Increase overall volume using EQ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-30-2012, 11:24 AM - Thread Starter
thor777's Avatar
I bought a Cowon Z2 android music player and although it has really good sound quality, the max volume is not loud enough. Is it good to raise the EQ on all bands to increase overall volume or is that bad practice? Will it affect sound quality?
Thanks in advance
thor777 is offline
post #2 of 10 Old 08-30-2012, 12:16 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Thanks in advance
That is a definate "It depends"
The general exposure is that if you set all bands high, they won't sum to flat enough response. Whether that happens enough to bother you is mostly dependent on the technical details of how your player is made.
The safer approach is to add an outboard headphone amplifier like a FIIO E5.
arnyk is offline
post #3 of 10 Old 08-30-2012, 12:51 PM - Thread Starter
thor777's Avatar
I'm trying to avoid going the amp route tongue.gif I tried using a CMoyBB with the Z2 but lost detail......
thor777 is offline
post #4 of 10 Old 08-30-2012, 04:26 PM
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1004
More efficient headphones?
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #5 of 10 Old 08-30-2012, 10:26 PM
has7738's Avatar
Liked: 24
Try a different amp. There are much better designs out there.
has7738 is offline
post #6 of 10 Old 08-31-2012, 02:54 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
For openers the CmoyBB schematics I've seen don't allow switching the bass boost out. The Fiio E5 does. I
arnyk is offline
post #7 of 10 Old 08-31-2012, 01:50 PM - Thread Starter
thor777's Avatar
I just solved my own problem. I got Volume+ from Play store and increased the maximum volume. It works great! I turned it up to 10 and didn't notice any distortion.
thor777 is offline
post #8 of 10 Old 09-01-2012, 08:31 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
That looks like an effective solution. Stick around kid, a lot of us are still to obtain our first smart phone and someone needs to take up the slack! ;-)
arnyk is offline
post #9 of 10 Old 09-01-2012, 08:45 AM
Hamilcar Barca's Avatar
I agree with this response, given the (general) design of graphic equalizers, but ...
if you're satisfied, it's all that matters and the problem really is solved.
Hamilcar Barca is offline
post #10 of 10 Old 09-06-2012, 12:22 PM
Dave1027's Avatar
Quoted: 12 Post(s)
No apology needed, Arny. There are still a bunch of us old schoolers that don't want to live life through a gadget like some sort of i-zombie.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
Reply 2-Channel Audio
