DAC suggestion - AVS Forum | Home Theater Discussions And Reviews
Old 07-22-2012, 02:09 PM - Thread Starter
kzhtoo's Avatar
My current set-up
AppleTV (via hdmi) --> A/V receiver as pre/pro (via pre out, RCA connection) --> external amp --> speakers
I'm thinking to upgrade the DAC in the chain (receiver internal DAC) to a quality external DAC.
Upgrade set-up
AppleTV (via hdmi) --> A/V receiver as pre/pro (via DIGITAL OUT) --> NEW external DAC (via RCA) --> external amp --> speakers
Any suggestion? Let's say budget is $1000.
kzhtoo is offline
Old 07-22-2012, 03:44 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Upgrade your speakers.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Old 07-22-2012, 03:45 PM - Thread Starter
kzhtoo's Avatar
Without knowing what speakers I have?
kzhtoo is offline
Old 07-22-2012, 04:03 PM
MarkHotchkiss's Avatar
Liked: 85
I think mcnarus's point is that any speaker upgrade would be more cost effective than any DAC upgrade.
If I had $1000 to spend, I would put it into speakers. Of course, you're right, if you've already put more than that into speakers. But then I would put the money into a better AVR, as the DACs within a good AVR are as good as the DACs within an external DAC, but the DSP processing in the AVR can give you more than an external DAC can.
MarkHotchkiss is offline
Old 07-22-2012, 04:10 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
Your AVR has digital out? That's uncommon. You may get some improvement with a device that supports higher resolutions than the ATV, like a squeezebox or direct connection from a computer. If you want to go the external DAC route, you could go with a DAC/pre-pro with HT bypass, but whether it would sound noticeably better is debatable. I don't know of any that take HDMI, but you could use the optical output on the ATV.
saeyedoc is offline
Old 07-22-2012, 04:24 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Upgrading the speakers will at least make an audible change.
The DAC in your receiver is probably very, very good and while it may be possible to obtain one that measures better, obtaining one that sounds better (or even different) will be extremely difficult.
The very many "internet truth" reports relating to improved SQ due to dacs are based on sighted evaluations which are fraught with listener bias.
The other alternative is: room acoustics.
Tony_Montana likes this.
arnyk is offline
Old 07-22-2012, 04:27 PM
AuralXTC's Avatar
Some pretty bad advice in this thread, I'll just leave it at that.
Why let facts or common sense get in the way of your opinions.
Quick shot of my gear/theater.
AuralXTC is offline
Old 07-22-2012, 04:31 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I'm hoping that you share my frustration with the absence of reliable evidence supporting many of the DAC upgrades that are thown around many audiophile conferences.
I've done a lot of relevant level matched, time synched blind listening evaluations and so have many other people. They back up the idea that a lot of common wisdom about alleged DAC upgrades is fiction.
arnyk is offline
Old 07-22-2012, 04:33 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
My current set-up
Upgrade set-up
BTW I suspect that if we do a technical evaluation of your external amp lash up, you may be surprised again.
Please provide more details, if you wish.
arnyk is offline
Old 07-22-2012, 10:24 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
My current set-up
Upgrade set-up
I don't understand how you are going out of a receiver into a DAC into an amp and having the system work normally...can you explain how you intend to make this work and what sort of equipment/speakers you have?
B.
Brian B is online now
Old 07-22-2012, 11:17 PM - Thread Starter
kzhtoo's Avatar
My current set-up
Upgrade set-up
B.
It's my mistake. After I wrote it in the afternoon I realized that it wouldn't work the way I intended. It should have been DAC --> receiver --> amp.
kzhtoo is offline
kzhtoo's Avatar
Thanks for all the suggestions.
kzhtoo is offline
Old 07-23-2012, 06:36 AM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
My current set-up
Upgrade set-up
I tried several DACs at the $500 level and below. Here are three favorites, in order :
1. PS Audio DLIII (original retail $999)
2. Music Hall DAC 25.3 ( tube in output stage)
3. Cambridge DAC Magic
Next DAC I will try in this range is the Arcam R-DAC
stevensctt is offline
Old 07-23-2012, 07:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
First off, what was your criteria for choosing favorites?
If the criteria was SQ, what listening methodology did you use that was properly level-matched, time-synched, and bias-controlled?
If your opinons are based on a reliable listening methodology, then that will have some general interest.
arnyk is offline
Old 07-23-2012, 01:35 PM
WagBoss's Avatar
Personally, I would not buy an external standalone DAC unless I had >$5000 speakers
WagBoss is offline
Old 07-23-2012, 02:42 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Yeah, if you want more then: Peachtree iDAC and Rega DAC--both $1K. If you want to go higher then there is the Wadia 121 @ $1300.
B.
Old 07-23-2012, 03:04 PM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
Try the Asus Xonar Essence One http://www.asus.com/Multimedia/Audio_Cards/Xonar_Essence_One/
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
Old 07-23-2012, 04:58 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
B.
Tried, owned the Rega DAC. While generally well reviewed, not a favorite of mine.
Old 07-23-2012, 05:12 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
C
My criteria and methodology are not complex. I owned (still own) all three, interchanged them within the same system, same source, same room, same music, same everything. Even substituted solid state and tubes for pre and amplification.
