Peachtree decco 2 power amp choice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-02-2012, 11:49 PM - Thread Starter
gregunderfoot's Avatar
i live in France and I bought a Decco 2 about 3 months ago in the UK, not easy to find in France...
My question is it really struggles driving my Dynaudio 110's but i love the sound they produce. As yet no Peachtree 220 in the UK certainly not France , what would be a good compromise as a power amp? Do not have massive funds for this either.... your suggestions or should I just sell the Peachtree and get a Nova?
gregunderfoot is offline
post #2 of 5 Old 10-03-2012, 12:03 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Power is cheap. OTTOMH suggestion and should be readily available in the EU would be a Yamaha P2500S.
A9X-308 is offline
post #3 of 5 Old 10-03-2012, 08:06 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Which Nova are you referring to? The original Nova's weak point is the amp section too.
Sent from my DROID3 using Tapatalk 2
Face2 is offline
post #4 of 5 Old 10-03-2012, 10:55 PM - Thread Starter
I like the idea of this Yamaha 2500s amp and have since read some good reviews of it used in this context rather than a studio or instrument amp, so thanks for that. Anyone else share that view?
Thanks for the advice on earlier Nova's too, forwarned is forearmed as they say...
post #5 of 5 Old 10-04-2012, 01:23 PM
A9X-308's Avatar
Liked: 951
I use one myself for the LF of my mains. I've also used them fullrange and they are a fine amp. I own and have owned a lot of Yamaha pro and domestic amps and they are well designed and made. I doubt you'll ever get the fan to come on in domestic use.
A9X-308 is offline
Reply 2-Channel Audio
