Manufacturers: PLEASE include full bass management on more 2.0 receivers, integrateds and preamps - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 48 Old 08-02-2012, 09:36 PM
Wayne Highwood's Avatar
Liked: 43
Donut, here is another you should check out.
Wayne Highwood is offline
post #32 of 48 Old 08-03-2012, 07:19 PM - Thread Starter
donutfan's Avatar
Quoted: 18 Post(s)
^ nice!
donutfan is offline
post #33 of 48 Old 08-04-2012, 06:13 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 336 Post(s)
Liked: 6994
You can "easily" put one or two subwoofers in a system with an analog preamp if the subwoofer has its on crossover. I just added two Velodyne Optimum 8's into my 2ch system and have gotten excellent results. I just wanted a slight "beef up" of the bottom end in my system. The subs have speaker inputs and line level inputs and outputs handled by the sub's crossover. I tried the speaker input setup first and after dinking with the sub crossover and sub volume I've got the subs merged seamlessly into the sound stage. I'm so pleased that at this point I have no interest in trying the line level route: preamp -> sub -> amp -> speaker, even after buying new interconnects to facilitate the setup. And, obviously, using the speaker input on the sub still allows full range to my speakers vs the sub crossover filtering low end to the speakers with the line level approach. I forgot to add that these subs also have an automatic "room correction or calibration" feature and come with a microphone.
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
post #34 of 48 Old 08-04-2012, 10:04 AM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
larry
I agree and do the same with a couple of integrated amps. Arguably a better arrangement and makes bass management output a non-issue
stevensctt is offline
post #35 of 48 Old 08-04-2012, 11:45 AM - Thread Starter
donutfan's Avatar
Quoted: 18 Post(s)
Unfortunately, 99% of the subs I have looked at do not include an adjustable crossover for the speaker level outputs. In other words, the crossover adustment control on the sub affects only the subwoofer itself. This creates the potential for a "hole" in the sat+sub system's overall output and/or phase issues: the speaker level xovers I've seen almost always use a relatively high crossover point e.g. 100Hz with a shallow cutoff slope of 6dB/octave. So while a good-sounding system is still possible with such a crossover system, IMO it makes it more difficult to properly blend the sats with the subwoofer.
donutfan is offline
post #36 of 48 Old 08-04-2012, 12:34 PM
Nyal Mellor's Avatar
Quoted: 463 Post(s)
Liked: 342
If you measure the main speakers by themselves you can 'craft' the sub crossover to fill in the bottom end. That's how I do it when I integrate subs into a system without a crossover for the mains. See the blog article I wrote:subwoofer crossover frequency, slope and phase for two channel systems
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #37 of 48 Old 08-04-2012, 02:34 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
I like using 2-way monitors in my smallish room and have found that they benefit greatly from having 60 hz and below taken off them. It increases their clarity/crispness in the mid-range... and especially when I want to crank the volume!
Most subs I have looked at in my price range don't have speaker output after its crossover. So without an AVR or added digital processing unit it was impossible to crossover from monitors to subs. I could only run monitors full range with the subs in support.
And I would also be dubious on relying on a sub crossover to feed my speakers even if it had one. I have two identical subs in my room that were purchased new at the same time. A while back I thought I had blown one of them because it was sounding very muddy and booming compared to the other one that was very tight and tactile. Turns out the problem was that the low pass filter bypass switch had been knocked and the sub's low pass filter was active (even though it was set as high as it would go at 120 hz) Flicking the switch back to 'bypass' instantly solved the problem. I was astonished at the difference between the digital crossover in the AVR compared to a physical low pass filter.
kiwi2 is offline
post #38 of 48 Old 08-04-2012, 05:08 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Agreed.
It's hard to buy a decent 2 or 4 channel amp in car audio without analog high pass filter and low pass filter dials with on/off switches. I think the home audio manufacturers are oblivious to the fact that their market is changing. It doesn't have to be full digital bass management. Most people wanting to integrate subs would be happy with that kind of dial setup and and an LFE jack on the back of their amp as long as the crossovers were decent. How much could this add to the cost of an integrated amp?
