2012, 06:33 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Specs are just that - specs. They are always lImIted to WHAT was measured. I heard the difference switching between filters in that device. Sometimes more, sometimes less. Instead of theorizing here go to a dealer and listen yourself. Then come back and tell about what YOU heard.
ap1 is offline
post #192 of 214 Old 08-14-2012, 06:39 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Sigh. Some people just never learn.
mcnarus is offline
post #193 of 214 Old 08-14-2012, 07:31 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Typical audiophile rhetoric. The theme is that no matter how many listening tests you've done related to products like these, and differences like these, this new toy is magic and breaks all of the rules. Their sighted tests trump everything else in the world.
It is likely pure solipsism.
Logic says that the differences between the various filters are well-characterized by the vendor's spec sheet because it is highly unlikely that anything else with audible significance changed.
The variations involved are often in the hundreths and even in thousandths of a dB. At 20 KHz a 5.0 dB difference can slip by everybody's ears for reasons I've previously explained.
arnyk is offline
post #194 of 214 Old 08-14-2012, 07:53 AM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
Arnyk, can you make it to Royal Oak/Clawson area this weekend? We can test this DAC out at David Michael Audio. biggrin.gif
post #195 of 214 Old 08-14-2012, 09:07 AM
diomania's Avatar
Liked: 50
Would you recommend taking one of these to the dealer when doing that? http://images10.newegg.com/ProductImageCompressAll300/82-461-009-02.jpg
diomania is offline
post #196 of 214 Old 08-14-2012, 09:13 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Is he equipped to do good clean DBTs?
Otherwise, not worth the trouble to even think about.
arnyk is offline
post #197 of 214 Old 08-14-2012, 09:18 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Actually, it would take more than that.
The biggies are listening to exactly the same music and getting the switching time down to subsecond and DB. Otherwise the evaluation is hopelessly compromised.
Besides, I'm hundreds of tries down this road and it is about as much fun to do yourself as watching paint dry.
Let some golden ear actually do a good test with positive results, and maybe it would be worth the trouble to run a confirmation. ;-)
arnyk is offline
post #198 of 214 Old 08-14-2012, 09:20 AM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
I think we could make it work. All of his gear is accessible enough to where we could have someone swapping out components within 20 - 30 seconds. You're not going to have instantaneous switching, though.
post #199 of 214 Old 08-14-2012, 09:45 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Nowhere near good enough. If the filters really did sound subtly different (which they obviously don't), that time delay would make it impossible to identify them in a true blind test.
mcnarus is offline
post #200 of 214 Old 08-14-2012, 09:45 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
That's hopelessly compromised in terms of sensitivity for small SQ differences. Over 30 times too much switch over delay to hear small differences. It needs to be well under 1 second.
The only beneficiaries of this test if done right is going to be someone other than me.
You can pay me to deal with this sort of thing, time and materials at $120/hr with a 4 hour minimum. I can refer you to someone in the area who is better known than I to do it for a higher price. ;-)
Nobody wants to know the inconvenient truth at that price!
arnyk is offline
post #201 of 214 Old 08-14-2012, 09:45 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Never mind that. He's a high-end dealer. Do you think he's gonna cooperate?
mcnarus is offline
post #202 of 214 Old 08-14-2012, 09:59 AM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
I have a very good relationship with this dealer. I would be able to work it out. But alas, Arnyk must be paid for his time and nobody as small time as myself is going to be able to pay Arnyk for his scientific research.
post #203 of 214 Old 08-14-2012, 10:23 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
I do not think you appreciate the attitude that such dealers have about blind testing. It is a mortal threat to their economic survival, and they know it.
My suggestion is that you buy the unit, and then offer to take it to Arny's for the test.
mcnarus is offline
post #204 of 214 Old 08-14-2012, 10:57 AM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
They already have a room setup with room treatments and such so I think it would be a good location to do the test. But, for that matter I would suspect Arny has a treated room as well.
post #205 of 214 Old 08-14-2012, 11:45 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I do just about all of my technical work either on-site or with headphones. My listening room is untreated.
arnyk is offline
post #206 of 214 Old 08-14-2012, 11:48 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
You do not need this. In Bricasti filter algorithm is switched with simple push of the button. Everything else stays the same.
ap1 is offline
post #207 of 214 Old 08-14-2012, 12:03 PM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
Yea this is correct. I was thinking that we were testing different DACs for some reason but the filters would be changed from the remote. So in that case level matching and such would not be required. Give someone else the remote and have them change the filter for you.
post #208 of 214 Old 08-14-2012, 12:57 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
One way to do blind testing with devices like this is to have a person who is hidden from all of the listeners.
Let him flip a coin in secret and make a numbered secret list of unknowns. Since there are more than 2 choices he should flip a number of coins, count heads as 0 and tails as 1 on the first coin he picks up after each toss, then heads as 2 and tails as 3 on the second coin he picks up, etc., and sum the value of the coins tossed for each unknown.
Then when the listeners call out a trial number, he consults the list and selects the filter associated with that number. They write down the filter number they think they are listening to and keep their results to themselves.
When all of the trials are complete, compare the secret operator's list with the listener's lists.
Score in accordance with this:
http://home.provide.net/~djcarlst/abx_bino.htm
arnyk is offline
post #209 of 214 Old 08-14-2012, 01:08 PM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
What headphones do you prefer?
post #210 of 214 Old 08-14-2012, 02:07 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Nonetheless, you should confirm this with an onsite measurement. Lots of audio components do not behave as advertised.
mcnarus is offline
Reply 2-Channel Audio
