I want to go classic hi-fi 2-channel, what are some good options in the under $1000 range? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 12-25-2012, 10:09 PM
whoaru99's Avatar
Liked: 69
A while backI broke out my old Cerwin D9s for ****s and grins following a previous C-V bashing thread. They sounded better than I expected them to.
Here are some modern versions of large speakers:
http://www.cerwinvega.com/home-audio/floorstanding-speakers/xls-215.html
http://www.tyleracoustics.com/pro_dynamics.html
http://www.musiciansfriend.com/pro-audio/yamaha-s215v-club-series-v-speaker
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 12-26-2012, 02:38 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 186
For my money, the Klipsch RF-82 ii's are the best speakers in this price range.
Here are the specs:
BUILT FROM: 2010
DEPTH: 16.3" (41.4cm) with grille
ENCLOSURE TYPE: Bass-reflex via dual rear-firing ports
FINISHES: Black Ash woodgrain vinyl
FREQUENCY RESPONSE: 33Hz-24KHz ± 3dB
HEIGHT: 43.9" (111.4cm) with feet
HIGH FREQUENCY CROSSOVER: 1400Hz
HIGH FREQUENCY DRIVER: 1" (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
INPUTS: Dual binding posts / bi-wire / bi-amp
LOW FREQUENCY DRIVER: Dual 8" (20.3cm) Cerametallic cone woofers
NOMINAL IMPEDANCE: 8 Ohms compatible
POWER HANDLING: 150W RMS / 600W Peak
SENSITIVITY: 98dB @ 2.83V / 1m
WEIGHT: 61.5lbs (27.9 kg)
WIDTH: 9.3" (23.5cm)
http://www.klipsch.com/rf-82-ii-floorstanding-speaker
I have seen these online for as low as $450 each, which is an absolutely INSANE bargain for what these things can do.
Lumenlab "Community driven video lab".
blake18 is offline
Old 01-10-2013, 01:29 PM
lmyamen's Avatar
For Bookshelf I would recommend the Monitor Audio RX1, they are in the $750 range I believe and they sound fantastic.
lmyamen is offline
Old 01-10-2013, 02:16 PM
Wayne Highwood's Avatar
Liked: 43
I'll chip in a vote for Klipsch Heritage or Extended Heritage models. Look for used forte, forte II, Chorus II. Gussy them up with a Crites crossover and driver updates and you have awesome 'vintage' sound for less than a grand.
Wayne Highwood is offline
Old 01-16-2013, 12:20 PM
mzpro5's Avatar
I bought a pair of Focal 814s a couple months ago and they are very nice. Using an Outlaw 2150 receiver in the set up. I paid a bit under $800 and see AfL now has them for $799/pair.
mzpro5 is offline
