Preamp search - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-01-2012, 11:24 AM - Thread Starter
kzhtoo's Avatar
Anyone know of good quality 2.1 preamp that does the following well? Budget is $2k.
1) Sub integration and bass management
2) HT bypass
kzhtoo is online now
post #2 of 17 Old 08-01-2012, 04:20 PM
dwong's Avatar
http://www.avsforum.com/t/1136817/parasound-model-2100-preamp-owners-thread
I see the atoms free and fine,
That bubble like a sparkling wine;
I see the songs Electrons sing,
Jumping from ring to outer ring;
              - Lister, The Physicist
dwong is offline
post #3 of 17 Old 08-01-2012, 08:26 PM - Thread Starter
kzhtoo's Avatar
post #4 of 17 Old 08-01-2012, 09:03 PM
NewHTbuyer's Avatar
Liked: 41
NewHTbuyer is offline
post #5 of 17 Old 09-04-2012, 01:41 PM
poopiehead's Avatar
Cary slp-03 sells for under $2k now
http://caryaudio.com/products/classic/SLP03.html
poopiehead is offline
post #6 of 17 Old 09-04-2012, 01:48 PM
A9X-308's Avatar
Quoted: 1334 Post(s)
Liked: 1004
Where's the sub integration?
A9X-308 is offline
post #7 of 17 Old 09-29-2012, 07:03 PM
Bigus3333's Avatar
2) HT bypass
I don't want to start anything here but........
You could look at the new Emotiva XSP-1 or even the older USP-1.
I had the older USP-1 in my system for a while and for the money it was great.
Bigus3333 is offline
post #8 of 17 Old 09-30-2012, 09:07 AM
commsysman's Avatar
Quoted: 994 Post(s)
Liked: 527
The best-sounding preamp I know of for under $2000 is the Vincent SA-31MK preamp. It is $1500. Much better IMO than anything Parasound makes in that price range.
It has two sets of outputs, one of which can go to the subwoofer. All you need to do for "bass management" is set the rolloff frequency and level on your subwoofer; works great for me.
2) HT bypass
commsysman is offline
post #9 of 17 Old 09-30-2012, 03:03 PM
runnin''s Avatar
Liked: 45
Neither of those have HT bypass, and the XSP is an unknown quantity at this point. The USP has a crappy volume control, users complain that the increments are too big for typical adjustments.
runnin' is offline
post #10 of 17 Old 09-30-2012, 03:25 PM
postrokfan's Avatar
Quoted: 524 Post(s)
Liked: 3144
The USP-1 actually has the HT bypass feature. Unfortunately, the unit has to be on to use it.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #11 of 17 Old 09-30-2012, 03:59 PM
runnin''s Avatar
Liked: 45
Pardon me, I remembered an issue with the bypass, I should have double checked, the XSP has to be on as well.
runnin' is offline
post #12 of 17 Old 09-30-2012, 08:40 PM
filecat13's Avatar
Quoted: 35 Post(s)
Liked: 101
Parasound P7, recently on sale for way less than $2k at authorized dealers. It's all analog: no DAC or digital inputs, but a pair of balanced inputs and 7.1 balanced outs, plus lots of unbalanced ins and outs. Phono stage, both MM and MC. Analog bass management. HT bypass (7.1). With a top flight universal player or an external DAC, it's quite the future proof unit. You change what feeds into it rather than get a new pre every time there's a new spec-o'-the-month.
What I can afford, when I can afford it...
filecat13 is offline
post #13 of 17 Old 09-30-2012, 11:53 PM
A9X-308's Avatar
Liked: 1004
Originally Posted by filecat13 View Post
Parasound P7
Whilst it does have some bass management, it isn't much giving only a choice of turnover of 50 or 80Hz and no ability to select slope, so you'd want to hope the limited options will actually be what you need in your particular system.
Much better would be a separate active xover.
A9X-308 is offline
post #14 of 17 Old 10-06-2012, 09:00 PM
filecat13's Avatar
Quoted: 35 Post(s)
Liked: 101
Maybe you could enumerate the "much better" part while keeping the OP's two requirements in mind?
post #15 of 17 Old 10-06-2012, 11:55 PM
A9X-308's Avatar
Liked: 1004
I pointed out the limitations in the P7, but I'm not the least interested in searching for an alternate product. Suggest something else and I will look and comment.
A9X-308 is offline
post #16 of 17 Old 10-07-2012, 10:04 PM
filecat13's Avatar
Quoted: 35 Post(s)
Liked: 101
That's not likely. It seems the OP has left, and I'm not interested in supporting your hobby.
post #17 of 17 Old 10-07-2012, 10:20 PM
A9X-308's Avatar
Liked: 1004
Hardly my hobby. This issue has come up before with this pre, so I knew what the limitations were, but if you think limited choices of xover freq, available filters and slopes (or even stating what the included ones are) then you have a different view than I do, especially considering it's price.
A9X-308 is offline
Reply 2-Channel Audio
