Do Optical Drives "count" when transferring CD to computer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-13-2012, 06:16 PM - Thread Starter
Michael Osadciw's Avatar
Quoted: 121 Post(s)
Liked: 112
I'm not sure if this is the best spot to post this - moderator please move if necessary.
I'm finally jumping in on transferring my CDs to my computer.
For me, maximum fidelity trumps all because I only want to do this once.
My question is: does the quality of the CD drive in my computer "count" for sound quality during this reading/transfer?
I currently have a Pioneer DVD/CD-RW drive in the computer from around 2004.
I also have an LG CD-RW drive (not for DVD) from around 2001-2002.
- Would using a dedicated CD drive to do the task be better than using the combo DVD/CD-RW drive?
- Or are other drives available today be far superior for pulling the content off of the discs than what I currently have?
- Or does it not matter at all?
- should I also check to see if I can clean the lens before I do this? I bet there's ten years worth of film on it.
Does the speed of copying matter if offered the option? Is the slower the better giving less errors?
I was thinking of using Exact Audio Copy (EAC) for software and storing it as lossless (WAV?) There doesn't appear to be a difference for storing CD in WAV or FLAC unless someone else has a suggestion.
I've been old school spinning CDs up to this point. I'm looking forward to playing back audio a different way without any loss.
Mike
Michael Osadciw is offline
post #2 of 8 Old 10-13-2012, 08:20 PM
Knucklehead90's Avatar
Quoted: 384 Post(s)
Liked: 332
A $20 DVD/CD burner/player works just fine for reading the zeros and ones that make up the music on your CDs. I rip my CDs to FLAC files and it works fine for me. Speed of the operation should be no problem since those cheap drives can read much faster than you or I would care to listen. I use Nero for ripping and for burning back to CD. When I want to make an audio CD that same DVD/CD player works just fine - makes perfect copies of those zeros and ones.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #3 of 8 Old 10-13-2012, 11:41 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Yep. EAC works great. EAC can use AccurateRip to verify that your CDs are ripped error free.
I rip everything to flac. Flac takes up less space than wav, but is otherwise equal quality. Saves on hard drive space over the long run if you have (or accumulate) a big music collection.
And be sure to get a USB backup drive if you don't do so already. Once you invest time in ripping your CDs, you'll cry if you have a hard drive failure.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 8 Old 10-14-2012, 12:33 AM
Tong Chia's Avatar
Mike
The drive does matter it must support the Accurate streaming feature.
Check your drive against the Accuraterip database http://www.accuraterip.com/driveoffsets.htm
Tong Chia is offline
post #5 of 8 Old 10-14-2012, 06:22 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It is question is about something that is all-digital. It's the usual answer.
An all-digital system delivers optimal sound system providing that you aren't going out of your way to change sound quality (e.g. adding digital equalization and the like) and providing there providing that there are no data errors.
Note that the parts of your audio system that are in some sense digital but could make a difference in terms of sound quality, being the DACs, aren't part of this discussion.
We are talking about just ripping CDs. Digital data on the CD going to digital data on your hard drive.
Here's the $64 question: Are there any data errors?
I use a freebie software package called EAC and it seems to complain pretty violently when there are unrecoverable data errors.
Not necessarily. Certainly not at all provided that you are getting accurate rips.
If there is a film on the lens, there would be data errors. Are you getting any data errors?
FLAC is lossless. It does save space at some cost in CPU use and complexity. It does not in of itself change sound quality.
arnyk is offline
post #6 of 8 Old 10-14-2012, 12:29 PM - Thread Starter
Quoted: 121 Post(s)
Liked: 112
Thanks guys for the responses. Regarding data errors, I may be getting errors. I say may be because there's been a batch of CDs I've been burning for the car and sometimes it works, sometimes it doesn't. The program (CDBurnerXP) tells me there is a problem with the disc. I figured it's been a bad batch, but maybe it's the drive. Two out of one are bad when copying and I end up junking the discs. I have no other discs here at the moment to I can't see if it's anything else. The CD drive I had always worked fine, so maybe I'll clean off the lens and use that one for burning and see if I have a higher success rate. Thanks for the info!
post #7 of 8 Old 10-14-2012, 02:00 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
CD players and DVD players do break, even when just in storage. At the price of a quality replacement, there's no reason to tolerate substandard performance.
arnyk is offline
post #8 of 8 Old 10-14-2012, 02:53 PM
Tong Chia's Avatar
The link below points to a tool that scans cd media, the ones to look for are the C2 errors. Your drive has to be able to return the C2 data
http://www.cdspeed2000.com/
Reply 2-Channel Audio
