Looking for a very high quality upgrade for a clock radio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 08-09-2012, 12:57 PM - Thread Starter
index2020X's Avatar
I realized that I spend a lot more time in the bedroom listening to music ... far more than the living room where I now have my nice new B&W speakers. smile.gif So, that means it's time to upgrade my years old Bose Wave Radio II.
I'm looking for the highest quality audio that I can get at less than $2,500 in a form factor that does not exceed 16" (width) x 10" (depth) x 8" high (these are my "architectural constraints"). Does not need to have a CD player and/or radio since I feed my music via a 3.5" cable from various sources. The room size is approx. 15 feet x 20 feet. Any recommendations will be deeply appreciated.
index2020X is offline
post #2 of 27 Old 08-09-2012, 01:33 PM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
I don't know that this exists...This is the only thing that comes to mind that fits your size requirements. But I have never heard it and I suspect it may be more "show" than "go."
Greg121986 is offline
post #3 of 27 Old 08-09-2012, 01:45 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Seriously, I suspect the Bose (or its Cambridge Soundworks equivalent) is about as good as you can do can do with a box that size. Physics is your enemy here.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 27 Old 08-09-2012, 02:18 PM
Ratman's Avatar
Quoted: 1277 Post(s)
Liked: 1026
Use the Bose until it dies.... it's just a clock radio. Sorry to say that anyone that can invest <$2500 for a clock radio needs a sanity/reality check. For that amount of $$, you can get a $5 alarm clock at Walmart and real nice sound system for < $2495. wink.gif
Ratman is offline
post #5 of 27 Old 08-09-2012, 02:20 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
mcnarus is offline
post #6 of 27 Old 08-09-2012, 02:22 PM - Thread Starter
index2020X's Avatar
Yeah - the Bose is on it's death bed... and needs a replacement soon. Doesn't matter what we call it... clock radio / music system ... I just need a really good sound system that meets my form factor limitation ...
As to who spends how much for an audio device -- that's a matter of personal preference and budget -- not a reality check. But thanks for your opinion. The opinion that would have been helpful is what should I but that meets my form factor for <$2495.
post #7 of 27 Old 08-09-2012, 02:23 PM
Ratman's Avatar
Liked: 1026
Then spend $995 for a sound system, $5 for an alarm clock and $1500 for a carpenter.rolleyes.gif
EDIT:
Contact Bose. I bet they may be able to provide a replacement/repair recommendation for less than $2500.
Ratman is offline
post #8 of 27 Old 08-09-2012, 02:33 PM
dwong's Avatar
Take a look at Tivoli, Geneva Sound or B&O.
I see the atoms free and fine,
That bubble like a sparkling wine;
I see the songs Electrons sing,
Jumping from ring to outer ring;
              - Lister, The Physicist
dwong is offline
post #9 of 27 Old 08-09-2012, 05:20 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The Henry Kloss Model One Table Radio is probably what you want.
It has now been put back into production as the Tivoli Model One Table Radio, and is available from Amazon for only $145.
In addition to having a very good AM/FM tuner, it has a very nice speaker and amplifier and an external 3.5 mm input jack for other music sources. You can plug into it and get nice sound.
It also has a nice-looking wood cabinet.
You could also just plug your cable into a pair of powered speakers such as the Audioengine 2 speakers, but the volume control is on the rear of one speaker, which might not be convenient. They will easily fit your space and cost $200. I have a pair connected to my computer, and the sound quality is very good.
My wife has a Nakamichi TM-1 radio in her room. It is out of production, but if you could find a used one, it is probably the best unit of this type ever made. Maybe one is on e-bay?
It has an excellent tuner, a true high-fidelity power amplifier, and an excellent 5-inch speaker. It cost around $300 when they were making it, plus there was a matching second powered speaker as an accessory for another $150 if you wanted stereo.
Update- I just looked on E-bay and there is one available for $125 complete with the companion stereo speaker. Each unit is 10.5 inches wide, so you wouldn't care about the second speaker unless you have a another place to put it somewhere in the room. In any case it is a very fine single-channel unit by itself and highly recommended.
