Need help with my 1987 Denon DRA-95VR receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-15-2012, 09:36 PM - Thread Starter
LVIV73's Avatar
I just bought Denon DRA-95VR receiver on eBay in mint condition,however it is missing the remote control.
My first question is,where can I find the code for the remote?Or will it even work with modern remotes?
I did auto remote code search with no luck and Denon codes that came with remote manual did not work.
And my second problem/question is this.Every time I power on the receiver it always goes back to Tuner input setting,is there a way to change the default input?
Or do I need to switch the input manually every time I turn on the receiver with these older receivers?
I love this receiver and it sounds way better than my modern Denon AVR391,I just wish my remote worked and the volume and input settings didn't reset every time I turn off the unit.
Thanks in advance for any help.
LVIV73 is offline
post #2 of 10 Old 08-16-2012, 03:46 PM - Thread Starter
LVIV73's Avatar
Anyone?Did I post this in the right section?
LVIV73 is offline
post #3 of 10 Old 08-16-2012, 03:56 PM
Ratman's Avatar
Quoted: 1459 Post(s)
Liked: 1158
Ask the mods to move this thread here:
http://www.avsforum.com/f/90/receivers-amps-and-processors
LVIV73 likes this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #4 of 10 Old 08-16-2012, 05:46 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Or just repost it there. It's hardly a capital crime.
Do you have a manual for the receiver? Have you tried googling for one?
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 10 Old 08-16-2012, 06:19 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
if lucky, your universal remote will have the codes for the Denon. As far as the default input, I don't recall any such thing and I've been in this business for a while, they should always stay where u left them off last.
MrBobb is offline
post #6 of 10 Old 08-16-2012, 07:14 PM - Thread Starter
LVIV73's Avatar
Manuals online are only in German.And I'm starting to think these vintage receivers do go back to default input,unless there is a key combo to set another input as default.I know that volume goes back to zero also upon power off.
LVIV73 is offline
post #7 of 10 Old 08-16-2012, 07:18 PM - Thread Starter
LVIV73's Avatar
Way ahead of you,manuals are only in German.That's why I posted my questions here because there is almost no info on it on theinternet.
I figured that there is gotta be another soul that owns one or used to own one.
LVIV73 is offline
post #8 of 10 Old 08-17-2012, 05:17 AM
Ratman's Avatar
Liked: 1158
No one said it was a crime. He asked if this was the "right section". The forum I suggested may get more attention. And, it's better and easier (IMO) to have responses consolidated in one thread, one forum.
post #9 of 10 Old 08-17-2012, 06:05 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Can you get google or some other similar free service to translate the German manual for you? I'm having pretty good luck with Google's work with web pages.
arnyk is offline
post #10 of 10 Old 04-11-2016, 07:13 PM
Liked: 0
DRA95 Owners Manual - English
I know this post is a little old, but I was in the process of reviving my Denon and while gathering all the items in storage, as well as online forums, noticed this request for the User Manual. I do have one if you want me to make a copy of it.
Mike
mgambuzza is offline
Reply 2-Channel Audio
