Budget Headphone Dac/amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-28-2012, 09:40 AM - Thread Starter
WagBoss's Avatar
Are there any dac/headphone amps that are in the quality/price range of the nuforce udac-2, maybe a bit cheaper? All it needs is USB input, and a headphone output with a headphone amplifier and decent quality dac.
WagBoss is offline
post #2 of 14 Old 08-28-2012, 10:12 AM
CHAVAN30's Avatar
Check out Fiio's website. They have a range of dac/amps. If you buy from Amazon, make sure it is a legit dealer. There have been a few fakes.
CHAVAN30 is offline
post #3 of 14 Old 08-28-2012, 11:08 AM - Thread Starter
WagBoss's Avatar
cool thanks
WagBoss is offline
post #4 of 14 Old 08-28-2012, 11:34 AM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
Check out the Audioquest Dragonfly. It's not real cheap ($250), but it's the size of a USB thumb drive and meets your other requirements.
saeyedoc is offline
post #5 of 14 Old 08-28-2012, 01:13 PM - Thread Starter
WagBoss's Avatar
WagBoss is offline
post #6 of 14 Old 09-25-2012, 09:16 AM
destroysall's Avatar
Fiio E10 or Fiio E17. Both are amazing! I own the E10, and to my ears it is much better than the NuForce.
destroysall is offline
post #7 of 14 Old 09-25-2012, 09:17 AM
Deleted.
post #8 of 14 Old 09-25-2012, 08:36 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3000
The E17 is great. Size of a smaller smart phone. Good sound. I use mine with my computer in my office at work.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #9 of 14 Old 09-26-2012, 06:38 PM
pkoko's Avatar
Do any of these units connect directly to iphone? I mean do they bypass the Iphone's built in DAC?
pkoko is offline
post #10 of 14 Old 09-27-2012, 06:36 PM
CHAVAN30's Avatar
With a lod. It will bypass the internal DAC. Fiio sells them also on Amazon.
CHAVAN30 is offline
post #11 of 14 Old 09-27-2012, 06:39 PM
cel4145's Avatar
Liked: 3000
I'm not an iPhone owner, so I'm not positive about this. But I'm pretty sure the LOD bypasses the headphone amplifier in the iPhone, not the DAC. LOD=LINE OUT DIRECT. So it would be an analog signal that has already been processed by the DAC in the iPhone.
cel4145 is offline
post #12 of 14 Old 10-31-2012, 04:41 PM
Unfortunately, no. Even a Line-Out Dock connector wouldn't do much. Only iDevice approved DACs can bypass the internal DAC inside an iDevice (iPod, iPhone, iPad). The only other way to bypass the internal DAC is to use the Pure i-20 dock and set it up with an external DAC. However, this eliminates any possible chance of portability.
If portability is what you want, check out ALO Audio as their DACs are iDevice approved. However, if you are on a tight budget, these may not appeal to you.
Destroysall.
post #13 of 14 Old 11-01-2012, 07:29 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Originally Posted by maxweber View Post
Any resource to get detailed specifications of E17?
http://supercurio.project-voodoo.org/audio/for-engadget/E17-iPad-NexusSVoodoo.htm
Test FiiO E17 USB DAC
Frequency response (from 40 Hz to 15 kHz), dB: +0.01, -0.57
Noise level, dB (A): -97.2
Dynamic range, dB (A): 97.5
THD, %: 0.0015
IMD + Noise, %: 0.036
Stereo crosstalk, dB: -93.7
arnyk is offline
post #14 of 14 Old 11-01-2012, 07:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Which iPhone?
The first iPhone had serious bass losses with typical 16 ohm headphones, but later models not so much:
http://www.swedroid.se/rightmark/x10_mini_comparison/x10miniaudicomparison.htm
iPhone 3GS
Frequency response (from 40 Hz to 15 kHz), dB: +0.31, -0.20
Noise level, dB (A): -83.7
Dynamic range, dB (A): 83.6
THD, %: 0.0095
IMD + Noise, %: 0.045 0
Stereo crosstalk, dB: -79.9
Apple upgraded their IOS device headphone amps in general about his time so later models should be no worse.
arnyk is offline
Reply 2-Channel Audio