They have it listed as "Nakamichi Clock Radio 1".
commsysman is offline
post #10 of 27 Old 08-09-2012, 06:51 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
The problem you are also having is that people are turning away from clock radios to using their phones and/or with docks. Do you have an iPhone or iPod Touch for the alarm clock? If so, looks like the Peachtree musicBox Amplifier might fit your space. Then get whatever tiny speakers you want to go with it: http://www.audioadvisor.com/prodinfo.asp?number=PTMUBOX1
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 27 Old 08-10-2012, 09:25 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Just took a look at the Tivoli Audio site. They have a broader product range than the last time I came across them. You might find something that works for you there.
And give the balance of your $2495 to Oxfam.
mcnarus is offline
post #12 of 27 Old 08-10-2012, 02:21 PM - Thread Starter
index2020X's Avatar
Thanks to all those who made meaningful recommendations to solve the problem.
I also find it amusing that there are so many members on a website about expensive a/v gear who are judgmental about how one should spend their $$$.
Best,
post #13 of 27 Old 08-10-2012, 02:43 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
This isn't a website about expensive gear. It's a website about good gear. You seem confused about the distinction.
mcnarus is offline
post #14 of 27 Old 08-10-2012, 02:49 PM - Thread Starter
index2020X's Avatar
In general, expensive is not always good. But good is in general expensive.
Anyway, I don't think you should be telling me how to spend my $$$ (beyond what I am asking for an opinion on). I am referring to your Oxfam comment here.
post #15 of 27 Old 08-10-2012, 02:54 PM
math-geek's Avatar
Check out the Yamaha TSX-120 or 130. These are very nice looking, high end clock radios with iPod dock and mp3 inputs. They are available on fleabay for less than $300.00.
I use a Yamaha MCR-040 in my bedroom and it is really nice sounding, much better than the Bose Wave II that I borrowed from my girlfriend.
math-geek is offline
post #16 of 27 Old 08-10-2012, 03:14 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Actually, good and even excellent is often not very expensive at all.
But we weren't really trying to tell you how to spend your money. We were telling you that you couldn't spend that much on what you wanted if you tried. Nor would it make any sense to. Given your size constraints, all the money in the world can't overcome the compromises that Bose and the other companies we suggested make.
mcnarus is offline
post #17 of 27 Old 08-10-2012, 03:26 PM
Ratman's Avatar
Liked: 1026
that's why there are contractors.... to build enclosures to accomdate your hardware, as opposed to buying expensive hardware to accomodate the enclosures.
Ratman is offline
post #18 of 27 Old 08-10-2012, 08:18 PM
math-geek's Avatar
I agree, my Yamaha micro system sounds better than the Bose, but they are different systems. The Bose is very good for what it does but it is pretty expensive. Your size constraints are a serious constraint to good sound quality.
post #19 of 27 Old 08-10-2012, 08:27 PM
Rammitinski's Avatar
Quite a bit overpriced is more like it, relatively speaking.
Rammitinski is offline
post #20 of 27 Old 08-11-2012, 07:05 AM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
The only clock radio that I know of that's in that price range of $2500 is the Meridian M-80. Plays CD's,DVD's,AM,FM and has an I-Pod. Also has an alarm clock function. Cost $3000. It's just a bit larger than the Bose Wave Radio.For me my $20 buzzer is just fine.smile.gif
Class A is online now
post #21 of 27 Old 08-11-2012, 07:10 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Relative to what? Its direct competitors seem to be in the same ballpark.
mcnarus is offline
post #22 of 27 Old 08-11-2012, 07:11 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
I stand corrected. I didn't think any company could be dumb enough to believe that any consumer would be dumb enough to spend that much on a clock radio.
mcnarus is offline
post #23 of 27 Old 08-11-2012, 07:18 AM
Ratman's Avatar
Liked: 1026
Manufacturers rarely underestimate consumer's lack of common sense and those with an expendible budget.
Ratman is offline
post #24 of 27 Old 08-11-2012, 07:42 AM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
post #25 of 27 Old 08-11-2012, 07:59 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Come on I know ypu really want one.
Couldn't I just have the money, Dad?
mcnarus is offline
post #26 of 27 Old 08-11-2012, 08:04 AM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
Right.  I have the predecessor F80 and it has outstanding sound for its size and package.  Because of that, it should not be compared to any component systems which are, unquestionably, better value.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #27 of 27 Old 08-14-2012, 09:34 AM
CloneX's Avatar
Perhaps something from Grace Digital would do the trick:
http://www.gracedigitalaudio.com/internet-radios-c-2.html
CloneX is offline
Reply 2-Channel Audio