Nethawk likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #39 of 48 Old 08-05-2012, 08:56 AM
Moderator
Moderator
Quoted: 336 Post(s)
Liked: 6994
Yes, and unfortunately you won't know until you try. And it's tough to judge by others experiences because the room size and type, speaker type and placement, and the speaker's characteristics will all come into play when trying to dial in the sub. And who has the exact same room, speakers and placement? And ears. smile.gif My case is probably the "simplest" because my mains are full range and I just wanted to extend the low end some and beef up a bit where they overlap.
larry
post #40 of 48 Old 08-05-2012, 01:55 PM - Thread Starter
donutfan's Avatar
Quoted: 18 Post(s)
+1 (heck I saw those way back in the mid 90s on $200 amps, so it's not like it is some kind of hi-tech/pricey technology)
Younger folks (@30 and younger) have grown up with subwoofers, and I think making it easier for them to use them with an audio-only system would be a good way to attract more customers.
:thumbsup:
donutfan is offline
post #41 of 48 Old 08-05-2012, 02:04 PM - Thread Starter
donutfan's Avatar
Quoted: 18 Post(s)
True. But the inclusion of a bass management system sure would improve one's chances of success!
donutfan is offline
post #42 of 48 Old 08-05-2012, 11:42 PM
kzhtoo's Avatar
I've been thinking about the same "issue" for awhile now. I have had an all-in-one (music, HT, gaming) 2.1 system running by a receiver. After I upgraded my speakers and adding a quality external amp, I feel there's more to it than the music performance I'm getting now and feel the pre-amp/dac section in the receiver is the weak link.
But it seems to me that I won't be able get there unless I spend about $5k for pre/pro such as Anthem AVM 50v or Classe CP800. My current receiver is Anthem MRX and I love its room correction and bass management but I feel pre-amp section might be a little weak to get the best out of my system. My speakers are Focal Electra and Paradigm Sub12. Amp is Pass Labs XA30.5.
Anyone feel integrating a pre-amp/dac like Peachtree NovaPre or Benchmark Dac pre is a good move for music playback? My main concerns are losing room correction, quality sub integration and EQ currently provided by MRX.
kzhtoo is offline
post #43 of 48 Old 08-05-2012, 11:58 PM
kzhtoo's Avatar
And I'm not even sure AVM50v will give significant upgrade over MRX in terms of sound quality. frown.gif plus I'll be paying for video processing capability I don't care much about.
But for Classe CP800, I won't get hdmi ins.
kzhtoo is offline
post #44 of 48 Old 08-06-2012, 03:47 AM
Moderator
Moderator
Quoted: 336 Post(s)
Liked: 6994
What's the difference in what you hear for 2ch if the crossover is in the sub or the preamp?
larry
post #45 of 48 Old 08-06-2012, 06:09 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Speaker-level crossovers are always a crap shoot unless specifically designed for the specific speakers involved, because their performance depends acutely on the impedance curves of the customer's speakers.
I recently migrated from using the speaker level crossovers in my sub to the bass management in my AVR, and the improvement in over-all cleanliness and bass detail was astounding. The mains have 8 inch woofers, so they are probably far more competent in the bass than most systems with 6.5 or 4 inch woofers.
arnyk is offline
post #46 of 48 Old 08-06-2012, 09:18 AM - Thread Starter
donutfan's Avatar
Quoted: 18 Post(s)
larry
Probably nothing, if there is an actual bass management system present. And personally speaking, that means low AND high pass filters (distance compensation would be nice too).
donutfan is offline
post #47 of 48 Old 08-06-2012, 12:07 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
larry
Or, the third option - a separate component.
In any case its about the crossover frequencies, the slopes, the relative levels and the routing of the channels, any equalization, etc., not where the circuity is. That presumes the circuitry is at a reasonable quality level.
arnyk is offline
post #48 of 48 Old 04-29-2013, 09:49 AM - Thread Starter
donutfan's Avatar
Quoted: 18 Post(s)
donutfan is offline
Reply 2-Channel Audio
