Real Book Shelf set up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-23-2012, 04:24 PM - Thread Starter
Ab4o's Avatar
I am currently configuring a system the will reside in a bedside bookshelf. I will be streaming Pandora from an iPad. I would also like Fm capability. I will not be taxed power wise, 10-15 watts would probably be overkill. Any ideas on receivers, as far as speakers been looking at paradigm atoms, nht zero 2.0, psb alphas really have not made up my mind on those either. Any suggestions on equipment or implementation would be greatly appreciated. Thanks:)
Ab4o is offline
post #2 of 3 Old 10-23-2012, 06:28 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
At the budget end, there's a Sherwood 4105 receiver and an Airport Express. $200 and change.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 3 Old 10-24-2012, 04:21 AM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15904
fwiw, another suggestion on a good budget reciever look at the onkyo tx-8050 $219 at accessories4less. as for speakers imo i would look at something that is front ported or acoustic suspension design (no ports) if you are going to place them in a bookshelf. the nht super zero's are a.s.d but you might need a sub as they dont go that low in the bass dept.
i'm so laid back,i'm laid out
smasher50 is offline
Reply 2-Channel Audio