I've had the speakers (Spendor SP 7/1), amps (Marantz and PrimaLuna) and sources for a couple of years and listen to nearly the same music daily.
It did come down to SQ measured by my own ears. I would tilt my head for level matching, time sync listening on my watch and alternately switched between Fox News and MSNBC to control bias.
Old 07-23-2012, 07:22 PM
diomania's Avatar
Liked: 50
Everything except for same volume level. You missed one of the most critical aspect.
diomania is offline
Old 07-23-2012, 07:51 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
Same everything, included volume. There were volume differences and I would manually adjust. Sorry, no SPL meter used although I do own one.
Old 07-23-2012, 09:53 PM
diomania's Avatar
Liked: 50
That's what I mean, you didn't really match volumes to objective level.
diomania is offline
Old 07-23-2012, 10:16 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
I prefer to listen rather than measure. Preferences are subjective.
Old 07-23-2012, 10:39 PM
diomania's Avatar
Liked: 50
Then you should edit your post (#19):
Very likely, the difference you've heard was due to volume levels not matched precisely.
diomania is offline
Old 07-23-2012, 10:57 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
Seriously?
Old 07-24-2012, 05:32 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Do you think that makes you different from me or better than people who can measure audio gear and understand the meaning of what we measure?
Do you seriously believe that they get all or most of their pleasure from measuring audio gear? No! Measuring audio gear is work. It can be work that is fun, but it is at its core boring, repetitive lab work.
Don't you think that people ho do measure on occasion audio gear on occasion spend hour after pleasurable hour listening to their audio systems?
I don't know of one person who is well-known in audio (and I know quite a few) who doesn't or (in the case of people like Julian Hirsch who have passed) didn't prefer to listen rather than measure.
The statement: "I prefer to listen rather than measure." is a truism, that sheds very little light on the question at hand.
That would also be a truism.
What do you call a preference that is based on illusions or false information? Do you want to visit that shimmery blue lake on the horizon that is a mirage? I can tell you some funny stories about that, relating to some people from Chicaog who, seeing it on the horizon started talking about swimming in the Salton Sea. ;-)
Preferences are all fine and good as far as they go, but they aren't universal.
I agree that in the end, its the sound quality that matters, and let the measurements go where they will. Ironically, I have measured a ton of audio gear over the years. Yet I constantly advise against giving too much credibility to small differences that can only be measured and not heard.
What actions are logical when they are based on illusions or other false information?
What advice should people who are "in the know" give?
We can say that "This is a hobby, and its all about fun", but Audio is about science, art, and enjoyment. What about making scientific claims like "it sounds better" when in fact there are no audible differences at all?
arnyk is offline
Old 07-24-2012, 05:38 AM
bfreedma's Avatar
Liked: 51
Seriously?
Yes.
bfreedma is offline
Old 07-24-2012, 05:44 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Agreed.
The problem of level matching is a very common problem with almost all audiophile listening evaluations including most that are done by well-known reviewers. Most audiophiles who talk about audio gear sounding different don't have any test gear at all, or if they have anything that measures, they have a cheap SPL meter. If you match levels by ear, you can hear differences with your ears because your level matching methodology is not any better than your listening methodology. Only meters measuring actual electrical audio signals are sensitive and reliable enough. Acoustic measurements are too imprecise and have too many built in variations.
There are other serious problems.
(1) Most audiophiles don't listen to the identical same music when they compare equipment. They listen to one piece of equipment with part of a recording, and then listen to the other piece of equipment with a somewhat different part of the same recording. The sound of music is constantly changing. Therefore, unless care is taken to match the musical selections being listened to with a great deal of precision, of course they will hear differences.
(2) Most audiophiles don't listen to equipment in quick succession. They hook up one piece of equipment, listen to it, and then hook up another piece of equipment and listen to it. It is a scientific fact that is now well understood that our memories for the small details of sound vanish after a few seconds. This is how our brains are wired. Only quick switching can give a reliable listening impression of small differences.
(3) Listener bias is almost always towards hearing differences, even when there aren't any. Again, we now have brain research that says this is the way that we are wired. This is easy to show when you address the first 3 problems: level matching, time synchronization, and quick switching.
arnyk is offline
Old 07-24-2012, 05:50 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Seriously?
Unless you matched levels very carefully, it is certain that the volume levels were mismatched enough to make the things you were comparing sound different. If you compared some component to itself with mismatched levels, it would sound different! Most DACs and music players have different output level ranging from about 1 volt to about 3 volts with the same digital signal. That's a huge audible difference all by itself.
Careful level matching involves a stable signal source such as a CD with test tones, and a measurement device properly attached, such as a voltmeter connected across the terminals of your main speakers.
arnyk is offline
Old 07-24-2012, 07:54 AM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
This is the methodology that I employ as well. In my decades of experience when reviewing audio equipment (pseudo-professionally, of course) I've found that Fox News and MSNBC are the only reliable sources for controlling bias. When a double-blind, inverted-conservative study is required, I look no further.
Just wire this up. It's only 8-bit, you don't need to waste your money on those overpriced 16 and 24 bit contraptions. This 8-bit DAC is superior because it's more efficient. Fewer bits means that it's easier for the device to do its job and it doesn't have to work as hard. You won't be able to hear the difference anyway. They're all the same and bits are bits!
Greg121986 is offline
